Thread: Vacuum solenoid valve
    Mileage : 000
    Default Vacuum solenoid valve
    Does anyone know where the Vacuum solenoid valve is situated on the 2.2dti. a mate at work has one and it is showing a fault code for it having a too high voltage, when the ecu light comes on the car goes into limp mode, the fault is a bit intermitent, but changeing the valve will eliminate the fault I think.
    Admin plasma's Avatar
    On the Forum
    287 Post(s)
    Engine : 150
    Mileage : 74000
    hey Ed, I have this problem on my 2.2dti too. but on my Veccy B. AFAIK its on the right hand side of the engine. You'll be able to see the vacuum hoses coming off of it. Gonna consult Haynes about it or wait for Mark to pipe up about it lol.
    Cant see anything about a solenoid valve though Ed,
    ed... there are 4 solenoid valves on the vec C dti..
    charge pressure control solenoid valve
    solenoid valve for turbo charger reservoir
    switchover valve solenoid valve
    switchover valves vacumn unit
    any idea which one?
    if it's the last one..it's under the front acoustic sheild..at about 2 oclock to the oil filter...
    if it's the intake plenubm switchover valve, it's on the front slam panel, by the clamp for the bonnet pull cable..
    if it's the vacumn control valve then it's..attached to the side of the battery box. look at the lower part of the cutout in the lower battery box and you'll see it with 2 vacumn lines and an electrical plug
    Mileage : 000
    I have asked my mate for the code but he can not remember it, but I will pass on the information to him. Cheers Mark.
  1. Throttle valve solenoid question!!
    By the_riddler in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:20
  2. Replies: 11
    Last Post: 26th June 2011, 19:29
  3. EGR Valve-hole in solenoid side
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2009, 10:08
  4. solenoid vacuum switchover valves
    By andy8966 in forum Engine & Drivetrain
    Last Post: 8th October 2007, 00:41
