Here is List of codes from the Vauxhall tech support TIS System .
P0016
Crankshaft/Camshaft Correlation
P0093
Rail Pressure Range/Performance (Positive Deviation)
P0100
Mass Or Volume Air Flow Circuit High Input
P0100
Mass Or Volume Air Flow Circuit Low Input
P0100
Mass or Volume Air Flow Sensor Circuit Range/Performance
P0105
Boost Pressure Sensor Circuit Low Input
P0105
Boost Pressure Sensor Circuit High Input
P0105
Boost Pressure Sensor Circuit Range/Performance
P0110
Charge Air Temperature Sensor Low Input
P0110
Charge Air Temperature Sensor High Input
P0180
Fuel Temperature Sensor Circuit Low Input
P0180
Fuel Temperature Sensor Circuit High Input
P0190
Rail Pressure Sensor Low Voltage
P0190
Rail Pressure Sensor High Voltage
P0190
Rail Pressure Range/Performance (Negative Deviation)
P0200
Fuel Injector Malfunction
P0201
Cylinder 1 Injector Circuit Open
P0202
Cylinder 2 Injector Circuit Open
P0203
Cylinder 3 Injector Circuit Open
P0204
Cylinder 4 Injector Circuit Open
P0205
Cylinder 5 Injector Circuit Open
P0206
Cylinder 6 Injector Circuit Open
P0217
Fuel Reduction caused by High Coolant Temperature
P0219
Engine Overspeed Condition
P0235
Boost Pressure Low Pressure
P0235
Boost Pressure High Pressure
P0243
Boost Pressure Valve High Voltage
P0243
Boost Pressure Valve Low Voltage
P0251
Rail Pressure Control Valve 1 or 2 High Voltage
P0251
Rail Pressure Control Valve 1 or 2 Low Voltage
P0251
Rail Pressure Control Valve 1 or 2 Short Circuit
P0301
Cylinder 1 Misfire Detected
P0302
Cylinder 2 Misfire Detected
P0303
Cylinder 3 Misfire Detected
P0304
Cylinder 4 Misfire Detected
P0305
Cylinder 5 Misfire Detected
P0306
Cylinder 6 Misfire Detected
P0335
Crankshaft Position Sensor Circuit Malfunction
P0335
Crankshaft Position Sensor Signal Range/Performance
P0340
Camshaft Position Sensor Circuit Malfunction
P0340
Camshaft Position Sensor Circuit Range/Performance
P0380
Glow Time Relay Circuit Malfunction
P0381
Glow Device Circuit High Voltage
P0381
Glow Device Circuit Low Voltage
P0382
P0400
Exhaust Gas Recirculation Flow Excessive
P0400
Exhaust Gas Recirculation Flow Insufficient Detected
P0404
Exhaust Gas Recirculation Circuit High Voltage
P0404
Exhaust Gas Recirculation Circuit Low Voltage
P0409
Exhaust Gas Recirculation Circuit Range/Performance (Open Valve)
P0409
Exhaust Gas Recirculation Circuit Range/Performance (Closed Valve)
P0409
Exhaust Gas Recirculation (EGR) Valve Feedback Voltage Low
P0409
Exhaust Gas Recirculation (EGR) Valve Feedback Voltage High
P0520
Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0615
Starter Relay Circuit High Voltage
P0615
Starter Relay Circuit Low Voltage
P0638
Electronic Throttle Control Low Voltage
P0654
Engine Speed Signal Range/Performance
P0705
Invalid Signal from TCM (Transmission Control Module)
P0725
P1035
Invalid Signal from ABS (Anti-Lock Brake System)
P1070
Intake Air Temperature Sensor Circuit Low Input
P1070
Intake Air Temperature Sensor Circuit High Input
P1105
Barometric Pressure Sensor Circuit Low Input
P1105
Barometric Pressure Sensor Circuit High Input
P1120
Accelerator Pedal Position Sensor 1 Low Input
P1120
Accelerator Pedal Position Sensor 1 High Input
P1120
Accelerator Pedal Position Sensor Malfunction
P1120
Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio
P1122
Accelerator Pedal Position Sensor 2 Low Input
P1122
Accelerator Pedal Position Sensor 2 High Input
P1216
Injector Valve Voltage Converter System Malfunction
P1216
Injector Valve Voltage Converter Module Malfunction
P1235
Guide Vane Control Rod Position Sensor Low Voltage
P1235
Guide Vane Control Rod Position Sensor High Voltage
P1235
Guide Vane Control Rod Position Sensor Range/Performance (Stuck Open)
P1235
Guide Vane Control Rod Position Sensor Range/Performance (Stuck Closed)
P1291
Cylinder 1 Injector Circuit High
P1291
Cylinder 1 Injector Correction Resistor Circuit High Input
P1291
Cylinder 1 Injector Correction Resistor Circuit Low Input
P1292
Cylinder 2 Injector Circuit High
P1292
Cylinder 2 Injector Correction Resistor Circuit High Input
P1292
Cylinder 2 Injector Correction Resistor Circuit Low Input
P1293
Cylinder 3 Injector Circuit High
P1293
Cylinder 3 Injector Correction Resistor Circuit High Input
P1293
Cylinder 3 Injector Correction Resistor Circuit Low Input
P1294
Cylinder 4 Injector Circuit High
P1294
Cylinder 4 Injector Correction Resistor Circuit High Input
P1294
Cylinder 4 Injector Correction Resistor Circuit Low Input
P1295
Cylinder 5 Injector Circuit High
P1295
Cylinder 5 Injector Correction Resistor Circuit High Input
P1295
Cylinder 5 Injector Correction Resistor Circuit Low Input
P1296
Cylinder 6 Injector Circuit High
P1296
Cylinder 6 Injector Correction Resistor Circuit High Input
P1296
Cylinder 6 Injector Correction Resistor Circuit Low Input
P1620
5V Reference Circuit 1 Low Voltage
P1620
5V Reference Circuit 1 High Voltage
P1625
Main Relay Circuit High Voltage
P1625
Main Relay Circuit Low Voltage
P1635
5V Reference Circuit 2 High Voltage
P1635
5V Reference Circuit 2 Low Voltage
P1811
Torque Signal Malfunction (CAN)
P1813
P1814
Invalid Signal from ECC (Electronic Climate Control)
P1835
Kickdown Switch Circuit Malfunction
Hello guys,
i have just bought a 2003 plate vectra. its the duel fuel job. Just reading your post on fault codes. You can get the computer on eBay for Ģ30 Thats a lit cheaper then going to a Stealer that includes postage. I am thinking of getting one in oxford. If anyone wanted to go half's on it or want to rent it for a Ģ1 let me know. Cheers Martin
Hey,
Dont seem to have any problems at the moment (touch wood) but does anyone have one of these fault code readers that i could borrow, in and around Bristol. Would be amazing, just to save having to splash out at a a dealer.
cheers josh
2004 cdti 150
look here for How 2; Read Fault Codes for Free and Without any Equipment
http://www.vectra-c.com/forum/showthread.php?t=81742
hi guys.My diesel vectra showing oil1000 on the display.before i start the car.
Could anyone tell me please,what is it?
Firstly check the oil level but its probably due for a service or if it was done recently then the service indicator hasn't been reset.
I am in london and I am certified to install lpg and getting a dealership software soon so am more happy to help anyone when it comes.
hello. my car keeps coming up with a light on the dash! its the car with a spanner which is meant 2 be the service light, i have reset it to tell the car its had a service but it still keeps coming on, when it comes on it put the car into "safe mode!" which is no use 2 me when im on a dual carriageway, any suggestions as why its happening as its driving me crazy, many thanks Kirsty.
