Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: clutch pedal spring
    Dec 2005
    south shields
    Default clutch pedal spring
    i finally got a clutch pedal spring for the vec and ive been having a look at the one thats currently fitted
    ive tried fiddling with the little white thing that appears to be holding the thing in place but cant seem to budge it, although i didnt fiddle too hard incase i broke something as ive got to goto work tomorrrow..
    has anyone changed this part? can anyone advise me how to change the part please?
    many thanks
    lee
    Regular Member stickshift's Avatar
    North London
    I thought it was a six hour pedal box out dealer job!
    [Ex]Admin Duncan's Avatar
    This PDF should help.
    Dec 2005
    south shields
    were there originally pictures with that pdf? cant seem to get it to work..
    There are illustrations/diagrams in the PDF.
    Admin plasma's Avatar
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    Works fine for me D
    North London
    Quote Originally Posted by stickshift View Post
    Guys, I think I’m right in thinking that the pedal spring which is about an inch in diameter and coiled around the pedal box shaft is a separate part to the switch. Although the switch is spring loaded it is only to make the switch return to rest position not the pedal . If the pedal is not returning via its spring the spring in the switch will not return as it is not strong enough to move the pedal up.
    Mileage : 000
    Cheers for the information Duncan.
    Dec 2005
    south shields
    ok i got the pdf to work, although i cant see the part (93183937) on those sketches, is that the same part?
    Dec 2005
    south shields
    right ive just been for another look under the pedals, i havent removed any interior parts. The spring has no electrical connections on or near it so it must be a different part. it actually looks just like a small shock absorber about 80mm long with black sleeve over the spring, looks like theres a small white clip that holds it in place. im guessing that you squeeze the clip togerther to get it out?
  1. Clutch pedal spring.
    Last Post: 1st May 2012, 00:06
  2. clutch pedal spring
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2011, 13:38
  3. clutch pedal spring
    By carl bear in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2010, 11:58
  4. clutch pedal spring
    By paul429 in forum Engine & Drivetrain
    Last Post: 20th March 2008, 15:53
