Thread: throttle position sensor
    Regular Member Ryan's Avatar
    Feb 2007
    Poole, Dorset
    Default throttle position sensor
    Hi,
    has anyone or know how to replace a throttle position sensor on a 2003 signum dti got fault code read out by dealer but it is so intermittant.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    its on the intake housing under the small black cover .........
    Feb 2007
    Glasgow
    Did changing the throttle position sensor fix the fault. I too have the same loss of power, leave it and its fine on a very intermitant basis. The mechanic wants to change the sensor but can only buy it as part of the manifold £150 + vat, did you manage to get the sensor on its own?
    Any help much appreciated.
    Regular Member Sundance's Avatar
    Scotland
    Quote Originally Posted by eileeng2 View Post
    Unfortunatly the sensor only comes with that part of the manifold. Vx dont sell it on its own!! (hopefully they will soon as it is a fairly common fault)
    Feb 2007
    Poole, Dorset
    vauxhall did diagnosis and replaced map sensor at a cost of £157, fault was happening all the time now hasnt happened in 300 miles
    Feb 2007
    Wales
    I have the same kind of issues with an 04 DTI Vectra - booked into local VX dealers on Friday - will let you know what happens?
    Nov 2010
    uk
    hi, I have a vectra from 2005 120 ph and from about three days the engine does not turate more than 3200 and I have got this fault code:P1125 and I don't know how to solve it. if I delete the code the engine works again but after few seconds the engine loses the power again and I get the same code p1125.
    can somebody help me with this?
    thank you
    Jan 2010
    glasgow
    P1125 APP Sys
    P1125 boost pressure solenoid valve errors thats the only thing i can find under p1125
  1. Throttle Position Sensor Vectra Est. 2.0L DTI
    By bernadette in forum Engine & Drivetrain
    Last Post: 22nd November 2011, 18:38
  2. Throttle Position Sensor
    By RichyA in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2010, 15:12
  3. Throttle Position Sensor...
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 16th September 2010, 20:51
  4. Throttle Position Sensor
    By Kristypie in forum Engine & Drivetrain
    Last Post: 9th April 2010, 21:14
  5. throttle position sensor
    By Morephun in forum Engine & Drivetrain
    Last Post: 3rd July 2008, 10:30
vectra c throttle position sensor
vauxhall vectra c throttle sensor problems
how much does it cost to replace a throttle position sensor on a vectra
throttle position sensor vectra c
vectra throttle position sensor
vauxhall vectra c throttle position sensor
