Results 1 to 10 of 26
Thread: Pioneer Install Problems
    Regular Member bluebirds1975's Avatar
    Wales
    Question Pioneer Install Problems
    I have just removed my CDR2005 and installed a facia surround and Pioneer DEH-P6900IB.
    I attached the ISO cable which came with the Pioneer but I cant seem to get any power to the head unit. Have I missed something as it seems just to be the 2 ISO connections.
    Checked the fuses and they are ok
    Anybody help?
    Dec 2005
    In the sponge-monkey tent
    Might be the red and yellow wires need swapping. Vx uses a slightly diff. wiring than other brands, so if the red and yellow wires are split and have connectors in, try swapping them around (ie. plug the yellow into the red and vice versa).
    Regular Member lochgilp's Avatar
    argyll
    you have to connect 2
    to the cig lighter aswell mate
    Wales
    Do I ?
    With what? and How?
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    is there a fuse in the back of the headunit, some headunit have a built in fuse (same sort as car fuses). dont know if u have checked that.
    argyll
    did u get the wiring loom and facia from v/hall ?there should be a brown and black wire that you have to connect to the cig lighter if my memory is correct
    Here, there and every where!
    Moved and merged the 2 threads you started m8
    Wales
    Apologies for the 2 threads!!
    Yes there is a 10amp fuse on the back of the stereo and is ok
    Yest I had a wiring loom from Vx with the facia surround. Would I bee better using this one than the pinoeer one?
    Have you traced the wiring through the plugs to see what is matching up on the facia loom that corresponds to the original wiring loom. It might be worth matching these up to see what is going where m8.
    Jul 2006
    Quote Originally Posted by lochgilp View Post
    No you don't. only if you decide you desperately want the ignition live. It works just fine without.
    My Pioneer HU only has the permanent live feed...but for some reason, this is by means of a yellow wire that doesn't go into the quadlock connector, just hangs loose. I had to split the casing on the live feed from the battery, and connect it behind the quadlock...if you see what I mean.
    No idea to this day why though
    Is that any use to you?
  1. Pioneer Headunit - Connection Problems
    By pshankland in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2012, 21:35
  2. Pioneer TS-Q172C Install Over Weekend.:)
    By paz_badboy4life in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2011, 09:27
  3. io play install problems
    By turbohaggis in forum Electrical & ICE (including SatNav)
    Last Post: 10th September 2009, 16:18
  4. Pioneer Install Questions
    By bennyk in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2007, 17:51
  5. Pioneer DEH P70BT Problems
    By Hendry in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2006, 18:12
