7th October 2013, 13:29
#1
Clicking from tailgate lights
Hi Everyone, has anyone experienced this with a Vectra C Estate?
There is a clicking noise from the drivers side tailgate light cluster (I've had it for ages), whenever the tailgate is open and I'm sitting at the rear of the car I can hear a clicking noise from the tailgate. (the clicking may be there all the time, but this is the only time I can hear it).
The noise lasts a long as the power is active following ignition off.
I've been doing some other investigation work in the tailgate recently with the trim removed - the noise is coming from the light cluster itself, if I remove the sidelight bulb, the noise stops!
It's almost like an electrical relay in the cluster itself.
Thanks in advance for any comments
Pete
7th October 2013, 16:14
#2
Never experienced that, sounds like canbus is polling, that is normal, but not sure what can be making the sound... towing relay? Perhaps tailgate lock gets polled? Wiper motor? I know the sound seems to be coming from the cluster, but difficult to see how it can! Hopefully someone can post you a more helpful answer!
7th October 2013, 16:34
#3
Normal, mine been doing it always.
8th October 2013, 12:14
#4
Thanks for your comments, I've always had it also - just wandered if it was a common thing?
8th October 2013, 13:18
#5
Have you got a towbar? If so it maybe the split charge relay.
15th October 2013, 12:11
#6
No towbar fitted.
Strange thing is, after seaching for an electrical problem over the weekend - disconnecting the rear body control unit, the LH inner light cluster now clicks!
19th October 2013, 18:32
#7
My Vectra Elite Estate is just the same. It's always done it.
23rd April 2019, 17:08
#8
Mine too! Did anyone get to the bottom of this?
24th January 2021, 23:07
#9
2 years later, and I've fixed this. Mine is an estate, but the problem revolves around the rear light bulb sockets corroding. I had a bulb out, or so I thought, in the tailgate, and the terminals were very corroded. Cleaned them up and did all the others while I was at it, bulb hadn't blown BTW, and hey presto, no clicking. Must be something to do with the Canbus, but glad it's fixed.
11th February 2021, 17:48
#10
Originally Posted by
christmas
Mine clicks too. I thought it was the canbus bulb check. I already sanded the sockets all way round since the front indicator was "out".
