Results 1 to 10 of 11
Thread: Ever wondered how many miles the Vec 3.0 engine is good for?
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Default Ever wondered how many miles the Vec 3.0 engine is good for?
    52 plater Saab 9-5 here with 168k on!
    http://cgi.ebay.co.uk/saab-9-5-arc-2...QQcmdZViewItem
    Assuming it's still running sweetly!
    But yeah, no reason why those diesels (or any petrol for that matter) can't rack up that sort of mileage if well maintained.
    Regular Member addyboy1982's Avatar
    Northampton
    It's only a few months older than mine and I thought I was doing well at nearly 144k!
    I always thought diesels lasted longer than petrols as they burn an oil rather than a solvent type of fuel. Also the 6 pots have less stress then the 4 pots I would have thought
    Regular Member Paddy2bsure's Avatar
    Hertfordshire
    I have just come out of Saab 9-5 ownership, albeit a 9-5 2.0 LPT, but the 9-5 3.0 tiD has a TERRIBLE reputation amongst a lot of Saab OC members because of cylinder liners dropping - they're made of different material than the block, so after a bit of heating & contracting, they work their way loose & drop. Not really a maintenance issue, just a massive design flaw. No similar issues in the Vectra application of this engine I assume?
    By the way, such instances of the cylinder liners dropping occured anywhere between 25k miles & 80k miles.
    For this reason, most Saabers won't touch the 3.0!
    Regular Member VXR_DV's Avatar
    South Coast
    The liners didn't drop because they were made from a different material to the block, which is a very common configuration. They dropped because were made from a different material to the block AND because there was a design flaw in the way they were fixed in (not).
    dv.
    Regular Member simac's Avatar
    Wirral
    I'm sure the engine will do a good high mileage but I bet it's on about it's fourth set of rear shocks, 2nd gear box, at least one change of the wiper linkage and flywheel.. I daren't go on ! LOL
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    speaking to our saab techies the 3.0 diesel runs hot in the saab application but doesnt have the same problem in the vauxhall,we very rarley see any vauxhall 3,0 diesels apart from servicing so they seem to be reliable
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Quote Originally Posted by solorider View Post
    .....we very rarley see any vauxhall 3,0 diesels apart from servicing......
    But when you do see one you cant fix it as your not used to them going wrong! (like what happened to me!)
    Regular Member OilBurner's Avatar
    Feb 2006
    Bromsgrove
    IIRC the 3.0 V6 goes wrong in the 9-5 because of the smaller engine bay causing passive cooling issues with airflow etc.
    Believe it or not, the Vectra-C has a bigger engine bay. Probably down to the fact that the 9-5 is a cross between the old Saab 9000 and the Vectra-B.
  1. wondered how many V does my car have?
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2012, 23:44
  2. I wondered if anyone had seen this?
    By luke4487 in forum General Chat
    Last Post: 28th May 2010, 09:35
  3. vec c 2.2 engine 55,000 miles £350
    By matty123 in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2009, 19:05
  4. Ever wondered when you are going to die...?
    By Jim Bob in forum Comedy & Humour
    Last Post: 6th November 2007, 16:01
