Thread: bump stops.....
    Feb 2007
    work
    Default bump stops.....
    ....after my ongoing problem with my new g-max springs (making a boinging noise when truning the wheel at low speeds) - i am going to try and grease up the bottom part of where the spring sits later.
    someone else suggested it may be the "bump stops" - i have no odea what this means but he said you can try to shorten them? can anyone enlighten me and let me know if this may be whats casuing the noise??
    thank u
    SOMERSET
    I thought bumps stops are surposed to stop the car from bottoming out ie if it has 20 people inside the bump stops will work and stop the shock and spring going all the way down(travel).
    As for creaking, i think there is a upgrade kit that sits on the top mounts because i have the same noise and its always done it , GSI3.2 knows all about it.
    Feb 2007
    work
    thanx mate - yeah its basically making a boinging noise when i'm parking up and turning the wheel - very noticeable - but when driving and cornering its fine, no noises at all....very confused by it all....
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    If the spring is going 'boing' when lock is applied it normally means the spring is being wound up then releasing,try watching the spring as some else parks the car (don't get run over please!).I've never seen a vec spring off,but not taking the pee,are they fitted the right way?.
    Feb 2007
    work
    Quote Originally Posted by tyreman View Post
    they were fitted at a garage and apparently there is only 1 way they fit on so im guessing thy are mate.......
    yep, there iis only 1 way up to fit them, as they have a flat top land to sit under the top bearing..and a obvious tail to sit in the spring pan...
    the bump stops are located on the main damper shaft..if they are bottoming out it means the springs are too weak, and you need higher rated ones..
    Dec 2005
    In the sponge-monkey tent
    It does sound like the end of the spring is catching on something as you're turning the steering then releasing. Could the pan they sit on have an 'edge' they catch on? Does it only happen when you turn the steering one way? Sounds a bit wierd to me.
    Feb 2007
    work
    right i took it to a garage tonight and he's jet sprayed all the sh*t out of the "seats" - plus greased up the bottom of the pan - we took it 4 a drive and it seemed MUCH better - one did the BOING noise once....but not heard it since......am off to birmingham tomorrow so will report back when i'm home on friday - fingers and toes crossed!
    thanx for all the help guys !!
  1. Z30DT stops
    By Johnny-B in forum Y & Z30DT Specific
    Last Post: 9th August 2012, 15:14
  2. car just stops???
    By kiwiboy in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 09:18
  3. Bump Stops - Help
    By Ian S100 in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2010, 20:15
  4. 1.8 low power, stops when hot
    By gassy in forum Engine & Drivetrain
    Last Post: 27th May 2007, 19:06
