Results 1 to 3 of 3
Thread: Rear end knocks
    Feb 2007
    Dundee
    Default Rear end knocks
    I have a 52 LS Vectra and have had intermittent rear end knocks for many months - some days the knocks were much worse that others. I put it into the local garage who could not find a problem. Three weeks ago - out of shear exaggeration I took off the rear wheels and blasted the whole rear wheel arch area with a power washer and then a scoot of WD40 to any area that had a bolt or looked like it could move.
    It worked and it is still OK!
    I appreciate this may not last long when the weather starts to dry up and would like to go over the area and reseat every bolt I can find, but I think they are TORX bolts. To get them off I will need a TORX socket for my half inch drive set. Does anybody know what size of TORX socket is required?
    E20 and E18 for the back suspension...
    Feb 2007
    Dundee
    Many thanks!
  1. Other than rear upper arms and arbs what else knocks?
    By MCD in forum Suspension, Wheels & Brakes
    Last Post: 6th March 2013, 18:15
  2. Suspension knocks, bangs, creaks and rattles.
    By gtr1000 in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2012, 23:24
  3. Rear left wheel knocks when drop in a hole
    By swet in forum Suspension, Wheels & Brakes
    Last Post: 31st August 2011, 17:16
  4. knocks result
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2010, 12:28
  5. Changed BOTH Upper Control Arms - still knocks!!
    By si_hoss in forum Suspension, Wheels & Brakes
    Last Post: 9th October 2009, 18:20
