Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: glow plugs
    Jan 2007
    rossendale
    Angry glow plugs
    hi lads,and girls i hope somebody will rply cos no one has to my last 4 probs but any way my vectra b was a bit **** at starting so i replaced the glowplugs and now i have no live going to the (starter rail) do you no how to solive it? witch relay do i have to check? it starts first time if i put the ignition on and (manually put a piece of wire running from rail to live on battery) but as you can see this is not a good look and is really ****ing me off, if you no witch relay or fuse it is i have to replace/look at i will be gratefull, it will save me taking it to a autoelc and costing me an arm and a leg THANKS AND PLS HELP
    Regular Member benny's Avatar
    Feb 2006
    dudley
    how do you mean mate there is no live feed to the glow plugs when you turn the ignition on...?
    Technical directors office
    I think he's saying that the Glowplug relay is U/S benny, hence, if he bridges out the battery to the glowplug power rail it will glow the plugs and start really easily..
    i'll stratch my head for a while and have a brew.. maybe it's location will come back to me...it is definatly under the bonnet thou..
    Jan 2007
    rossendale
    Default glow plugs 2
    cheers lads for rply cdti have you had your brew yet???????? ive looked again in haynes man but it doesnt tell you witch realy it is going to be, ill wait for your ideas, because ive run out of them.
    Jan 2007
    rossendale
    bennie its like gsi 3.2 said if i turn on the key its not sending a live to the glow plug rail hence no heat to glow the plugs but if i run a piece of wire from rail to live termnal its ok and warms the glow plugs and starts, ???????????????
    Regular Member robzc's Avatar
    Mar 2007
    South West
    confused
    I don't know the actual engine setup that well, but the glow plugs should warm up for x amount of time from when you turn the ignition on, they will stay on longer if the engine is colder, so obviously there is some kind of measurement circuit that powers the glow plugs for a time proportional to the temperature of the engine.
    Obviously this circuit isn't working, so the fault may actually lie in a sensor that is reporting that the engine is already warm when it isn't - on a warm engine, the glow plugs don't activate at all.
    Sorry I can't help any more than this, just that the fault is not necessarily on the actual glow plug circuit but with whatever activates this circuit.
    Jan 2007
    rossendale
    cheers robz for reply ut im still no closer to finding the falt but ill keep looking thanks pal
    Jan 2007
    morton
    do they heat up every time you start the car though ? i've been told they dont ! is this correct ?
    They don't have to, no.. it's all down to if the ECU says it needs to..
    but if it won't start without glowing, it obviously needs to..
    Administrator plasma's Avatar
    Mar 2006
    On the Forum
    572 Post(s)
    Engine : 150
    Year : 05
    Mileage : 74000
    Check F28 should be 20A this is the fuse for the glow plugs
    if no good i'll chk for more ideas..
    2.0dti or 2.2dti??
  1. Glow plugs?
    By SEANYboi in forum Engine & Drivetrain
    Last Post: 11th February 2013, 10:00
  2. Which glow plugs for 1.9 150?
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2011, 12:01
  3. Glow Plugs
    By RobW in forum Engine & Drivetrain
    Last Post: 18th March 2011, 20:05
  4. Glow plugs
    By danny1992 in forum Engine & Drivetrain
    Last Post: 9th September 2010, 11:52
  5. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
