Thanks Thanks:  2
Likes Likes:  6
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 58
Thread: CDTi 120 & 150 Cold start problem check list.
  1. #11
    Regular Member willbaroo's Avatar
    Dec 2013
    United Kingdom
    Vehicle : Signum 1.9 CDTI
    Engine : CDTi
    Year : 06
    Mileage : 116000
    Quote Originally Posted by Pwthebaldeagle View Post
    Well it's gone in today for new glow plugs and thermostat too. Will see if that cures the problem.
    anyone I've spoke to all say glow plugs,but one or two people have also said poss injector ?
    Ok keep me posted dude.
  2. #12
    Jan 2013
    Chester
    Vehicle : Vectra estate xp cdti
    Trim : Sri xp
    Engine : 120 cdti
    Well new plugs and thermostat fitted. Massive improvement on start up this morning,hardly any smoke at all..altho the old plugs were still functioning?
    Apparently the noise on start up/tick over is down to the botom pulley which now needs to be changed
  3. #13
    Dec 2013
    United Kingdom
    Engine : CDTi
    Year : 06
    Mileage : 116000
    How strange! I didn't think the glows were used until it got below -3 or something. But if the light on the dash comes on surely that means they are being used. My issue seems to get worse as the temp gets colder.
    I tested glow plugs the other night and when the multimeter was on 200ohms they all read 0001.
    I get white diesel smelling smoke and it sounds like 3 cylinders for about 10-15 seconds on idle or it vanishes as you drive away/apply throttle.
    Cleaning throttle body and replacing leak off pipes tomorrow. Wish I could get to the bottom of this!
  4. #14
    Jan 2013
    Chester
    Trim : Sri xp
    Engine : 120 cdti
    I would say to replace the glow plugs,what gave you got to lose? Other than that,could it poss be an injector problem?
  5. #15
    Dec 2013
    United Kingdom
    Engine : CDTi
    Year : 06
    Mileage : 116000
    This is true - if tomorrows efforts don't do anything I will be tempted to change glows. Only thing I can think of is injector seals, the car runs sweet as a nut any other time. Even warm starts
  6. #16
    Jan 2014
    birmingham
    Vehicle : vectra
    Trim : exclusive
    Engine : 1900 cdti
    Im having a problem starting my car from cold to ,i recently had the injectors checked they were fine ,also checked the glow plugs the resistance was good.had the egr valve cleaned out .had the fuel lines checked to that was ok to ,any ideas please have read in this post that a new starter motor could cure the problem ?
  7. #17
    Jan 2013
    Chester
    Trim : Sri xp
    Engine : 120 cdti
    I bet if you replace the starter it will all but cure the problem
  8. #18
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by scanny View Post
    Check the video in the first post of this thread and compare with your starter motors performance.
    also make sure your battery is 100% with a drop test done at a Starter & Alternator repairers
    not Halfords or Quick fit
  9. #19
    Jan 2014
    birmingham
    Vehicle : vectra
    Trim : exclusive
    Engine : 1900 cdti
    i replaced the starter motor made a little difference but not how it should be. also replaced coolant temp sensor and now the glowplugs but no difference any ideas
  10. #20
    Jan 2014
    birmingham
    Vehicle : vectra
    Trim : exclusive
    Engine : 1900 cdti
    ive noticed when the coolant temp sensor was disconected the glow plugs would stay on longer and the car would start a lot easier ,So i replaced the coolant temp sensor but no digfference,is there a way i could fit a timer relay to the coolant temp sensor wire so to keep the glowplugs on longer
  1. Cold start problem z18xer
    By Erikf in forum Vectra C / Signum Troubleshooting
    Last Post: 26th February 2012, 22:40
  2. vectra c 2.0dti cold start problem
    By Ade-c in forum Engine & Drivetrain
    Last Post: 12th February 2011, 14:35
  3. cold start problem
    By daddy07 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd July 2010, 22:28
  4. Semi cold start problem
    By Hennie in forum Engine & Drivetrain
    Last Post: 8th June 2010, 17:04
  5. Cold start problem. 2004 2.0 DTi.
    By BlueMarvel in forum Engine & Drivetrain
    Last Post: 6th June 2010, 22:20
https:www.vectra-c.comforumshowthread.php198534-CDTi-120-amp-150-Cold-start-problem-check-listpage2
https:www.vectra-c.comforumshowthread.php198534-CDTi-120-amp-150-Cold-start-problem-check-listpage5
zafira 1.9 cdti starting problems
vauxhall vectra 1.9 cdti cold starting problems
vectra c diesel starting problems
vectra c cold start problem
vectra glow plugs problems
vauxhall vectra not starting problems
vectra diesel starting problems
vectra hard to start cdti list of possible faults
vauxhall vectra diesel starting problems
vectra c 1.9 cdti starting problems
vectra c starting problems
vectra 1.9 cdti starter motor problems
vectra starting problems
vauxhall astra 1.9 cdti cold start problem
my vectra is hard to start 1.9cdi
vauxhall vectra c diesel engine start faults list
vauxhall vectra 1.9 cdti starting problems
insignia cdti starting problem
vauxhall diesel starting problems
vectra 1.9 cdti cold start problem
vectra cdti cold start problem
