Results 1 to 10 of 15
Thread: Smelly Washer Jets!!!
    Regular Member crazychemist76's Avatar
    North Wales
    Default Smelly Washer Jets!!!
    Ok here's a wierd one that I hope someone has the answer to. Whenever I squirt my washer jets onto the windscreen if I have a/c or fan on there is a god awful sulphur like smell comes into the car!! Kinda embarrasing if I have female company in car as it smells like someone has sqeezed cheese!!!
    Heeeeeelp!!! Car is going in for 50k serivce next week and I would like to have an idea to tell what to look for!!!!
    Regular Member R13hard's Avatar
    Devon
    Engine : 2.0 Turbo
    i have had a horrible smell in the washers before, i found out throught the forum that it was probably the actual screen wash fluid . some of the cheaper stuff can "go off" and stink when sprayed
    Or if you mix different types as well, they may go off, and even block the pipes ... dismantle and clean it out should sort you ...
    North Wales
    Using.....wait for it.... TESCO OWN!!!!! Not being cheap, just found it works really well!!!! Any ideas on what ones to use??? How about scented ones???
    Regular Member R-man's Avatar
    Beds
    If it were me I would stick some neat solution in there, no water, that could break down whatever bad stuff is in there - and it'll smell ultra clean through your vents.
    Dec 2005
    In the sponge-monkey tent
    I find the pink ready mix from halfrauds works pretty good for me.
    North Wales
    Which neat stuff would you use???
    May 2006
    Cambridgeshire
    Vehicle : BMW 335D X-Drive
    Trim : M Sport
    Engine : 3Ltr Twin Turbo
    Year : 2016
    I had this problem on my last vec somebody had been mixing the washer fluid chemicals.
    Just drop some strerident tablets in your bottle, leave them to fizz away for a few minutes then empty the bottle and rinse out the remaining foam. ( I used the washer pump to empty my bottle ) I just removed the pipe where it connects to the bonnet and pumped the water straight onto the road.
    Refill and the problem should be gone.
    Beds
    I just mean that you can buy ready mixed, or neat. The neat stuff on it's own will be very strong solution, so should perhaps clear your pipes. During the summer months when I used to be permanently on the road i used neat anyway so's to get rid of the bugs.
    I also like halfords pink stuff, has a nice smell, and often on 2 for 1 ..
  1. Washer Jets
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2010, 17:20
  2. Washer jets
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 11:15
  3. Washer jets
    By DHobbs in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2010, 16:04
  4. washer jets
    By steve-wolves in forum Bodywork & Interior
    Last Post: 21st December 2009, 18:13
  5. Smelly washer bottle
    By kns in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2008, 10:40
