Thread: Burning smell / overheating
    Regular Member andymcniven's Avatar
    newcastle upon tyne
    Unhappy Burning smell / overheating
    Was just about to go to work tonight when driving down the road i got a strong burning smell a loud whiring noise (like another turbo) and my car majorly overheated.
    Pulled over popped bonnet and no smoke or nowt.
    Loosened coolant cap halfway to release pressure and watched my coolant all vanish ......
    Then it bubbled back up ????
    Smell seems to be coming from timing cover which was very hot ???
    Also forgot to say heaters in car were blowing cold dispite temp gauge reading nearly 100 ???
    Car has now done 81 k so is way way out a warranty !
    Any help appreciated !!
    it sounds like you've got a water circulaition issue.. like a failed water pump..it's boiled up, but if the heater is cold then all you are getting is the engine heating the water, but not moving it round...
    prepare for a wallet beating and get the engine looked at with a veiw to a failed waterpump..if you're lucky it will escape needing a headgasket as well..
    newcastle upon tyne
    Cheers Gsi,
    Looks like ya right just had my mechanic on says water pump has seized causing tensioner to fail and belt started to come of rubbing against timing casing giving burning smell .
    He says head gasket seems ok but need new belt rollers and water pump.
    Reckons if a had drove another hundred yards a would have needed a new engine !!!!!!
    Quite lucky then really !
    Any one else had this trouble ?
    Thanks mate
    Andy
    i only know of one car, but that never boiled up and was fixed under warranty..
    yo've had an expensive, but lucky escape there mate..
    DERRY
    my car has been overheating on long journeys if i go over 60...
    was told to change the thermostate.... but it hasnt helped... the coolant light is now on today...
    do u think the coolant has been low all along ? if i top up the coolant should this sort the problem ?
    is the coolant actually low.. it should sit level with the mouldline on the tank..
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Quote Originally Posted by andymcniven View Post
    Cheers Gsi,
    Thanks mate
    Andy
    Think this is the problem ive had, timing belt has been rubbing against the casing & coolent is pouring out the bottom (guess from the water pump). I had smoke too though so not sure what other damage has been done
  1. Burning Smell
    By Tam80 in forum Engine & Drivetrain
    Last Post: 13th April 2011, 11:36
  2. burning smell
    By mace in forum Engine & Drivetrain
    Last Post: 7th December 2010, 21:47
  3. burning smell!
    By MARK RC in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2010, 19:13
  4. burning smell
    By tony stoney in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2010, 19:23
  5. Hmm What's that burning smell?
    By Stevel in forum The 'Off Topic' room
    Last Post: 9th March 2009, 21:22
