Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Dti cold start problems
    Regular Member storey_3000's Avatar
    May 2006
    somerset
    Thumbs down Dti cold start problems
    hello peeps, as above really, my 2.0 dti has developed a cold start problem. It will turn over without heating, but is really lumpy for a second or two then quits. another try with abit of pump on thr throttle usually gets it started with a massive cloud of black smoke. I was wondering if it was a number of problems including;-Glow plugs (but it doesn't always need heat due to outside temp)-Air in the fuel lines (A problem on vec B's i think/no major leaks visable from injectors or return pipes)-Poor fuel (i'm guilty of filling my last 2 tanks at morrisons, and the problem has arrose!)Hopefully its just ****e diesel from morrisons , but is poor starting a common problem on the dti? Thanks for reading!
    it sounds like it still needs/wants to glow...so if you've done a round/over 50,000 miles, i'd change the glowplugs and check the 12V feed to them..
    if you think it's poor diesel , have yoy tried the fuel fiter to see if there's water in the fuel..try a drain of it to see..However bad fuel would cause bad running all the time.. this is deffo a glowplug/coldstart issue..did it glow in the recent cold weather?
    May 2006
    somerset
    thanks gsi, yes it did glow in the cold snap, and i started fine. but on a da like today, where it is reasonably warm out, it will not glow obviously, but will struggle to start. I think you're right with the plugs though. as it runs fine when running, same old dti, its just the starting thats a problem!! I've still got some network q warranty so i'll dump it back down the dealers me thinks! Again! Only just got it back!
    Regular Member JCB's Avatar
    Oh, I forgot to remember!
    injector seals?
    thats what everyonereckons mine is...same prob!
    May 2006
    somerset
    Quote Originally Posted by JCB View Post
    injector seals?
    oh right yeh, is that a big job to do?
    Or leak off pipes?
    May 2006
    somerset
    No leaks at present form the pipes. But, it was frosty yesterday morning, and it heated, and started fine. The problem deffo occurs when its not cold enough to heat so it doesn't and won't start properly.
    Nr Cardiff
    Injector seals.
    Pop off the covers, get to the injectors and carefully give them a tighten. If this cures the problem replace the seals, jobs a goodun. Easy DIY job, a garage will charge you up to £100 to do it.
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    Quote Originally Posted by prm View Post
    Or leak off pipes?
    Heres one for you my old vec B cold start problems
    What we found was the rubber pipes on the injectors had started to perish and leaking diesel
    So when you came to start her no diesel in the injectors so a bad cold start
    Told this form a VX micky and it worked
    So theres some thing else to think about
    May 2006
    somerset
    Thanks fellas, and thanks tripple trouble, i'll try that! If it ever stops raining!!!!!!!!!
  1. Cold start problems?
    By Barlow in forum Vectra C / Signum Troubleshooting
    Last Post: 24th February 2012, 14:16
  2. 2.2 dti cold start problems
    By MattHD in forum Engine & Drivetrain
    Last Post: 20th May 2011, 23:07
  3. 2.0 dti cold start problems
    By nickp1975 in forum Engine & Drivetrain
    Last Post: 1st December 2010, 11:33
  4. 2.0 dti cold start problems
    Last Post: 21st June 2010, 09:25
  5. Cold start problems
    By hippo94735 in forum Engine & Drivetrain
    Last Post: 24th February 2010, 19:48
