Thread: CDTi Air-Box Modification
    Regular Member DesignforLife's Avatar
    Lancashire
    Question CDTi Air-Box Modification
    Hi All,
    just thought I would ask:
    I have seen members talking about de - restricting Air Boxes on their cars. Something about a tube in the Box... and snapping the edge of it off or something??
    I took my Filter out today to look for said tube - all I found was like a Rubber breather pipe in the lower section and a Trumpet feeding air into the Box.
    Am I wrong? Can you mod the box or not?
    Matt
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    just nicked a pic out of one of the how 2's. Its the bit in the bottom right corner of the pic. Hope this helps.
    Lancashire
    Thumbs up
    Thanks Pricey,
    Thought it was that! Got it unclipped at the top and it seemed a little reluctant to come out at the bottom - thought I would check B4 forcing it...
    Does this make much if any difference?
    Matt
    Mine was a bit tough to get off aswell, and ended up snapping one of the little lugs off.
    The difference is noticable. Sort of cures the flat spot below 1800rpm and gives you a bit more mid range pull.
    yep, a noticable difference, but not a huge one... beneficial IMO..
    SOMERSET
    I've done the mod, and every little helps
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Cutting some of the top trumpet out will also make a big difference but may cause the air to become turbulent at high revs, giving false MAS readings and ECU warning lights (doesn't put the car in to limp mode, just makes it moan.
    yep.. have to agree with Nutron.. hence why i left mine alone..
    Mileage : 000
    Will it make mine do 170 mph if I do the mod??
    Dec 2005
    In the sponge-monkey tent
    Quote Originally Posted by ed taylor View Post
    Only if you get the better half to push once over 160mph
  1. air box modification
    By davedave in forum Petrol Engine related
    Last Post: 10th May 2012, 23:13
  2. Need Help in modification
    By my834 in forum Electrical & ICE (including SatNav)
    Last Post: 20th June 2010, 01:27
  3. 1st Modification
    By Gregg in forum Quick Photo Album
    Last Post: 15th November 2007, 16:51
  4. Next modification anyone??
    By j13hdb in forum Comedy & Humour
    Last Post: 13th November 2007, 16:15
  5. modification to air box????
    By mbonnick in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2006, 15:42
vectra airbox mod
vectra cdti airbox mod
cdti airbox
vectra c airbox
