Put a sound clip on here of the starter motor on a cold start.
Im having same problems but also the glow plug light only comes on for less than a second the goes out im sure this shouldnt be right any ideas
Sent from my GT-I9505 using Tapatalk
Ive had problems starting my vec 1.9 8v battery is fine new glow plugs new relay new starter cleaned and blanked off egr cleaned throttle body the circuit board as covered in oil im stuck now only injectors i havent checked
Any ideas lads
Look at the tops of the injectors............
You will see braided hoses running across in-between them then off to the metal fuel return pipe.
These hoses can leak.
ah right yeh ive changed them
i have also been reading today about the woodruff key on the 1.9 8v where they wear down and knock the timing out a fraction and thats what causes the car to have cold start problems
i know where the woodruff key is on the 1.9 16v as i almost lost it when i changed the manifold on it but im not too sure where it is on the 1.9 8v i should imagine pretty much the same place
anyone know for pictures on this
thanks leighton
