Thread: Z19DTH or Y19DTH
    South Central England
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    confused Z19DTH or Y19DTH
    Someone said in a post a while ago that if you don't have 0.5 on the door plate then you don't have a particle filter. Well mine is registered as Euro IV emissions and a Z19DTH but it doesn't have 0.5 on the plate... Can it be a Z19DTH without a particle filter?
    What does the filter look like?
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Quote Originally Posted by nutron View Post
    If a particle filter is fitted the car will never emit any black smoke when the car is revved hard ... if the car does smoke then it doesn't have one.
    HTH
    Leicester
    'Most' Vectra hatchback/saloon Z/Y19DTH no matter what the year do not havea particulate filter, I pretty sure none have, but have put most as I am not 100% sure.
    But I beleive all Vectra Estate and Signum 1.9's do have DPS.
    Someone may be able to correct me here, but I am pretty sure this is the case.
    My old Y19DTH SRi on an 04 reg didn't have one, neither has my 06 Z19DTH.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Euro 4 does not mean you will have DPF. Euro 4 reduced particulate matters to max 25 mg/km (Euro 3: 50) and on new engines there was not always the need to install a DPF to achieve this goal. It will be needed for Euro 5 (< 5 mg/km).
    However when Opel introduced the 1.9CDTI engines you could order a DPF for an extra 500 euro but it was from the begin standard on the estates and Signum (according to the Benelux press text 23.2-2004). I think in Germany the DPF became standard on all Vec/Sig somewhere in 2005; in Benelux in 2006.
    I don't know about the 0.5 on the door plate - it is not on mine - i only know that Euro 4 reduced CO-emissions tot 0.5 g/km from 2005 on.
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    This is the particle filter (on a GTS):
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Isn't that the CAT? Mine looks like that, with what I though was the CAT just behind that braided section.
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    The cat is smaller and without suspension parts at the back and no temperature sensor, but is true DPF is integrated with the cat in one (bigger) part.
  1. Z19dth DMF
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2012, 15:30
  2. Oil for z19dth
    By neill in forum Engine & Drivetrain
    Last Post: 18th July 2011, 18:45
  3. z19dth
    Last Post: 22nd April 2011, 08:38
  4. Z19DTH - Which Oil?
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 17:22
  5. z19dth
    By taralko in forum Vectra C / Signum Troubleshooting
    Last Post: 1st July 2006, 13:36
