Thread: Clutch..............
    Regular Member HappyHarry's Avatar
    Wolstanton, Newcastle-under-lyme.
    Default Clutch..............
    Just a quick question - On a 2.0 DTi, can these be adjusted? TIA.
    Don't think so. Think all the Vec C clutches are hydraulic and non-adjustable.
    Ta for the quick reply - So, what can I expect to get from a clutch on one of these, with an average mix of driving? Anyone the wiser?
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    my old veccy B... 112k and still going strong... 2.2dti
    Regular Member Sundance's Avatar
    Scotland
    it all depends on how it is driven, did one last week that only got 30 miles!! (faulty friction plate). Done another with 7k on the clock. My mate had a fiesta with over 200k on it and all original parts!
    Scotland
    and no they cant be adjusted. If the pedal has a lot of free play you could try getting it bled though.........but be carefull cos you can knacker the seals in the slave cyl if you bleed it with the pedal, try using a pressure bleeder or a vacuum bleeder.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
