I had this in my Coupe but have never got around to putting it in the MG - so decided I may as well sell it as it's unlikely that I will install it.
In addition to the subwoofer is a brand new installation kit containing all the wires you need (power, speaker wire), I may even have the original box for the sub!
£95 ono
Subwoofer spec -
# 10" subwoofer and 10" passive radiator with built-in amp
# Dimensions (H x W x D): 14-1/2" x 12-1/2" x 8"
# Power Output: 200W
# Frequency Response (±3dB): 20Hz - 100Hz
# Variable Bass EQ: +3dB to -6dB at 45Hz
# Variable Electronic Crossover: 70Hz - 100Hz
# BassLink can be mounted vertically or horizontally using its unique mounting system.
# BassLink provides user-adjustable input sensitivity, crossover frequency and bass-boost. This allows BassLink's performance to be optimized for any installation.
# Four low-level inputs provide nonfading bass.
# High-level inputs allow interface with most factory systems.
# 200-Watt Class-D amplification.
# Rigid-polymer chassis withstands the rigors of the road.
