Results 1 to 10 of 11
Thread: wheel alignment
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    Default wheel alignment
    Hello.
    Once i get my new tyres on the 19's and get them back on the var and i get the rear camber adjusters from down under, Im goin to need to get the wheel alignment done.
    Does anyone know of a wheel alignment specialist? I will need the camber, castor and toe check and altered if needed.
    Ive found a place in MK, they want £125 to check all suspension components (bushes etc etc), 4 wheel laser alignment, castor and camber adjustments. I thought this was a good price.
    Just wondered if anyone else knew of a place.
    Carl
    That looks like a very good quote
    Just make sure their equipment is under 18 months old, after that they tend to go out of calibration, with damage and so on
    Anyone with a modern 4 wheel laserline will be able to do it for you..a system like 'hunter' is what you need..
    I paid £50 for my last total setup on the GSi...
    Regular Member muffking's Avatar
    I need to get the same thing done with mine once I get the front struts changed as the bl00dy car kicked out at 110 yesterday and I had to steer in to it
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    nottm 4 wheel alignment center quoted me £50.00 but i went through my insurance company and paid £67.00, just ask them the name of there approved repairers and give them a ring
    Midlands Mod Shop - NFFC.
    in Colwick, got it. I'll try them when I get my shox
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    If you are going to get full 4 wheel alignment done, make sure they check the thrust line too, if they are any good they will know what you want.
    Admin plasma's Avatar
    On the Forum
    181 Post(s)
    Engine : 150
    Mileage : 74000
    thrust line?
    Regular Member Silver V's Avatar
    Jul 2006
    mmmmmmmmmmmm
    would I need to have mine done? just got new 18's and getting it lowered next sat....
    Mar 2007
    Stockton on Tees
    Quote Originally Posted by plasma View Post
    thrust line?
    The thrust line is the comparson of the rear wheel alignment to the front wheel alignment, without this 4 wheel alignment is 2 wheel alignment on 2 axles.
  1. 4 wheel alignment
    By tangoman in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 21:42
  2. wheel alignment
    By matt2005 in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2012, 12:32
  3. 4 Wheel Alignment
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2011, 20:06
  4. 4 wheel alignment
    By dave_taiho in forum Northern Ireland (RO - Vacant)
    Last Post: 9th March 2010, 16:35
  5. Wheel Alignment?
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2008, 23:09
