Results 1 to 2 of 2
Thread: Changed airfiler, part of the MAF sensor was broken
    Regular Member simac's Avatar
    Wirral
    Default Changed airfiler, part of the MAF sensor was broken
    Well, I say MAF sensor because I think that's the sensor on the top of the air box.
    I took the large intake pipe off to change the air filter and noticed some plastic inside the senor. It's like a plastic "spiders web", the opposite side to the mesh filter just before the sensor connects to the pipe. Part of it was broken and loose, after thinking about it I decided to remove it rather than risk small bits braking off and being sucked in to the engine
    It looks like it's only there to stop the delicate probes in the sensor being touched, does anyone know if it has another use ? It starts and runs fine with no warning lights or anything ......
    Cheers guys, could really do with putting my mind at rest
    Regular Member Ian's Avatar
    York
    Yep your right on all counts. But I would look into getting a new one. An old member did this - but removed it for perfromance reasons - and ended up buying a new MAF sensor. The fact that is broken may tell you its there for a reason.
  1. changed my outside temp sensor
    By tolly in forum Vectra C / Signum Troubleshooting
    Last Post: 13th January 2012, 10:01
  2. Boost Sensor Broken?
    By quarkrad in forum Engine & Drivetrain
    Last Post: 12th October 2011, 08:27
  3. Has anyone changed this part of the grill
    By Shogun in forum Styling
    Last Post: 14th September 2011, 18:30
  4. Broken brake pad sensor
    By mishima in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2010, 00:08
