Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Turbo Lag
    Regular Member installer's Avatar
    Nottingham
    Default Turbo Lag
    This has been mentioned a little before this but only in threads not a thread on it.
    I`ve had my 1.9 CDTi (150) Estate for 18 months and still can`t get over how dead it is below 1800ish rpm until turbo kicks in.
    I am correct that everyone elses is the same?
    Is the cure a remap @ VXR or Courtenay for example.
    If you don`t bring the revs up you`d get killed at some point I`m sure - which until I got used to it happend a few times.Me screaming "come on" then 1800ish rpm and phew what a relief.
    So a fair statement is that the 1.9 CDTi needs keeping on the boil so to speak?
    Any views or thoughts on this.
    member of the smoke patrol 230bhp+
    thats just what a turbo is like
    if you had a smaller turbo this wouldnt happen as it would spin up faster but with a smaller turbo come less power.
    a smaller turbo would make it pull like a train upto about 2500 rpm then its all gone its just a trade off .
    this is why company are playing around with 2 turbo's
    1 small turbo to work at low presser and to pull low down then the larger turbo come in to do the rest.
    id think vauxhall where doing one a bi-turbo 1.9 cdti engine soon im shore there is a link on the site somwhere about the vectra with the new engine .
    to solve all the lag from a tubro jag go a diffrent way and bolt a supercharge to there engines
    no lag at all but this takes power to run them
    Regular Member amos's Avatar
    s,wales
    I had the same with mine, I put K&N on made it better and then tuning box runs like dream from low down revs and increase economy.
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Hi, mine had a small amount of lag below 1800 rpm but i improved it greatly when i dropped a K&N filter in and did the box mod ! one thing i did do which in my experience didn't help, was to disconnect the battery leads ! this made the lag reappear. Once the K&N was fitted it took about three days for the ecu to adapt. cheers Kcs
    Nottingham
    Another way of expressing the question is -
    is the lag a characteristic of the CDTi
    Nottingham
    Quote Originally Posted by amos View Post
    Quote Originally Posted by Kcs View Post
    Did the airbox mod when first got it in 2005.(However have got new airbox lid as I had originaly removed the trumpet that goes on the the MAF sensor.)
    Took my K/N out as the MAF was getting coverd in filter oil and the numerous storys of excees oil damaging MAF sensors.So I now replace my standard filter every 6 months.
    Think remap is far better than box for long term reliabilty as plan to keep it a while (or can`t afford to replace it)
    Feb 2007
    Tamworth
    I think it is on most diesels, but manufacturers will be using two turbo's on most cars soon.
    Feb 2007
    Tamworth
    Yes the oil can be a prob, got the hair dryer on mine first !
    Feb 2007
    Tamworth
    They don't tend to be too bad from K&N, its when people re charge them, they put too much oil on !
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
  3. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
  4. Turbo Help
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 12th February 2010, 11:42
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
