Results 1 to 10 of 20
Thread: whining/ticking in the ICE install!!
    Regular Member nickybvaux's Avatar
    lincs
    Default whining/ticking in the ICE install!!
    hi there! this is my first time owning a vectra c and now i have fitted my ice into it i'm picking up bad singnals of whining and ticking through the amps! as anyone else have this prob through a vec-C????
    Regular Member rosssri's Avatar
    S.Lanarkshire
    Sounds like you'll maybe need a supressor fitted to your live feed .
    lincs
    i've heard lots about suppressor but which one as i've now found theres many types around! you say on live feed, where does that go?
    S.Lanarkshire
    I'm not to sure but at a guess i'd say on the power live feed into your amps it'll either be there or on the back of your stereo on existing wiring, you'd maybe be better talking to an auto electrician for some free advice.As these are the only 2 points the power is going in.
    member of the smoke patrol 230bhp+
    are the amps eathed at the same place
    and where
    list what you have in the car to and where its fitted
    lincs
    many electrical minded peolpe have had a listen and it is puzzleing them as that noise isn't normaly connected thro live feeds! i'm under going many tests to rule things out, just wondered if anyone has had simular probs?
    but as always, probley just me again!LOL
    Regular Member dervdoc's Avatar
    Co.Armagh
    are the power leads and rca leads run down the same side of the car
    lincs
    i have 4 earths and in two diff points in floor of boot! live leads one side of car and remote and rca's the other! i have had diff rca running over seats to rule them out from interferience but no difference! 0 gauge and 4 gauge running passanger side with left speakers but people say noise is to much for speaker wires to pulse thro! earth is my next job to rule out when i try under rear seat belt points!
    Co.Armagh
    usually if the power and rca leads are close it can cause interferance but if its not that try changing the rca leads the other way round going into the amp
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Check all your ground points first. Then look at getting a suppressor.
    Make sure that there is no paint under your ground points also.
    Are you running high outputs from the head unit or RCA?
  1. HELP! whining from the front
    By Ann in forum Suspension, Wheels & Brakes
    Last Post: 17th February 2013, 16:32
  2. whining egr
    By donut in forum Troubleshooting
    Last Post: 14th January 2011, 11:56
  3. whining noise (HELP)!!!!
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 20th March 2009, 09:03
  4. Steering whining!
    By Merick in forum Handling & Braking
    Last Post: 27th August 2008, 18:40
  5. Whining Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 13th May 2007, 01:13
