Results 1 to 10 of 20
Thread: side sills, easy to remove?
    Regular Member gizmo10119's Avatar
    Cambridgeshire
    Default side sills, easy to remove?
    as above, i need to remove them as they are being painted hopefully in the next couple of days, are they easy to get off????
    any advice greatly appreciated!
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    hi m8
    yeah p*ss easy m8,here goes
    just before you attemt it make sure you have new rivets so you can
    replace them as you wont be able to salvage the centre pins for the old
    rivets.
    how to remove
    open front/rear door at 1 side at a time and pull off the rubber strip along the inner of the
    door sill,then were the rubber strip was,behind it push through the centre
    pin of the rivets all the way along,then underneath the sill you will see
    square recesses and again push the centre pin on the rivets in,then at the
    front end pull the skirt out and all the remaining of the rivets shud all pop
    out along wit the skirt then at the rear of the sill skirt its clipped on so just
    pull it and it`ll clip off,think thats it really.
    Cambridgeshire
    thanks matey, easy when you know how! how much are the rivets do you know?
    12 Post(s)
    Trim : elite
    Year : 2011
    Quote Originally Posted by gizmo10119 View Post
    hi m8
    they are no more than 12p each and you will need 12 for each side
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Quote Originally Posted by Andyvec View Post
    hi m8
    Andy, Is there a specific part number for these or just general plastic rivets?
    12 Post(s)
    Trim : elite
    Year : 2011
    Quote Originally Posted by willc01 View Post
    yes m8 there is a specific part number as these rivets come in all sizes,i
    think from memory the part number is 90138810 but just make sure you ask
    the parts guy to check,if you get stuck then let me know and i`ll get them
    and send you them.
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Andy,
    Shall do a how 2 with photos next week?
    12 Post(s)
    Trim : elite
    Year : 2011
    Quote Originally Posted by Brocks View Post
    Andy,
    f*ck andy will be NOT
    think from memory the part number is 90138810...
    Yep, that's the one Andy.
    12 Post(s)
    Trim : elite
    Year : 2011
    wow aint i sad remembering that part number for the rivets
  1. How easy is it to remove side skirts on estate??
    By SlowCoach in forum Styling
    Last Post: 8th October 2012, 22:48
  2. how to remove vlack window sills
    By damadom in forum Styling
    Last Post: 27th May 2009, 17:24
  3. is it easy to remove towbar ???
    By tash in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2009, 19:46
vectra c remove sill cover
