Thanks Thanks:  2
Likes Likes:  6
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: CDTi 120 & 150 Cold start problem check list.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Default CDTi 120 & 150 Cold start problem check list.
    @ Admin please make this a sticky at some point due to the amount of cold start queries on the forum
    Hi all
    This applies only to difficult COLD starting and not WARM starting.
    I'll start this collection with the usual suspect the starter motor speed on first cold start overnight.
    Conditions
    1. Battery checked tested and fully charged.
    2. Fuel line leak off/return checked/replaced.
    3. Glow plug system checked.
    4. Tech 2 Vaux-com OBDII scan with no current fault codes fuel/starting related.
    5. Injectors tested and within performance range.
    The above checks are advised, but looking at the video below should make it obvious what the problem is
    Here's a comparison video made by one of the members on this forum some time ago,
    it highlights the differences perfectly between old and new stater motor cold start performance,
    please note the vehicle battery should be tested and in perfect condition.
    http://www.youtube.com/watch?v=RCrykhNWOd8
    If your starter motor sounds like the first one or slower than the new one in the above video chances are it needs replacing/repairing.
    Please add you cold starting fixes as well everyone
    Regular Member Slammedorion's Avatar
    Mar 2012
    cheshire
    11 Post(s)
    My 120 cdti Sri was a pig to start on a cold morning, after lots of searching on here I first tried...
    glow plugs... ( was better but still not good )
    a full thermostat housing with new temp sensor as gauge wasn't working correctly... ( no difference )
    glow plug relay ( no better )
    diesel filter plus housing ( had a slight weep, but no improvement )
    BIG battery ( no better )
    a new starter motor ( BINGO )
    If you've fitted new glow plugs and a glow plug relay and it's still poor starting, stick a big battery on it and a new starter...
    Sep 2013
    Hertfordshire
    Trim : SRi XPNAV
    Engine : 1.9 CDTi 150
    I think mine needs a new starter. Starts fine from Warm, but once left to cool its a pig, and the starter seems to labour even with jump leads on.
    Is it a pig to change? I have done other cars, but never touched a Vectra under the bonnet.
    May 2011
    South London
    Quote Originally Posted by NeiltSRi View Post
    Simple job to do just 3 bolts at the back of the engine , you can do it from the top
    1. Remove battery earth lead.
    2. Remove the main battery to starter cable and solenoid cable from the starter motor.
    3. Remove the 3x13mm bolts retaining the stater motor
    Shoud take about an hour off/on
    See about getting your old one repaired at a Auto-electrical repairers, it will be cheaper than a new one.
    Sep 2013
    Hertfordshire
    Trim : SRi XPNAV
    Quote Originally Posted by C-Owner View Post
    Great thanks. Can get a new one for £108, but will enquire about price to get mine refurbed.
    Feb 2013
    west yorkshire
    Vehicle : 150 cdti
    Trim : sri
    Engine : 200
    had the same problem on my brother car turned out to be 3 glow plugs had stop working
    Jan 2013
    Chester
    Vehicle : Vectra estate xp cdti
    Trim : Sri xp
    Engine : 120 cdti
    well ive got the dreaded cold start problems back!. This time last year changed the glow plugs,alternator,battery and starter motor.That made sure everything was spot on..now..dam cold start problem is back!!
    Only difference this time around is when the car actually fires up,theres quite a bit of smoke,bit of cough and spluttering and a smell of diesel in the air. Any ideas anyone?
    Feb 2013
    west yorkshire
    Vehicle : 150 cdti
    Trim : sri
    Engine : 200
    that sound like my brother car and it turned out to be glow plugs buddy
    Regular Member willbaroo's Avatar
    Dec 2013
    United Kingdom
    Vehicle : Signum 1.9 CDTI
    Engine : CDTi
    Year : 06
    Mileage : 116000
    Quote Originally Posted by Pwthebaldeagle View Post
    I'm getting the same chap - did you fix your cold start issues?!
    Replaced starter motor last weekend which means it starts quicker but still get white diesel smoke and lumpy idle (slight misfire) for about 10-15seconds. Driving off or giving it a boot full clears the problem straight away!
    Jan 2013
    Chester
    Trim : Sri xp
    Engine : 120 cdti
    Well it's gone in today for new glow plugs and thermostat too. Will see if that cures the problem.
    anyone I've spoke to all say glow plugs,but one or two people have also said poss injector ?
  1. Cold start problem z18xer
    By Erikf in forum Vectra C / Signum Troubleshooting
    Last Post: 26th February 2012, 22:40
  2. vectra c 2.0dti cold start problem
    By Ade-c in forum Engine & Drivetrain
    Last Post: 12th February 2011, 14:35
  3. cold start problem
    By daddy07 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd July 2010, 22:28
  4. Semi cold start problem
    By Hennie in forum Engine & Drivetrain
    Last Post: 8th June 2010, 17:04
  5. Cold start problem. 2004 2.0 DTi.
    By BlueMarvel in forum Engine & Drivetrain
    Last Post: 6th June 2010, 22:20
zafira 1.9 cdti starting problems
vauxhall vectra 1.9 cdti cold starting problems
vectra glow plugs problems
vectra c cold start problem
vectra diesel starting problems
vauxhall vectra not starting problems
vectra c diesel starting problems
vectra 1.9 cdti starter motor problems
vectra hard to start cdti list of possible faults
vectra c 1.9 cdti starting problems
vauxhall astra 1.9 cdti cold start problem
vauxhall vectra diesel starting problems
vectra c starting problems
https:www.vectra-c.comforumshowthread.php198534-CDTi-120-amp-150-Cold-start-problem-check-listpage2
vectra starting problems
vectra cdti cold start problem
vectra c cold starting problems
vauxhall diesel starting problems
vauxhall vectra 1.9 cdti starting problems
vectra 1.9 cdti cold start problem
insignia cdti starting problem
my vectra is hard to start 1.9cdi
vauxhall vectra c diesel engine start faults list
vectra starting problems 19 cdti
