Results 1 to 10 of 15
Thread: Wheel Bearing with VX?
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    Default Wheel Bearing with VX?
    Hi guys just noticed my front wheel is making a wine noise, so jacked it up and there a tiny bit of play in the front wheel so sounds like bearing on its way out, how much would VX charge to replace the bearing?
    it's just over a ton to buy.. add about 2.5 hrs to change...and you end up around 270 quid..
    Regular Member simac's Avatar
    Wirral
    are the rear bearings as expensive, I have a similar noise which seems to be coming from the back
    Regular Member robzc's Avatar
    Mar 2007
    South West
    Angry
    You have to buy the whole rear hub if I remember correctly, around £60 ea on e-bay.
    indeed, the bearings are now sealed hub units..and they are roughly the same price..if you buy from VX they're £100 each..
    Wirral
    S.Wales, Nr Swansea
    are the fronts sealed units too mate? if so il fit my self?
    yep, sealed unit..held on a yoke carrier by a ring of bolts...
    S.Wales, Nr Swansea
    nice one mate uve been most helpfull...again lol, you reckon it a hard job to do?
    hard.. no.. just wd40 the heck out of the mounting bolts 1st..it's actually easier to do than the old style of bearings that needed pressing in..don't forget to disconnect the ABS lead that comes out of the hub..and don't damage the new one, or it'll be another new hub unit..the ring of fixing bolts need torqueing up to 100nm, the main hub nut is 150nm, then release by 45 degrees, then tighten to 250nm..in other words F###ing tight..
  1. UJ or wheel bearing?
    By Endricks in forum Engine & Drivetrain
    Last Post: 8th April 2012, 10:49
  2. Wheel Bearing ?
    By jer75 in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2011, 02:01
  3. wheel bearing
    By stuart bigboy in forum Suspension, Wheels & Brakes
    Last Post: 28th October 2007, 17:07
  4. Wheel Bearing
    By suj786 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 22:05
