Great.
Now to see if the seller accepts my slightly reduced offer... haha.
Can anyone confirm if the original Xenon Bulbs/Ballasts fit into the AFL Lamps?
Great.
actually the blue halo lens turns couple degrees to each side when you turn the wheel but you need to be traveling at least couple miles per hour. The middle bulb is only for curb lighting and is activated when you turn the wheel at least 90 degrees or you put on turn signal but only when travelling below 30mph or so. The afls will also bring up the low beam a bit when travelling at motorway speeds.
Yes however there is additional H1 bulb for curb lighting, the one in the middle pointing at an angle on the picture above in this thread. You can bring accros D1S burner. AFL uses this for low and main beam. You also can bring across H1 main beam bulb from normal xenons. AFL use this to support main beam and for flashing when lights are turned off.
Great, Thanks.
So to clarify - Existing Bulbs that can be swapped across;
Dip (Low) Beam Xenon & Ballast
Main Beam
Indicator
To Add/Source;
Dynamic Lighting Bulb
That's correct. You will also need AFL control module to make the lights work if I remember correctly
hopefully someone on here will be able to source them cheaper than what they're going for on the bay!
Right, bought the Lamps - hopefully the weathering marks can be removed (I'll follow the guide on here as the results shown are good!)
Hopefully it'll be straightforward after they've been tidied up.
some added and alterering of some wiring and a tech2 session will finish the job off nicely
