Results 1 to 10 of 14
Thread: Stiff gear changes
Hybrid View
    Bonnie Scotland
    Default Stiff gear changes
    Guys
    When the car is cold the gear change from 1st to 2nd is very stiff and when warmed up is notchy from 2nd to 3rd and sometime 3rd to 4th. I have read the following thread and was wondering if the F23 transmission was what I had on my 04 3.0V6 CDTi 6-speed box http://forum.vectra-c.com/showthread...t=Field+Remedy Do any of you guys with a V6 have the same problems?? My warranty is up on the 10th March and I want to get looked at before then if I need to. Any info or comments would be greatly received.
    James
    Bonnie Scotland
    I'm unable to access the thread. Do a search and its under "Stiff gearchange"
    Sweden
    Should be the F40 gearbox.
    The same as in the 2.0T and some Saabs and Fiat & Alfa ....
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    I have read an interesting article about approaching the end of your warranty. It recommends having your car checked over by one of these AA/RAC type engineers as you would if you were buying the car. You then go to the stealers with the engineers report and get them to repair what is wrong b4 the warranty expires. The article says that in 90% of cases the engineers examination will more than pay for itself. Worth thinkng about.
    Jan 2007
    morton
    top idea ! everybody take note !!
    Regular Member Harry's Avatar
    Uxbridge, London
    James, my v6 diesel is the same, sometimes i worry about it as it needs very careful driving until the juices get flowing, often get a little crunching too when i go from first to second when its cold unless i let the revs drops right down to idle when changing up.
    might have mine checked out aswell.
    Quote Originally Posted by James7 View Post
    As Techwolf said, it's the F40 in the 3.0V6 but not exactly the same one as in the 2.0T. The 2.0T is the close ration version.
    A number of people of people have had problems with stiff changes with this box and, if I recall, Ian C had his gearbox changed eventually (he has the same engine).
    Do a bit of a search/browse and you should find more details.
    I'd say it's definitely a trip to the dealer to give them some pressure to sort it out before the warranty runs out.
    Regular Member Silentknight's Avatar
    Swindon
    Angry stiff gear bo
    I have 2.2 sri petrol, same problem stiff changing between first & second. It seems to knock aswell.!! Took it back to dealer they said that its acceptable for age of car (Reg. Jan 04) but they lubricated the linkage for me and said this should help.
    Do I have the same gear box? and was i fed a load of s**t!!
    Thanks lads!!
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Mine is just comming up to 7k, 1st & 2nd is a real dog at times, more so when cold ! i did think it was because it was new, but i think they are all the same !
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Quote Originally Posted by Kcs View Post
    My CDTi is the same 1st to 2nd always grates - It's not stiff just very notchy particularly when its cold. 2nd - 3rd is a little notchy but more than acceptable - It's certainly not the Synchro's because it's fine coming down the box - double declutching helps!!
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Stiff Gear Change
    By John Bishop in forum Engine & Drivetrain
    Last Post: 1st June 2012, 16:43
  3. Stiff Gear Change
    By sheddy in forum Engine & Drivetrain
    Last Post: 24th February 2012, 12:07
  4. vectra 2.0 turbo stiff gear help
    By matrix1979 in forum Engine & Drivetrain
    Last Post: 21st September 2011, 21:19
  5. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
z22se stiff gear
