Thread: Water leak drivers floor
    Regular Member grumpano's Avatar
    North West
    Unhappy Water leak drivers floor
    Iv'e just been away for 2 weeks, so while i was away i had to use a pressure wash on the car,after which a vacumed it.Everything was fine until 2 days later i noticed my mat around the throttle area was wet through, as was the carpet in this area.The rest of the carpet seemed dry but just to make sure i lifted the tab on the carpet and felt underneath. To my shock the foam under the carpet was soaked. I have been leaving kitchen roll on the carpet while spraying the car with water,but no water is evident.
    I wonder do i have a leak or could under the carpet be soaked due to the car being valeted by the selling garage?
    Please help. The last thing i need is a damp and rotting carpet............
    Have a look at this thread m8. It relates to the passenger side apparently, but it could be that it's the same problem you have - just on the driver's side.
    HTH
    North West
    Hmmm not sure its that though Duncan.
    Ta for the reply.
    Regular Member SirGSi's Avatar
    England
    Hello m8.
    Does the water smell of antifreeze?
    If so, it could be the heater matrix which has a hole in it.
    I had two go in an old F-reg Astra and dumped the cooling system in the driver's footwell, made a right mess!!!
    Hope it's not that for your sake!
    ATB
    Grant.
    North West
    No it doesn't smell at all mate.I dried it out with the wifes hair dryer yesterday,so i'll see if it returns.If it does then back to VX.
    England
    Ok, ol' chap....hope it's sorted for you now!
    Grant.
    wigan
    i have just had the same problem, just bought the car and noticed the drivers side was wet underneath, after checking the drain hole it was full of leaves and s&%t, i've cleared it out so hopefully thats the end of it!!
  1. Water on floor not blocked scuttle
    By roverjay in forum Bodywork & Interior
    Last Post: 27th May 2012, 22:47
  2. water in boot floor???
    By richiem in forum Bodywork & Interior
    Last Post: 18th November 2011, 11:38
  3. What cured your water leak (hatchback, damp floor in boot/spare wheel well)
    By DNS in forum Vectra C / Signum Troubleshooting
    Last Post: 5th October 2011, 19:31
  4. leaking water, driver's floor ?
    By timbuckwho in forum Engine & Drivetrain
    Last Post: 4th February 2011, 22:01
signum water leak on floor
