Thread: DTi oil level checking?
    Regular Member Vectra_Power's Avatar
    York
    Smile DTi oil level checking?
    I have a 2002 Vec C 2.0 DTI and have tried checking the engine oil level recently.
    I have tried it on a warm engine, a hot engine and a stone cold engine - but each time the dip stick, no matter how clean it is when I poke it in, comes out completely black!! No way can I check the level!
    I have never had this, am I missing something??!
    Cheers!
    Regular Member OilBurner's Avatar
    Feb 2006
    Bromsgrove
    The proper procedure is to check with the engine warm, 5 minutes after turning the engine off. Always do it on a level surface too.
    The oil will be very black, even if recently serviced. As long as the mark is between top and bottom and isn't going down quick, you're fine.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    how long ago was it since you changed the oil. I would add some engine flush and then drain out the old oil and start again. At least that way you know where your up to.
    I have a 2.2dti and it dosn`t blacken the dipstick, but i do change the oil every 5000 miles.
    You don`t say how many miles the car has done. I just think it needs a good flush.
    York
    Cheers guys
    I bought the car about 4 months ago with 101,500 on the clock and it now has 106k on it.
    When I poke the dipstick in clean, it comes out black for the bottom 3-4 inches, hence why I can't read the scale.
    The reason I'm checking this is that the low oil warning light came on last week, checked it immediately and had the above problem. I poured a small amount in and the warning went off.
    I think I best do a flush and oil change.
    Silly question - can I pour the flush in myself and the take the car to get the oil change done shortly afterwards? I'm thinking Kwik-Fit!
    Cheers,
    Chris
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    Quote Originally Posted by Vectra_Power View Post
    Cheers guys
    Cheers,
    Chris
    you want to trust kwik fit?i wouldnt let one of their fitters any where near my car,you need to make sure you get the correct oil and i doubt they would use the right stuff,also you shouldnt drive with a flush in and all diesel oils will get very black very quickly
    York
    I just phoned them and they said flush was a bad idea and 'not recommended'. They also said that with the warning on the dash, the engine would have had 'way less than a litre left' and would be 'badly damaged'. That didn't sound good.
    Going to phone around for more quotes for the oilchange, they quoted £24 for the oil and filter.
    Cheers,
    Nicking Ya Dinner.
    Cheers,
    That is correct, flush should only be used in engines that have always been flushed, doing it in an engine with 100k on it will result in lots of muck being moved and usually it doesn't come out of the drain hole, and can settle in other places that then cause other problems.
    Also the oil reading should be done cold, it takes a while for the oil to drain back to the sump on these engines, and if not careful you can think you are low on oil and overfill it, resulting in blown seals.
    Feb 2006
    Bromsgrove
    Quote Originally Posted by VauxVeteran View Post
    The manual states that it should be done warm, but with 5 minutes wait to allow the oil to settle back in the sump.
    Always worked for me on both 2.0 DTI and 1.9 CDTI.
    If you don't wait long enough the oil level looks too high.
    I have to admit though, I would have thought a cold reading should give an accurate result, but the Vauxhall instructions are quite specific, even marked under the bonnet IIRC.
    Feb 2006
    Bromsgrove
    I quote from my PDF copy of the March 2003 manual:
    "The oil level must be checked with the vehicle horizontal and with the engine (which must be at operating temperature) switched off. Wait at least five minutes before checking the level to allow the normal oil accumulation in the engine to drain back into the oil pan."
    pp. 264
    No idea why it has to be warm though.
    Feb 2006
    Guttedsville
    This is strange. Every engine on every vehicle I've ever driven (and there's been a few!) needs to be on level ground, with a cold engine.
    My DTi hasn't used any oil all the time I've had it. Not even when the Turbo was playing silly bu99ers.
  1. Checking in...
    By Pops82 in forum Introduce yourself.
    Last Post: 18th February 2013, 20:49
  2. just checking
    By tosh23 in forum Introduce yourself.
    Last Post: 24th October 2012, 18:15
  3. Gearbox oil level.does it need checking ?
    By Dobs in forum Engine & Drivetrain
    Last Post: 14th February 2012, 20:53
  4. Checking oil
    By gdansk in forum General Chat
    Last Post: 7th December 2009, 19:09
  5. Checking oil level : When to do?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2009, 14:19
dti oil level check
vectra dti oil level check
cant get an accurate oil level reading vauxhall vectra 2005 1.9 cdti
cant get acurate oil level reading vectra 1.9
2.2 dti oil level high
check oil on dipstick vauxhall vivaro dti 2003
vectra c dti oil level
vivaro dti oil
opel vectra c oil level check
2.0dti oil level lamp
which is correct mark for full on vectra c oil dip stick
