Results 1 to 10 of 11
Thread: getting springs fitted tomorrow...
    Feb 2007
    work
    Default getting springs fitted tomorrow...
    .....ive bought some springs from a member here.
    however he told me that when he fitted them to his vec originally they made a banging noise....so he was told by G-max to take the "spring mod" off which is the small rubber sleeve on the bottom coil.
    i am fitting these to my car tomorrow but when i told my mate at the garage he said this spring mod usually STOPS the banging....any1 got any advise...leave it on or take it off?
    thanx!
    Regular Member Spikeyİ's Avatar
    Dec 2005
    In the sponge-monkey tent
    Leave it on, might be that his shocks weren't up to the job. Did they come off an Sri or 'comfort' model? 'Standard' shocks on an LS or other non-sports model may not have been uprated enough to handle shorter/harder springs. Sri ones should be ok as long as the drop isn't rediculous.
    Feb 2007
    work
    its a 40mm drop - they came from woodysri on here - he has the dti sri.....strange...not sure what to do!!!!
    leave it on.. it will do no harm whatsoever..
    Dec 2005
    Is that 40mm over standard ride height or 40mm over Sri height? Bear in mind the Sri is already 15mm lower than standard. If it's 40mm over Sri ride height, you may well need uprated shocks.
    Also check the ends of the springs to make sure there's no ends broken off.
    Feb 2007
    work
    cheers guys - i'll tell him to leave it on then and just see how it goes. are these spring mods on every spring.
    how can you see if the ends have snapped - is it obvious?
    compare them to each other and if one is shorter..
    the spring mods should only be fitted to the fronts, the rears don't need them as they sit on 2 rubber mounts.Depending on the car it may or may not have them fitted already
    Feb 2007
    work
    ok cheers - a bit confused but i will replay you guys' advise to the fitter tomorrow and see what he thinks
    Feb 2007
    work
    right checked springs - dont seem snapped at all luckily. however the rear ones seem shorter than the fronts, or at least the seem more"compressed" - is that normal?
    Regular Member selv1980's Avatar
    warwickshire
    where can you get the spring mod from
  1. Coilovers fitted tomorrow :-)
    By Deano2.2SRi in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2012, 20:13
  2. just fitted new springs
    By melvyn8181 in forum Suspension, Wheels & Brakes
    Last Post: 22nd November 2011, 22:45
  3. New manifold fitted tomorrow.
    By badback in forum Engine & Drivetrain
    Last Post: 6th February 2011, 17:17
  4. My springs are fitted
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2010, 16:54
  5. Hopefully getting my proper springs back tomorrow
    By cheekylemon in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2009, 17:17
