Results 1 to 10 of 14
Thread: spongey brakes
    dumbarton
    Default spongey brakes
    any ideas got a vectra c cdti 19 est problem is the brake pedal is going to the floor its not loosing fluid tho
    Regular Member dervdoc's Avatar
    Co.Armagh
    when ya last get your pads done? much beef on the pads?
    faulty master cyclinder maybe? are the brakes cra*p or does she still stop ya ok?
    dumbarton
    they still stop me and the pads are quite new i was thinking the master cylinder too hope its covered on net q
    Co.Armagh
    Quote Originally Posted by taxi kev View Post
    yea should be, only time iv heard of them going faulty on a vauxhall is if ya change your pads, push the piston in the caliper in without loosening the bleed nipple
    dumbarton
    cheers for the info m8 nice car by the way
    Co.Armagh
    thanks mate
    Gävle, Sweden
    Same issue with my Signum... If I bleed the break system it will be fine for a few weeks or so, but then same thing again... Master cylinder has been replaced and break pads are just fine. It won't loose any fluid either. Getting tired of this! What can I do?
    Regular Member wingers1982's Avatar
    barnsley
    do a full brake fluid change sounds like ya brake fluid has broken down with time
    Regular Member simac's Avatar
    Wirral
    Sounds like water vapour in the brake fluid or a dodgy vac pump as that was causing a similar problem on my vec B dti
    Jul 2006
    Mexico
    Also bad lines (hoses) can cause that feeling, specially when brake fluid is hot....but is more likely to have air on the system as mentioned above
  1. vxr brakes + 17s ???
    By wullie-t27 in forum Handling & Braking
    Last Post: 8th September 2012, 17:46
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. Brakes a bit on the spongey side...
    Last Post: 3rd February 2011, 20:43
  4. Spongey/weak brakes HELP!
    By sri andy in forum Suspension, Wheels & Brakes
    Last Post: 10th July 2009, 16:54
  5. Spongey brakes?
    By Keith Fusco in forum Suspension, Wheels & Brakes
    Last Post: 18th June 2009, 20:07
