Results 1 to 10 of 15
Thread: Z18XER 6 speed gearbox
    Nov 2013
    Mors, Denmark
    Vehicle : Caravan
    Trim : Standart
    Engine : 1.8 16v Z18XER
    Default Z18XER 6 speed gearbox
    Can I build a 6 speed gearbox in my vectra c with a Z18XER engine.
    if yes.
    what do I need.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Trim : ES,Panoramic Roof and Power Mirrors
    Engine : 1.8 iVtec
    Mileage : 67500
    Its never been done, its been talked about, well not that ive seen on the site. The Insignia 1.8 has a 6 speed box, so it should technically be doable as its the same engine.
    Barrow In Furness, Cumbria
    Don't think the 1.8 has enough torque to make proper use of a 6th gear to be honest.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 67500
    Quite possibly as even the diesel guys notice they can get better mpg by leaving it in 5th. A 6th gear would most likely just leave the engine labouring. @Mark Evison
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    6th gear makes the car struggle in my insignia i get better mpg in 5th, i only put it in 6th on the motorway on a long run
    Nov 2013
    Mors, Denmark
    Vehicle : Caravan
    Trim : Standart
    When I drive 100 km / h in Denmark "about 60mph" in fifth gear.
    Seems I the car is very noisy and I need a gear more ..
    Think I will have great benefit of a 6 speed gear box on the motorway..
    We have a speed limit of 80mph on motorway..
    My tires are 205/55-16
    Dec 2011
    Seaham
    @ Kent A, to increase the gearing on your car, fit some larger rolling radius tyres.
    Nov 2013
    Mors, Denmark
    Vehicle : Caravan
    Trim : Standart
    My summer tires are 225/45-17.
    Dec 2011
    Seaham
    Here is a tyre comparrison calculator
    http://www.kouki.co.uk/utilities/vis...ize-calculator
    My car originally had 215/55/16 and I have fitted 235/45/17 as they have almost identical rolling radius.
    To increase the gearing you can try a larger rolling radius tyre, however, it will affect your speedo reading, unless the tyres are within those specified by Vauxhall.
    Oct 2009
    Aberdeenshire
    The forbidden software can program a custom rolling radius for the speedo, but if your after the ultimate in MPG then fit good quality tires that are designed to save fuel with low rolling resistance, alter driving style etc, the 1.8 just doesn't have the torque to pull a 6th gear
  1. 1.8 VVT z18xer manual Gearbox Oil change
    By smoggie in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2013, 19:27
  2. 1.8 VVT z18xer gearbox oil capacity??
    Last Post: 18th August 2013, 11:17
  3. 5-speed gearbox on 6-speed z22yh
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 09:06
  4. Vectra C Z18XER Gearbox Probelms!
    By demoni in forum Engine & Drivetrain
    Last Post: 10th February 2011, 01:09
  5. 5 speed / 6 speed gearbox difference?
    By electron in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 21:27
increase mpg on Vectra c
m32 gearbox conversion for astra h 1.8vvt
vectra 1.8vvt 6 speed gearbox
what gearbox goes with the a18xer
1.8 vvt insignia 6 spd
vectra vvt 1.8 gearbox site:www.vectra-c.com
z18xer 6 speed gearbox
vauxhall 1.8 6 speed gearbox
vectra c 1.8 m32 6 speed gearbox
capacity gear box opel vectra c 1.8
vectra c 1.8vvt z18xer clunky gearbox
x18xer with m32 gearbox
