Thanks Thanks:  1
Likes Likes:  1
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Dash Camera Wiring?
    Regular Member Keif's Avatar
    In the Garage
    Default Dash Camera Wiring?
    How have you done yours?
    My Mini 0801 dash Camera arrived this morning.
    It's come with the USB to Mini USB cable and a "Cig Lighter" to Mini USB cable.
    I want to Hard Wire it into the car and have a permanent cable up the A-Pillar into the roof lining (i.e. NOT use the aux socket).
    My first thoughts were to replace the Cig Lighter casing to a box and run a fused Ign feed to the PCB. Should be easy enough with a “project box” from Maplins. etc
    How have you wired your Dash Cams up? Is there naything "off the shelf".
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Cut into the cig lighter wiring as it is a switched live, wire in a secondary cig lighter socket that you can hide under the dash, run your wire from that, up the dash, behind the glovebox, up the A-pillar and across the roof, plug in at both ends. Done.
    Jun 2012
    North Shields
    In the Garage
    Quote Originally Posted by jackied247 View Post
    That's looking a better idea, is the box to USB cable long enough though?
    Or does the box live at the top of the A-pillar?
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    I wired mine to the live feed in the courtesy light and run the cable out of the front of the headlining at the windscreen.
    In the Garage
    Quote Originally Posted by ghostrider View Post
    Using the above ebay wiring?
    Jun 2012
    North Shields
    Quote Originally Posted by Keif View Post
    havent fitted one myself mate,just something i was thinking of doing as my original charger stopped working @ghostriders idea sounds pretty good though.
    On another planet
    Engine : 2.0
    No - The camera setup i have is 12V, so no need for any voltage convertors, but if you need one then that will work. So long as you arn't going to be pulling > 1 amp from the wiring you'll be fine. I also replaced my courtesy lights with LEDs to reduce the load. I have a bullet camera with RF transmitter wired to it in the front courtesy light feed and a camera in the rear with 2 separate DVRs recording all the time in the car.
    If you have a look there's a few pictures of my setup on here somewhere.
    Regular Member any-mgzt's Avatar
    cheshire
    9 Post(s)
    Trim : basic
    Engine : Z19DT
    I have one of those great CAM good quality video
    In the Garage
    I take it you're running a permanent live then as I have no Ign feed in my roof light.
    Quote Originally Posted by any-mgzt View Post
    Yep, had a play and i'm really impressed with it.
  1. reversing camera wiring - vectra c 05 plate
    By jakemuk in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2016, 20:25
  2. Wiring - Dash loom/cables behind whole Dash
    By Dane-10 in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2013, 10:49
  3. dash board camera
    By skidmark1 in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2012, 19:30
  4. Reversing camera wiring help
    By wayne10244 in forum Electrical & ICE (including SatNav)
    Last Post: 19th August 2011, 17:45
  5. Reversing CAMERA -Wiring to Light help Needed
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2010, 08:22
https:www.vectra-c.comforumshowthread.php200574-Dash-Camera-Wiring&goto=newpost
hardwire fit to dash cam for vauxhall insignia
fitting nextbase hardwire kit to vectra c
fitting nextbase to opel vectra c
How to hardwired dashcam in insignia
lhard wire vectra c
insignia dash cam ground point
vectra c hardwire dashcam
Nextbase hardwire Vauxhall insignia
hardwire dash cam zafira gsi
fit reversing camera to vectra dashboard
dashcam hard wire vectra c
bast way to fit a dashcam hardwire to a vauxhall insignia
hardwire dash opel signum
