Results 1 to 10 of 11
Thread: mot failure?
    Regular Member leeandjude's Avatar
    Feb 2007
    boldon, sunderland
    Default mot failure?
    can someone tell me if its a requirement of the mot test to have a spare wheel in the car? i have plans for an ice install..
    if you do have to have it i could always throw it in the car then!
    it is not a requirement at all.. if it's fitted it has to be legal, but if it's not there it's not an issue
    Regular Member Paddy2bsure's Avatar
    Hertfordshire
    No specific requirement for a spare wheel - more & more cars don't have them - Porsche Boxter for example. Think of all the folk that do a LPG conversion with one of those donut tanks that sits in the spare wheel well.
    Carry a can of tyre weld tho' - and your AA card
    Nr Cardiff
    Interestingly enough, if you remove your rear seatbelts and buckles, spare wheel and rear wiper it will pass!
    Ashington, Northumberland
    Quote Originally Posted by Triple Trouble View Post
    Even more interestingly, if you remove the windscreen completely it will pass. (However, under construction and use regulations our friend Paul (MLC) would like a little word with you as you tootle along the M1 with the wind in your hair)
    Rear wiper and spare wheel are not testable items anyway.
    Jul 2006
    Quote Originally Posted by GARY3306 View Post
    I agree with GSi3.2 - I thought if it was there, it had to be legal, but if it was missing, there was no problem.
    Good job really, as apparently the spare wheel well in the estate won't take an 18" or 19" wheel....is that really true?
    Sorry....
    Quote Originally Posted by parapaul View Post
    Sorry....
    The condition of the spare tyre is not a testable issue. An mot tester will not even look at a spare wheel. Under construction and use regulations if a spare wheel is carried it must be legal, but for the MOT, not required. In fact if you presented a vehicle for test and the spare wheel was right down to the cords, the tester wouldn't bat an eyelid, it ain't testable.(well not strictly true cos I would advise on it)
    It won't even take a full-size 17" wheel. It's the width that it won't take as the well is shallower than in the Vec C (due to the level load space of the estate). Same with the Signum - so we're stuck with the crappy spacesavers!
    The VXR doesn`t come with a spare, just a can of foam and a pump ... I have put a 19" wheel with a 235/35 in there so fits in the hatch hole, though the carpet doesn`t lie completely flat now, but not an issue and it will settle a bit i think ...
    Regular Member benny's Avatar
    Feb 2006
    dudley
    Quote Originally Posted by Paddy2bsure View Post
    as far as i can tell most new vauxhalls are comeing with a bottle of tyre weld or a pump in the boot now bad news makeing the spare a option had a brand new zafira bought back by the owner had to explain his brand new10k car dont come with a spare ..and if he wanted one he had to buy the rim tyre and fitting kit for under the rear of his zafira ...he wore a happy bunny .....
  1. Mot failure
    By tangoman in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2012, 20:59
  2. DMF failure!
    By lofty in forum Engine & Drivetrain
    Last Post: 23rd February 2012, 11:30
  3. MOT Failure or Not?
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 14:50
  4. is it mot failure
    By the fisherman in forum Styling
    Last Post: 12th May 2009, 16:25
  5. DMF Failure
    By iainm in forum Engine & Drivetrain
    Last Post: 21st January 2009, 12:44
