Likes Likes:  1
Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
Thread: Fault code site.
  1. #31
    exeter
    Quote Originally Posted by phill c View Post
    I'm getting the P0404 code which is the exhaust gas range/performance, is this a faulty sensor etc. or something more sinister
    if its a dti try cleaning the egr valve look on here there's a how 2
  2. #32
    Regular Member SlowCoach's Avatar
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Engine : Z19DTH
    Year : 2008
    Mileage : 105000
    no longer working!!
  3. #33
    May 2020
    worthing
    Vehicle : vauxhall vectra
    Trim : cdti
    Engine : 1.9cdti
    Year : 06
    Default P1709 PNP Switch Out Of Self Test Range
    P0001 Fuel Volume Regulator Control Circuit/Open
    P0002 Fuel Volume Regulator Control Circuit Range/Performance
    P0003 Fuel Volume Regulator Control Circuit Low
    P0004 Fuel Volume Regulator Control Circuit High
    P0005 Fuel Shutoff Valve C ontrol Circuit/Open
    P0006 Fuel Shutoff Valve C ontrol Circuit Low
    P0007 Fuel Shutoff Valve C ontrol Circuit H igh
    P0008 Engine Position System Performance (Bank1)
    P0009 Engine Position System Performance (Bank2)
    P0010 A Camshaft Position Actuator Circuit (Bank1)
    P0011 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
    P0012 A Camshaft Position - Timing O ver-Retarded (Bank 1)
    P0013 B Camshaft Position - Actuator Circuit (Bank1)
    P0014 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
    P0015 B Camshaft Position - Timing O ver-Retarded (Bank 1)
    P0016 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor A)
    P0017 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor B)
    P0018 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor A)
    P0019 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor B)
    P0020 A Camshaft Position Actuator Circuit (Bank 2)
    P0021 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
    P0022 A Camshaft Position - Timing O ver-Retarded (Bank 2)
    P0023 B Camshaft Position - Actuator Circuit (Bank 2)
    P0024 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
    P0025 B Camshaft Position - Timing O ver-Retarded (Bank 2)
    P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1)
    P0027 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 1)
    P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)
    P0029 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 2)
    P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
    P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
    P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
    P0033 Turbo Charger Bypass Valve Control Circuit
    P0034 Turbo Charger Bypass Valve Control Circuit Low
    P0035 Turbo Charger Bypass Valve Control Circuit High
    P0036 HO2S Heater Control C ircuit (Bank 1 Sensor 2)
    P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
    P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
    P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
    P0040 O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1
    P0041 O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2
    P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
    P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
    P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
    P0045 Turbo/Super Charger Boost Control Solenoid Circuit/Open
    P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
    P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low
    P0048 Turbo/Super Charger Boost Control Solenoid Circuit High
    P0049 Turbo/Super Charger Turbine Overspeed
    P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
    P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
    P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
    P0053 HO2S Heater Resistance (Bank 1 Sensor 1)
    P0054 HO2S Heater Resistance (Bank 1 Sensor 2)
    P0055 HO2S Heater Resistance (Bank 1 Sensor 3)
    P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
    P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
    P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
    P0059 HO2S Heater Resistance (Bank 2 Sensor 1)
    P0060 HO2S Heater Resistance (Bank 2 Sensor 2)
    P0061 HO2S Heater Resistance (Bank 2 Sensor 3)
    P0062 HO2S Heater Control C ircuit (Bank 2 Sensor 3)
    P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
    P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
    P0065 Air Assisted Injector Control Range/Performance
    P0066 Air Assisted Injector Control Circuit or Circuit Low
    P0067 Air Assisted Injector Control Circuit High
    P0068 MAP/MAF Throttle Position Correlation
    P0069 Manifold Absolute Pressure Barometric Pressure Correlation
    P0070 Ambient Air Temperature Sensor Circuit
    P0071 Ambient Air Temperature Sensor Range/Performance
    P0072 Ambient Air Temperature Sensor C ircuit Low
    P0073 Ambient Air Temperature Sensor Circuit High
    P0074 Ambient Air Temperature Sensor Circuit Intermittent
    P0075 Intake Valve Control Solenoid Circuit (Bank 1)
    P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
    P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
    P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
    P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
    P0080 Exhaust Valve C ontrol Solenoid C ircuit High (Bank 1)
    P0081 Intake Valve Control Solenoid Circuit (Bank 2)
    P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
    P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
    P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
    P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
    P0086 Exhaust Valve C ontrol Solenoid C ircuit High (Bank 2)
    P0087 Fuel Rail/System Pressure - Too Low
    P0088 Fuel Rail/System Pressure - Too High
    P0089 Fuel Pressure Regulator 1 Performance
    P0090 Fuel Pressure Regulator 1 C ontrol Circuit
    P0091 Fuel Pressure Regulator 1 C ontrol Circuit Low
    P0092 Fuel Pressure Regulator 1 C ontrol Circuit High
    P0093 Fuel System Leak Detected Large Leak
    P0094 Fuel System Leak Detected Small Leak
    P0095 Intake Air Temperature Sensor 2 C ircuit
    P0096 Intake Air Temperature Sensor 2 C ircuit Range/Performance
    P0097 Intake Air Temperature Sensor 2 C ircuit Low
    P0098 Intake Air Temperature Sensor 2 Circuit High
    P0099 Intake Air Temperature Sensor 2 C ircuit Intermittent/Erratic
    P0100 Mass or Volume Air Flow Circuit Malfunction
    P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
    P0102 Mass or Volume Air Flow Circuit Low Input
    P0103 Mass or Volume Air Flow Circuit High Input
    P0104 Mass or Volume Air Flow Circuit Intermittent
    P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
    P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
    P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
    P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
    P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
    P0110 Intake Air Temperature Circuit Malfunction
    P0111 Intake Air Temperature Circuit Range/Performance Problem
    P0112 Intake Air Temperature Circuit Low Input
    P0113 Intake Air Temperature Circuit High Input
    P0114 Intake Air Temperature Circuit Intermittent
    P0115 Engine Coolant Temperature Circuit Malfunction
    P0116 Engine Coolant Temperature Circuit Range/Performance Problem
    P0117 Engine Coolant Temperature Circuit Low Input
    P0118 Engine Coolant Temperature Circuit High Input
    P0119 Engine Coolant Temperature Circuit Intermittent
    P0120 Throttle Position Sensor/Switch A Circuit Malfunction
    P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
    P0122 Throttle Position Sensor/Switch A Circuit Low Input
    P0123 Throttle Position Sensor/Switch A Circuit High Input
    P0124 Throttle Position Sensor/Switch A Circuit Intermittent
    P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control; ECT Excessive Time to Closed Loop Fuel Control
    P0126 Insufficient Coolant Temperature for Stable Operation
    P0128 Coolant Thermostat Malfunction
    P0129 Barometric Pressure Too Low
    P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
    P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
    P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
    P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
    P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
    P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
    P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
    P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
    P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
    P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
    P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
    P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
    P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
    P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
    P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
    P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
    P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
    P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
    P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
    P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
    P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
    P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
    P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
    P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
    P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
    P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
    P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
    P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
    P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
    P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
    P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
    P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
    P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
    P0170 Fuel Trim Malfunction (Bank 1)
    P0171 Fuel Trim too Lean (Bank 1)
    P0172 Fuel Trim too Rich (Bank 1)
    P0173 Fuel Trim Malfunction (Bank 2)
    P0174 Fuel Trim too Lean (Bank 2)
    P0175 Fuel Trim too Rich (Bank 2)
    P0176 Fuel Composition Sensor Circuit Malfunction
    P0177 Fuel Composition Sensor Circuit Range/Performance
    P0178 Fuel Composition Sensor Circuit Low Input
    P0179 Fuel Composition Sensor Circuit High Input
    P0180 Fuel Temperature Sensor A Circuit Malfunction
    P0181 Fuel Temperature Sensor A Circuit Range/Performance
    P0182 Fuel Temperature Sensor A Circuit Low Input
    P0183 Fuel Temperature Sensor A Circuit High Input
    P0184 Fuel Temperature Sensor A Circuit Intermittent
    P0185 Fuel Temperature Sensor B Circuit Malfunction
    P0186 Fuel Temperature Sensor B Circuit Range/Performance
    P0187 Fuel Temperature Sensor B Circuit Low Input
    P0188 Fuel Temperature Sensor B Circuit High Input
    P0189 Fuel Temperature Sensor B Circuit Intermittent
    P0190 Fuel Rail Pressure Sensor Circuit Malfunction
    P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
    P0192 Fuel Rail Pressure Sensor Circuit Low Input
    P0193 Fuel Rail Pressure Sensor Circuit High Input
    P0194 Fuel Rail Pressure Sensor Circuit Intermittent
    P0195 Engine Oil Temperature Sensor Malfunction
    P0196 Engine Oil Temperature Sensor Range/Performance
    P0197 Engine Oil Temperature Sensor Low
    P0198 Engine Oil Temperature Sensor High
    P0199 Engine Oil Temperature Sensor Intermittent
    P0200 Injector Circuit Malfunction
    P0201 Injector Circuit Malfunction - Cylinder 1
    P0202 Injector Circuit Malfunction - Cylinder 2
    P0203 Injector Circuit Malfunction - Cylinder 3
    P0204 Injector Circuit Malfunction - Cylinder 4
    P0205 Injector Circuit Malfunction - Cylinder 5
    P0206 Injector Circuit Malfunction - Cylinder 6
    P0207 Injector Circuit Malfunction - Cylinder 7
    P0208 Injector Circuit Malfunction - Cylinder 8
    P0209 Injector Circuit Malfunction - Cylinder 9
    P0210 Injector Circuit Malfunction - Cylinder 10
    P0211 Injector Circuit Malfunction - Cylinder 11
    P0212 Injector Circuit Malfunction - Cylinder 12
    P0213 Cold Start Injector 1 Malfunction
    P0214 Cold Start Injector 2 Malfunction
    P0215 Engine Shutoff Solenoid Malfunction
    P0216 Injection Timing Control Circuit Malfunction
    P0217 Engine Overtemp Condition
    P0218 Transmission Over Temperature Condition
    P0219 Engine Overspeed Condition
    P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
    P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
    P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
    P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
    P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
    P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
    P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
    P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
    P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
    P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
    P0230 Fuel Pump Primary Circuit Malfunction
    P0231 Fuel Pump Secondary Circuit Low
    P0232 Fuel Pump Secondary Circuit High
    P0233 Fuel Pump Secondary Circuit Intermittent
    P0234 Engine Overboost Condition
    P0235 Turbocharger Boost Sensor A Circuit Malfunction
    P0236 Turbocharger Boost Sensor A Circuit Range/Performance
    P0237 Turbocharger Boost Sensor A Circuit Low
    P0238 Turbocharger Boost Sensor A Circuit High
    P0239 Turbocharger Boost Sensor B Malfunction
    P0240 Turbocharger Boost Sensor B Circuit Range/Performance
    P0241 Turbocharger Boost Sensor B Circuit Low
    P0242 Turbocharger Boost Sensor B Circuit High
    P0243 Turbocharger Wastegate Solenoid A Malfunction
    P0244 Turbocharger Wastegate Solenoid A Range/Performance
    P0245 Turbocharger Wastegate Solenoid A Low
    P0246 Turbocharger Wastegate Solenoid A High
    P0247 Turbocharger Wastegate Solenoid B Malfunction
    P0248 Turbocharger Wastegate Solenoid B Range/Performance
    P0249 Turbocharger Wastegate Solenoid B Low
    P0250 Turbocharger Wastegate Solenoid B High
    P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
    P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
    P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
    P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
    P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
    P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
    P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
    P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
    P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
    P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
    P0261 Cylinder 1 Injector Circuit Low
    P0262 Cylinder 1 Injector Circuit High
    P0263 Cylinder 1 Contribution/Balance Fault
    P0264 Cylinder 2 Injector Circuit Low
    P0265 Cylinder 2 Injector Circuit High
    P0266 Cylinder 2 Contribution/Balance Fault
    P0267 Cylinder 3 Injector Circuit Low
    P0268 Cylinder 3 Injector Circuit High
    P0269 Cylinder 3 Contribution/Balance Fault
    P0270 Cylinder 4 Injector Circuit Low
    P0271 Cylinder 4 Injector Circuit High
    P0272 Cylinder 4 Contribution/Balance Fault
    P0273 Cylinder 5 Injector Circuit Low
    P0274 Cylinder 5 Injector Circuit High
    P0275 Cylinder 5 Contribution/Balance Fault
    P0276 Cylinder 6 Injector Circuit Low
    P0277 Cylinder 6 Injector Circuit High
    P0278 Cylinder 6 Contribution/Balance Fault
    P0279 Cylinder 7 Injector Circuit Low
    P0280 Cylinder 7 Injector Circuit High
    P0281 Cylinder 7 Contribution/Balance Fault
    P0282 Cylinder 8 Injector Circuit Low
    P0283 Cylinder 8 Injector Circuit High
    P0284 Cylinder 8 Contribution/Balance Fault
    P0285 Cylinder 9 Injector Circuit Low
    P0286 Cylinder 9 Injector Circuit High
    P0287 Cylinder 9 Contribution/Balance Fault
    P0288 Cylinder 10 Injector Circuit Low
    P0289 Cylinder 10 Injector Circuit High
    P0290 Cylinder 10 Contribution/Balance Fault
    P0291 Cylinder 11 Injector Circuit Low
    P0292 Cylinder 11 Injector Circuit High
    P0293 Cylinder 11 Contribution/Balance Fault
    P0294 Cylinder 12 Injector Circuit Low
    P0295 Cylinder 12 Injector Circuit High
    P0296 Cylinder 12 Contribution/Range Fault
    P0300 Random/Multiple Cylinder Misfire Detected
    P0301 Cylinder 1 Misfire Detected
    P0302 Cylinder 2 Misfire Detected
    P0303 Cylinder 3 Misfire Detected
    P0304 Cylinder 4 Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    P0306 Cylinder 6 Misfire Detected
    P0307 Cylinder 7 Misfire Detected
    P0308 Cylinder 8 Misfire Detected
    P0309 Cylinder 9 Misfire Detected
    P0310 Cylinder 10 Misfire Detected
    P0311 Cylinder 11 Misfire Detected
    P0312 Cylinder 12 Misfire Detected
    P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
    P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
    P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
    P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
    P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
    P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
    P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
    P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
    P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
    P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
    P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
    P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
    P0333 Knock Sensor 2 Circuit High Input (Bank 2)
    P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
    P0335 Crankshaft Position Sensor A Circuit Malfunction
    P0336 Crankshaft Position Sensor A Circuit Range/Performance
    P0337 Crankshaft Position Sensor A Circuit Low Input
    P0338 Crankshaft Position Sensor A Circuit High Input
    P0339 Crankshaft Position Sensor A Circuit Intermittent
    P0340 Camshaft Position Sensor Circuit Malfunction
    P0341 Camshaft Position Sensor Circuit Range/Performance
    P0342 Camshaft Position Sensor Circuit Low Input
    P0343 Camshaft Position Sensor Circuit High Input
    P0344 Camshaft Position Sensor Circuit Intermittent
    P0350 Ignition Coil Primary/Secondary Circuit Malfunction
    P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
    P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
    P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
    P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
    P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
    P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
    P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
    P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
    P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
    P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
    P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
    P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
    P0370 Timing Reference High Resolution Signal A Malfunction
    P0371 Timing Reference High Resolution Signal A Too Many Pulses
    P0372 Timing Reference High Resolution Signal A Too Few Pulses
    P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
    P0374 Timing Reference High Resolution Signal A No Pulses
    P0375 Timing Reference High Resolution Signal B Malfunction
    P0376 Timing Reference High Resolution Signal B Too Many Pulses
    P0377 Timing Reference High Resolution Signal B Too Few Pulses
    P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
    P0379 Timing Reference High Resolution Signal B No Pulses
    P0380 Glow Plug/Heater Circuit "A" Malfunction
    P0381 Glow Plug/Heater Indicator Circuit Malfunction
    P0382 Exhaust Gas Recirculation Flow Malfunction
    P0385 Crankshaft Position Sensor B Circuit Malfunction
    P0386 Crankshaft Position Sensor B Circuit Range/Performance
    P0387 Crankshaft Position Sensor B Circuit Low Input
    P0388 Crankshaft Position Sensor B Circuit High Input
    P0389 Crankshaft Position Sensor B Circuit Intermittent
    P0400 Exhaust Gas Recirculation Flow Malfunction
    P0401 Exhaust Gas Recirculation Flow Insufficient Detected
    P0402 Exhaust Gas Recirculation Flow Excessive Detected
    P0403 Exhaust Gas Recirculation Circuit Malfunction
    P0404 Exhaust Gas Recirculation Circuit Range/Performance
    P0405 Exhaust Gas Recirculation Sensor A Circuit Low
    P0406 Exhaust Gas Recirculation Sensor A Circuit High
    P0407 Exhaust Gas Recirculation Sensor B Circuit Low
    P0408 Exhaust Gas Recirculation Sensor B Circuit High
    P0410 Secondary Air Injection System Malfunction
    P0411 Secondary Air Injection System Incorrect Flow Detected
    P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
    P0413 Secondary Air Injection System Switching Valve A Circuit Open
    P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
    P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
    P0416 Secondary Air Injection System Switching Valve B Circuit Open
    P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
    P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
    P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
    P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
    P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
    P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
    P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)
    P0427 Catalyst Temperature Sensor Low Input (Bank 1)
    P0428 Catalyst Temperature Sensor High Input (Bank 1)
    P0430 Catalyst System Efficiency Below Threshold (Bank 2)
    P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
    P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
    P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
    P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
    P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)
    P0437 Catalyst Temperature Sensor Low Input (Bank 2)
    P0438 Catalyst Temperature Sensor High Input (Bank 2)
    P0440 Evaporative Emission Control System Malfunction
    P0441 Evaporative Emission Control System Incorrect Purge Flow
    P0442 Evaporative Emission Control System Leak Detected (small leak)
    P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
    P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
    P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
    P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
    P0447 Evaporative Emission Control System Vent Control Circuit Open
    P0448 Evaporative Emission Control System Vent Control Circuit Shorted
    P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
    P0450 Evaporative Emission Control System Pressure Sensor Malfunction
    P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
    P0452 Evaporative Emission Control System Pressure Sensor Low Input
    P0453 Evaporative Emission Control System Pressure Sensor High Input
    P0454 Evaporative Emission Control System Pressure Sensor Intermittent
    P0455 Evaporative Emission Control System Leak Detected (gross leak)
    P0460 Fuel Level Sensor Circuit Malfunction
    P0461 Fuel Level Sensor Circuit Range/Performance
    P0462 Fuel Level Sensor Circuit Low Input
    P0463 Fuel Level Sensor Circuit High Input
    P0464 Fuel Level Sensor Circuit Intermittent
    P0465 Purge Flow Sensor Circuit Malfunction
    P0466 Purge Flow Sensor Circuit Range/Performance
    P0467 Purge Flow Sensor Circuit Low Input
    P0468 Purge Flow Sensor Circuit High Input
    P0469 Purge Flow Sensor Circuit Intermittent
    P0470 Exhaust Pressure Sensor Malfunction
    P0471 Exhaust Pressure Sensor Range/Performance
    P0472 Exhaust Pressure Sensor Low
    P0473 Exhaust Pressure Sensor High
    P0474 Exhaust Pressure Sensor Intermittent
    P0475 Exhaust Pressure Control Valve Malfunction
    P0476 Exhaust Pressure Control Valve Range/Performance
    P0477 Exhaust Pressure Control Valve Low
    P0478 Exhaust Pressure Control Valve High
    P0479 Exhaust Pressure Control Valve Intermittent
    P0480 Cooling Fan 1 Control Circuit Malfunction
    P0481 Cooling Fan 2 Control Circuit Malfunction
    P0482 Cooling Fan 3 Control Circuit Malfunction
    P0483 Cooling Fan Rationality Check Malfunction
    P0484 Cooling Fan Circuit Over Current
    P0485 Cooling Fan Power/Ground Circuit Malfunction
    P0500 Vehicle Speed Sensor Malfunction
    P0501 Vehicle Speed Sensor Range/Performance
    P0502 Vehicle Speed Sensor Low Input
    P0503 Vehicle Speed Sensor Intermittent/Erratic/High
    P0505 Idle Control System Malfunction
    P0506 Idle Control System RPM Lower Than Expected
    P0507 Idle Control System RPM Higher Than Expected
    P0510 Closed Throttle Position Switch Malfunction
    P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
    P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
    P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
    P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
    P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
    P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
    P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
    P0533 A/C Refrigerant Pressure Sensor Circuit High Input
    P0534 Air Conditioner Refrigerant Charge Loss
    P0550 Power Steering Pressure Sensor Circuit Malfunction
    P0551 Power Steering Pressure Sensor Circuit Range/Performance
    P0552 Power Steering Pressure Sensor Circuit Low Input
    P0553 Power Steering Pressure Sensor Circuit High Input
    P0554 Power Steering Pressure Sensor Circuit Intermittent
    P0560 System Voltage Malfunction
    P0561 System Voltage Unstable
    P0562 System Voltage Low
    P0562 A/C pressure sensor low voltage(Chrysler)
    P0563 System Voltage High
    P0565 Cruise Control On Signal Malfunction
    P0566 Cruise Control Off Signal Malfunction
    P0567 Cruise Control Resume Signal Malfunction
    P0568 Cruise Control Set Signal Malfunction
    P0569 Cruise Control Coast Signal Malfunction
    P0570 Cruise Control Accel Signal Malfunction
    P0571 Cruise Control/Brake Switch A Circuit Malfunction
    P0572 Cruise Control/Brake Switch A Circuit Low
    P0573 Cruise Control/Brake Switch A Circuit High
    P0574 Cruise Control Related Malfunction
    P0575 Cruise Control Related Malfunction
    P0576 Cruise Control Related Malfunction
    P0578 Cruise Control Related Malfunction
    P0579 Cruise Control Related Malfunction
    P0580 Cruise Control Related Malfunction
    P0600 Serial Communication Link Malfunction
    P0601 Control Module Read Only Memory(ROM)
    P0602 Control Module Programming Error
    P0603 Internal Control Module Keep Alive Memory (KAM) Error
    P0604 Internal Control Module Random Access Memory (RAM) Error
    P0605 Internal Control Module Read Only Memory (ROM) Error
    P0606 PCM Processor Fault
    P0608 Control Module VSS Output "A" Malfunction
    P0609 Control Module VSS Output "B" Malfunction
    P0620 Generator Control Circuit Malfunction
    P0621 Generator Lamp "L" Control Circuit Malfunction
    P0622 Generator Field "F" Control Circuit Malfunction
    P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
    P0654 Engine RPM Output Circuit Malfunction
    P0655 Engine Hot Lamp Output Control Circuit Malfucntion
    P0656 Fuel Level Output Circuit Malfunction
    P0700 Transmission Control System Malfunction
    P0701 Transmission Control System Range/Performance
    P0702 Transmission Control System Electrical
    P0703 Torque Converter/Brake Switch B Circuit Malfunction
    P0704 Clutch Switch Input Circuit Malfunction
    P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
    P0706 Transmission Range Sensor Circuit Range/Performance
    P0707 Transmission Range Sensor Circuit Low Input
    P0708 Transmission Range Sensor Circuit High Input
    P0709 Transmission Range Sensor Circuit Intermittent
    P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
    P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
    P0712 Transmission Fluid Temperature Sensor Circuit Low Input
    P0713 Transmission Fluid Temperature Sensor Circuit High Input
    P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
    P0715 Input/Turbine Speed Sensor Circuit Malfunction
    P0716 Input/Turbine Speed Sensor Circuit Range/Performance
    P0717 Input/Turbine Speed Sensor Circuit No Signal
    P0718 Input/Turbine Speed Sensor Circuit Intermittent
    P0719 Torque Converter/Brake Switch B Circuit Low
    P0720 Output Speed Sensor Circuit Malfunction
    P0721 Output Speed Sensor Range/Performance
    P0722 Output Speed Sensor No Signal
    P0723 Output Speed Sensor Intermittent
    P0724 Torque Converter/Brake Switch B Circuit High
    P0725 Engine Speed input Circuit Malfunction
    P0726 Engine Speed Input Circuit Range/Performance
    P0727 Engine Speed Input Circuit No Signal
    P0728 Engine Speed Input Circuit Intermittent
    P0730 Incorrect Gear Ratio
    P0731 Gear 1 Incorrect ratio
    P0732 Gear 2 Incorrect ratio
    P0733 Gear 3 Incorrect ratio
    P0734 Gear 4 Incorrect ratio
    P0735 Gear 5 Incorrect ratio
    P0736 Reverse incorrect gear ratio
    P0740 Torque Converter Clutch Circuit Malfuction
    P0741 Torque Converter Clutch Circuit Performance or Stuck Off
    P0742 Torque Converter Clutch Circuit Stuck On
    P0743 Torque Converter Clutch Circuit Electrical
    P0744 Torque Converter Clutch Circuit Intermittent
    P0745 Pressure Control Solenoid Malfunction
    P0746 Pressure Control Solenoid Performance or Stuck Off
    P0747 Pressure Control Solenoid Stuck On
    P0748 Pressure Control Solenoid Electrical
    P0749 Pressure Control Solenoid Intermittent
    P0750 Shift Solenoid A Malfunction
    P0751 Shift Solenoid A Performance or Stuck Off/1-2 Shift Solenoid Valve Performance
    P0752 Shift Solenoid A Stuck On
    P0753 Shift Solenoid A Electrical/1-2 Shift Solenoid Circuit Electrical
    P0754 Shift Solenoid A Intermittent
    P0755 Shift Solenoid B Malfunction
    P0756 Shift Solenoid B Performance or Stuck Off/2-3 Shift Solenoid Valve Performance
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical/2-3 Shift Solenoid Circuit Electrical
    P0759 Shift Solenoid B Intermittent
    P0760 Shift Solenoid C Malfunction
    P0761 Shift Solenoid C Performance or Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Intermittent
    P0765 Shift Solenoid D Malfunction
    P0766 Shift Solenoid D Performance or Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Intermittent
    P0770 Shift Solenoid E Malfunction
    P0771 Shift Solenoid E Performance or Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Intermittent
    P0775 Pressure Control Solenoid B Malfunction
    P0776 Pressure Control Solenoid B Performance
    P0777 Pressure Control Solenoid B Stuck On
    P0778 Pressure Control Solenoid B Electrical
    P0779 Pressure Control Solenoid B Intermittent
    P0780 Shift Malfunction
    P0781 1-2 Shift Malfunction
    P0782 2-3 Shift Malfunction
    P0783 3-4 Shift Malfunction
    P0784 4-5 Shift Malfunction
    P0785 Shift/Timing Solenoid Malfunction/ 3-2 Shift Solenoid Circuit Electrical
    P0786 Shift/Timing Solenoid Range/Performance
    P0787 Shift/Timing Solenoid Low
    P0788 Shift/Timing Solenoid High
    P0789 Shift/Timing Solenoid Intermittent
    P0790 Normal/Performance Switch Circuit Malfunction
    P0801 Reverse Inhibit Control Circuit Malfunction
    P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
    P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
    P1100 MAF Sensor Intermittent/ Check of all OBDII Systems Not Complete
    P1101 MAF Sensor Out Of Self Test Range./KOER Not Able To Complete KOER Aborted
    P1102 MAF Sensor In Range But Lower Than Expected
    P1103 MAF Sensor In Range But Higher Than Expected
    P1104 MAF Ground Malfunction
    P1105 Dual Alternator Upper Fault
    P1106 Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
    P1107 Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
    P1108 Dual Alternator Battery Lamp Circuit Malfunction
    P1109 IAT - B Sensor Intermittent
    P1110 IAT Sensor (D/C) Open/Short
    P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
    P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
    P1113 IAT Sensor Open/Short
    P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input
    P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage/IAT - B Circuit High Input
    P1116 Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range
    P1117 Engine Coolant Sensor intermittent/ECT Sensor Intermittent
    P1118 Manifold Absolute Temperature Circuit Low Input
    P1119 Manifold Absolute Temperature Circuit High Input
    P1120 Throttle position sensor out of range
    P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
    P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
    P1123 Throttle Position Sensor In Range But Higher Than Expected
    P1124 Throttle Position Sensor Out Of Self Test Range
    P1125 Throttle position sensor intermittent
    P1126 Throttle Position (Narrow Range) Sensor Circuit Malfunction
    P1127 Exhaust Not Warm, Downstream O2 Sensor
    P1128 Upstream Heated O2 Sensors Swapped
    P1129 Downstream Heated O2 Sensors Swapped
    P1130 Lack Of HO2S Switch - Adaptive Fuel At Limit
    P1131 Lack Of HO2S Switch - Sensor Indicates Lean
    P1132 Lack Of HO2S Switch - Sensor Indicates Rich
    P1133 HO2S Insufficient Switching Sensor 1
    P1134 HO2S Transition Time Ratio Sensor 1
    P1135 Pedal Position Sensor A Circuit Intermittent
    P1136 Fan Control Circuit Malfunction
    P1137 Lack Of HO2S Switch - Sensor Indicates Lean
    P1138 Lack Of HO2S12 Switch - Sensor Indicates Rich
    P1139 Water In Fuel Indicator Circuit Malfunction
    P1140 Water In Fuel Condition
    P1141 Fuel Restriction Indicator Circuit Malfunction
    P1142 Fuel Restriction Condition
    P1143 Air Assist Control Valve Range/Performance
    P1144 Air Assist Control Valve Circuit Malfunction
    P1150 Lack Of HO2S21 Switch - Adaptive Fuel At Limit
    P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
    P1152 Lack Of HO2S21 Switch - Sensor Indicates Rich
    P1153 Bank 2 Fuel Control Shifted Lean
    P1154 Bank 2 Fuel Control Shifted Rich
    P1155 Alternative Fuel Controller
    P1156 Fuel Select Switch Malfunction
    P1157 Lack Of HO2S22 Switch - Sensor Indicates Lean
    P1158 Lack Of HO2S22 Switch - Sensor Indicates Rich
    P1159 Fuel Stepper Motor Malfunction
    P1167 Invalid Test,throttle not depressed
    P1168 Fuel Rail Sensor In-Range Low Failure
    P1169 Fuel Rail Sensor In-Range High Failure
    P1170 ESO - Engine Shut Off Solenoid Fault
    P1171 Rotor Sensor Fault
    P1172 Rotor Control Fault
    P1173 Rotor Calibration Fault
    P1174 Cam Sensor Fault
    P1175 Cam Control Fault
    P1176 Cam Calibration Fault
    P1177 Synchronization Fault
    P1178 ( open )
    P1180 Fuel Delivery System Malfunction - Low
    P1181 Fuel Delivery System Malfunction - High
    P1182 Fuel Shut Off Solenoid Malfunction
    P1183 Engine Oil Temperature Circuit Malfunction
    P1184 Engine Oil Temperature Out Of Self Test Range
    P1185 FTS High - Fuel Pump Temperature Sensor High
    P1186 FTS Low - Fuel Pump Temperature Sensor Low
    P1187 Variant Selection
    P1188 Calibration Memory Fault
    P1189 Pump Speed Signal Fault
    P1190 Calibration Resistor Out Of Range
    P1191 Key Line Voltage
    P1192 Voltage External
    P1193 EGR Drive Overcurrent
    P1194 ECU A/D Converter
    P1195 SCP HBCC Failed To Initialize
    P1196 Key Off Voltage High
    P1197 Key Off Voltage Low
    P1198 Pump Rotor Control Underfueling
    P1199 Fuel Level Input Circuit Low
    P1200 Injector Control Circuit
    P1201 Injector Circuit Open / Shorted - Cylinder #1
    P1202 Injector Circuit Open / Shorted - Cylinder #2
    P1203 Injector Circuit Open / Shorted - Cylinder #3
    P1204 Injector Circuit Open / Shorted - Cylinder #4
    P1205 Injector Circuit Open / Shorted - Cylinder #5
    P1206 Injector Circuit Open / Shorted - Cylinder #6
    P1209 Injector Control Pressure System Fault
    P1210 Injector Control Pressure Above Expected Level
    P1211 Injector Control Pressure Sensor Above / Below Desired
    P1212 Injector Control Pressure Not Detected During Crank
    P1213 Start Injector Circuit Malfunction
    P1214 Pedal Position Sensor B Circuit Intermittent
    P1215 Pedal Position Sensor C Circuit Low Input
    P1216 Pedal Position Sensor C Circuit High Input
    P1217 Pedal Position Sensor C Circuit Intermittent
    P1218 CID High
    P1219 CID Low
    P1220 Series Throttle Control System Malfunction
    P1221 Traction Control System Malfunction
    P1222 Traction Control Output Circuit Malfunction
    P1223 Pedal Demand Sensor B Circuit High Input
    P1224 Throttle Position Sensor B Out Of Self Test Range
    P1225 Needle Lift Sensor Malfunction
    P1226 Control Sleeve Sensor Malfunction
    P1227 Wastegate Failed Closed (Over Pressure)
    P1228 Wastegate Failed Open (Under Pressure)
    P1229 Intercooler Pump Driver Fault
    P1230 Fuel Pump Low Speed Malfunction
    P1231 Fuel Pump Secondary Circuit Low, High Speed
    P1232 Fuel Pump Speed Primary Circuit Malfunction
    P1233 Fuel Pump Driver Module Off Line
    P1234 Fuel Pump Driver Module Off Line
    P1235 Fuel Pump Control Out Of Range
    P1236 Fuel Pump Control Out Of Range
    P1237 Fuel Pump Secondary Circuit Malfunction
    P1238 Fuel Pump Secondary Circuit Malfunction
    P1239 Speed Fuel Pump Positive Feed Fault
    P1240 Sensor Power Supply Malfunction
    P1241 Sensor Power Supply Low Input
    P1242 Sensor Power Supply High Input
    P1243 Second Fuel Pump Faulty or Ground Fault
    P1244 Alternator Load Input Failed High
    P1245 Alternator Load Input Failed Low
    P1246 Alternator Load Input Failed
    P1247 Turbo Boost Pressure Low
    P1248 Turbo Boost Pressure Not Detected
    P1249 Wastegate Control Valve Performance
    P1250 PRC Solenoid Circuit Malfunction
    P1251 Air Mixture Solenoid Circuit Malfunction
    P1252 Pedal Correlation PDS1 and LPDS High
    P1253 Pedal Correlation PDS1 and LPDS Low
    P1254 Pedal Correlation PDS2 and LPDS High
    P1255 Pedal Correlation PDS2 and LPDS Low
    P1256 Pedal Correlation PDS1 and HPDS
    P1257 Pedal Correlation PDS2 and HPDS
    P1258 Pedal Correlation PDS1 and PDS2
    P1259 Immobilizer to PCM Signal Error
    P1260 THEFT Detected, Vehicle Immobilzed
    P1261 Cylinder #1 High To Low Side Short
    P1262 Cylinder #2 High To Low Side Short
    P1263 Cylinder #3 High To Low Side Short
    P1264 Cylinder #4 High To Low Side Short
    P1265 Cylinder #5 High To Low Side Short
    P1266 Cylinder #6 High To Low Side Short
    P1267 Cylinder #7 High To Low Side Short
    P1268 Cylinder #8 High To Low Side Short
    P1269 Immobilizer Code Not Programmed
    P1270 Engine RPM Or Speed Limiter Reached
    P1271 Cylinder #1 High To Low Side Open
    P1272 Cylinder #2 High To Low Side Open
    P1273 Cylinder #3 High To Low Side Open
    P1274 Cylinder #4 High To Low Side Open
    P1275 Cylinder #5 High To Low Side Open
    P1276 Cylinder #6 High To Low Side Open
    P1277 Cylinder #7 High To Low Side Open
    P1278 Cylinder #8 High To Low Side Open
    P1280 Injection Control Pressure Out Of Range Low
    P1281 Injection Control Pressure Out Of Range High
    P1282 Excessive Injection Control Pressure
    P1283 IPR Circuit Failure
    P1284 Aborted KOER - ICP Failure
    P1285 Cylinder head over temp sensed
    P1286 Fuel Pulse In Range But Lower Than Expected
    P1287 Fuel Pulse In Range But Higher Than Expected
    P1288 Cylinder Head Temp Sensor Out Of Self Test Range
    P1289 Cylinder Head Temp Sensor High Input
    P1290 Cylinder Head Temp Sensor Low Input
    P1291 Injector High Side Short To GND Or VBATT - Bank 1
    P1292 Injector High Side Short To GND Or VBATT - Bank 2
    P1293 Injector High Side Open - Bank 1
    P1294 Injector High Side Open - Bank 2/Target idle not reached
    P1295 Multi-faults - Bank 1 - With Low Side Shorts
    P1296 Multi-faults - Bank 2 - With Low Side Shorts
    P1297 Injector High Sides Shorted Together
    P1298 IDM Failure
    P1299 Cylinder Head Overtemperature Protection Active
    P1300 Boost Calibration Fault
    P1301 Boost Calibration High
    P1302 Boost Calibration Low
    P1303 EGR Calibration Fault
    P1304 EGR Calibration High
    P1305 EGR Calibration Low
    P1306 Kickdown Relay Pull - In Circuit Fault
    P1307 Kickdown Relay Hold Circuit Fault
    P1308 A/C Clutch Circuit Fault
    P1309 Misfire Monitor AICE Chip Fault
    P1313 Misfire Rate Catalyst Damage Fault - Bank 1
    P1314 Misfire Rate Catalyst Damage Fault - Bank 2
    P1315 Persistent Misfire
    P1316 Injector Circuit / IDM Codes Detected
    P1317 Injector Circuit / IDM Codes Not Updated
    P1336 Crank / Cam Sensor Range / Performance
    P1340 Camshaft Position Sensor B Circuit Malfunction
    P1341 Camshaft Position Sensor B Range / Performance
    P1345 SGC (Cam Position) Sensor Circuit Malfunction/ Crankshaft Position - Camshaft Position Correlation
    P1346 Fuel Level Sensor B Circuit Malfunction
    P1347 Fuel Level Sensor B Range / Performance
    P1348 Fuel Level Sensor B Circuit Low
    P1349 Fuel Level Sensor B Circuit High
    P1350 Fuel Level Sensor B Intermittent/Bypass Line Monitor
    P1351 IDM Input Circuit Malfunction/ Ignition Coil Control Circuit High Voltage
    P1352 Ignition Coil A Primary Circuit Malfunction
    P1353 Ignition Coil B Primary Circuit Malfunction
    P1354 Ignition Coil C Primary Circuit Malfunction
    P1355 Ignition Coil D Primary Circuit Malfunction
    P1360 Ignition Coil A Secondary Circuit Malfunction
    P1361 Ignition Control (IC) Circuit Low Voltage
    P1362 Ignition Coil C Secondary Circuit Malfunction
    P1363 Ignition Coil D Secondary Circuit Malfunction
    P1364 Ignition Coil Primary Circuit Failure
    P1365 Ignition Coil Secondary Circuit Failure
    P1366 Ignition Spare
    P1367 Ignition Spare
    P1368 Ignition Spare
    P1369 Engine Temperature Light Monitor Failure
    P1370 Insufficient RMP Increase During Spark Test
    P1371 Ignition Coil - Cylinder 1 - Early Activation Fault
    P1372 Ignition Coil - Cylinder 2 - Early Activation Fault
    P1373 Ignition Coil - Cylinder 3 - Early Activation Fault
    P1374 Crankshaft Position (CKP)/Ignition Coil - Cylinder 4 - Early Activation Fault
    P1375 Ignition Coil - Cylinder 5 - Early Activation Fault
    P1376 Ignition Coil - Cylinder 6 - Early Activation Fault
    P1380 Misfire Detected - Rough Road Data Not Available
    P1381 Variable Cam Timing Overadvanced (Bank #1)/ Misfire Detected - No Communication with BCM
    P1382 Variable Cam Timing Solenoid #1 Circuit Malfunction
    P1383 Variable Cam Timing Overretarded (Bank #1)
    P1384 VVT Solenoid A Malfunction
    P1385 Variable Cam Timing Solenoid B Malfunction
    P1386 Variable Cam Timing Overadvanced (Bank #2)
    P1387 Variable Cam Timing Solenoid #2 Circuit Malfunction
    P1388 Variable Cam Timing Overretarded (Bank #2)
    P1389 Glow Plug Circuit High Side Low Input
    P1390 Octane Adjust Pin Out Of Self Test Range
    P1391 Glow Plug Circuit Low Input (Bank #1)
    P1392 Glow Plug Circuit High Input (Bank #1)
    P1393 Glow Plug Circuit Low Input (Bank #2)
    P1394 Glow Plug Circuit High Input (Bank #2)
    P1395 Glow Plug Monitor Fault (Bank #1)
    P1396 Glow Plug Monitor Fault (Bank #2)
    P1397 System Voltage Out Of Self Test Range
    P1398 VVT Solenoid B Circuit High Input
    P1399 Glow Plug Circuit High Side, High Input
    P1400 DPFE Circuit Low Input
    P1401 DPFE Circuit High Input
    P1402 EGR Metering Orifice Restricted
    P1403 DPFE Sensor Hoses Reversed
    P1404 IAT - B Circuit Malfunction/ Exhaust Gas Recirculation Closed Position Performance
    P1405 DPFE Sensor Upstream Hose Off Or Plugged
    P1406 Exhaust Gas Recirculation (EGR) Position Sensor Performance
    P1407 EGR No Flow Detected
    P1408 EGR Flow Out Of Self Test Range
    P1409 EVR Control Circuit Malfunction
    P1411 SAI System Incorrect Downstream Flow Detected
    P1413 SAI System Monitor Circuit Low Input
    P1414 SAI System Monitor Circuit High Input
    P1415 Air Pump Circuit Malfunction/ (AIR) System Bank 1
    P1416 Port Air Circuit Malfunction/ (AIR) System Bank 2
    P1417 Port Air Relief Circuit Malfunction
    P1418 Split Air #1 Circuit Malfunction
    P1419 Split Air #2 Circuit Malfunction
    P1420 Catalyst Temperature Sensor Failure
    P1421 Catalyst Damage
    P1422 EGI Temperature Sensor Failure
    P1423 EGI Functionality Test Failed
    P1424 EGI Glow Plug Primary Failure
    P1425 EGI Glow Plug Secondary Failure
    P1426 EGI Mini - MAF Failed Out Of Range
    P1427 EGI Mini - MAF Failed Short Circuit
    P1428 EGI Mini - MAF Failed Open Circuit
    P1429 Electric Air Pump Primary Failure
    P1430 Electric Air Pump Secondary Failure
    P1433 A/C Refrigerant Temperature Circuit Low
    P1434 A/C Refrigerant Temperature Circuit High
    P1435 A/C Refrigerant Temperature Circuit Range/Performance
    P1436 A/C Evaporator Air Temperature Circuit Low
    P1437 A/C Evaporator Air Temperature Circuit High
    P1438 A/C Evaporator Air Temperature Circuit Range/Performance
    P1439 Floor Temperature Switch Circuit Malfunction
    P1440 Purge Valve Stuck Open
    P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Chevrolet Only
    P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Oldsmobile Only
    P1442 Evaporative Emission Control System Leak Detected
    P1443 Evaporative Emission Control System Control Valve
    P1444 Purge Flow Sensor Circuit Low Input
    P1445 Purge Flow Sensor Circuit High Input
    P1446 Evaporative Vac Solenoid Circuit Malfunction
    P1447 ELC System Closure Valve Flow Fault
    P1448 ELC System 2 Fault
    P1449 Evaporative Check Solenoid Circuit Malfunction
    P1450 Unable To Bleed Up Fuel Tank Vacuum
    P1451 Evap Emission Control Sys Vent Control Valve Circuit
    P1452 Unable To Bleed - Up Vacuum in Tank
    P1453 Fuel Tank Pressure Relief Valve Malfunction
    P1454 Evaporative System Vacuum Test Malfunction
    P1455 Evap Emission Control Sys Leak Detected (Gross Leak/No Flow)
    P1456 Fuel Tank Temperature Sensor Circuit Malfunction
    P1457 Unable To Pull Vacuum In Tank
    P1460 Wide open throttle A/C cutoff relay circuit
    P1461 A/C pressure sensor circuit voltage low
    P1462 A/C pressure sensor circuit voltage high
    P1463 A/C Pressure Sensor Insufficient Pressure Change
    P1464 A/C Demand Out of Self Test Range
    P1465 A/C Relay Circuit Malfunction
    P1466 A/C Refrigerant Temperature Sensor/Circuit Malfunction
    P1467 A/C Compressor Temperature Sensor Malfunction
    P1468 SSPOD Open Circuit or Closed Circuit Fault
    P1469 Low A/C Cycling Period
    P1470 A/C Cycling Period Too Short
    P1471 Electrodrive Fan 1 Operational Failure (Driver Side)
    P1472 Electrodrive Fan 2 Operational Failure (Passenger Side)
    P1473 Fan Secondary High With Fan(s) Off
    P1474 Low Fan Control Primary Circuit Malfunction
    P1475 Fan Relay (Low) Circuit Malfunction
    P1476 Fan Relay (High) Circuit Malfunction
    P1477 Additional Fan Relay Circuit Malfunction
    P1478 Cooling Fan Driver Fault
    P1479 High Fan Control Primary Circuit Malfunction
    P1480 Fan Secondary Low with Low Fan On
    P1481 Fan Secondary Low With High Fan On
    P1482 SCP
    P1483 Power To Fan Circuit Overcurrent
    P1484 Open Power To Ground VCRM
    P1485 EGRV Circuit Malfunction
    P1486 EGRA Circuit Malfunction
    P1487 EGRCHK Solenoid Circuit Malfunction
    P1490 Secondary Air Relief Solenoid Circuit Malfunction
    P1491 Secondary Switch Solenoid Circuit Malfunction
    P1492 APLSOL Solenoid Circuit Malfunction
    P1493 RCNT Solenoid Circuit Malfunction
    P1494 SPCUT Solenoid Circuit Malfunction
    P1495 TCSPL Solenoid Circuit Malfunction
    P1500 Vehicle Speed Sensor Intermittent
    P1501 Vehicle Speed Sensor Out Of Self Test Range
    P1502 Vehicle Speed Sensor Intermittent Malfunction
    P1503 Auxillary Speed Sensor Fault
    P1504 Idle Air Control Circuit Malfunction
    P1505 Idle Air Control System At Adaptive Clip
    P1506 Idle Air Control Overspeed Error
    P1507 Idle Air Control Underspeed Error
    P1508 Idle Control System Circuit Open
    P1509 Idle Control System Circuit Shorted
    P1510 Idle Signal Circuit Malfunction
    P1511 Idle Switch (Electric Control Throttle) Circuit Malfunction
    P1512 Intake Manifold Runner Control (Bank 1) Stuck Closed
    P1513 Intake Manifold Runner Control (Bank 2) Stuck Closed
    P1514 High Load Neutral/Drive Fault
    P1515 Electric Current Circuit Malfunction
    P1516 IMRC Input Error (Bank 1)
    P1517 IMRC Input Error (Bank 2)
    P1518 Intake Manifold Runner Control (Stuck Open)
    P1519 Intake Manifold Runner Control (Stuck Closed)
    P1520 Intake Manifold Runner Control Circuit Malfunction
    P1521 Variable Intake Solenoid #1 Circuit Malfunction
    P1522 Variable Intake Solenoid #2 Circuit Malfunction
    P1523 IVC Solenoid Circuit Malfunction
    P1524 Variable Intake Solenoid System
    P1525 Air Bypass Valve System
    P1526 Air Bypass System
    P1527 Accelerate Warmup Solenoid Circuit Malfunction
    P1528 Subsidiary Throttle Valve Solenoid Circuit Malfunction
    P1529 SCAIR Solenoid Circuit Malfunction
    P1530 A/C Clutch Circuit Malfunction
    P1531 Invalid Test - Accelerator Pedal Movement
    P1532 IMCC Circuit Malfunction, Bank B
    P1533 AAI Circuit Malfunction
    P1534 Inertia Switch Activated
    P1535 Blower Fan Speed Circuit Range/Performance
    P1536 Parking Brake Switch Circuit Failure
    P1537 Intake Manifold Runner Control (Bank 1) Stuck Open
    P1538 Intake Manifold Runner Control (Bank 2) Stuck Open
    P1539 Power To A/C Clutch Circuit Overcurrent
    P1540 Air Bypass Valve Circuit Malfunction
    P1549 IMCC Circuit Malfunction, Bank B
    P1550 PSPS Out Of Self Test Range
    P1565 Speed Control Command Switch Out of Range High
    P1566 Speed Control Command Switch Out of Range Low
    P1567 Speed Control Output Circuit Continuity
    P1568 Speed Control Unable to Hold Speed
    P1571 Brake Switch Malfunction
    P1572 Brake Pedal Switch Circuit Malfunction
    P1573 Throttle Position Not Available
    P1574 Throttle Position Sensor Disagreement btwn Sensors
    P1575 Pedal Position Out of Self Test Range
    P1576 Pedal Position Not Available
    P1577 Pedal Position Sensor Disagreement btwn Sensors
    P1578 ETC Power Less Than Demand
    P1579 ETC In Power Limiting Mode
    P1580 Electronic Throttle Monitor PCM Override
    P1581 Electronic Throttle Monitor Malfunction
    P1582 Electronic Throttle Monitor Data Available
    P1583 Electronic Throttle Monitor Cruise Disable
    P1584 TCU Detected IPE Circuit Malfunction
    P1585 Throttle Control Unit Malfunction
    P1586 Throttle Control Unit Throttle Position Malfunction
    P1587 Throttle Control Unit Modulated Command Malfunction
    P1588 Throttle Control Unit Detected Loss of Return Spring
    P1589 TCU Unable To Control Desired Throttle Angle
    P1600 Loss of KAM Power; Open Circuit
    P1601 ECM/TCM Serial Communication Error
    P1602 Immobilizer/ECM Communication Error
    P1603 EEPROM Malfunction
    P1604 Code Word Unregestered
    P1605 Keep Alive Memory Test Failure
    P1606 ECM Control Relay O/P Circuit Malfunction
    P1607 MIL O/P Circuit Malfunction
    P1608 Internal ECM Malfunction
    P1609 Diagnostic Lamp Driver Fault
    P1610 SBDS Interactive Codes
    P1611 SBDS Interactive Codes
    P1612 SBDS Interactive Codes
    P1613 SBDS Interactive Codes
    P1614 SBDS Interactive Codes
    P1615 SBDS Interactive Codes
    P1616 SBDS Interactive Codes
    P1617 SBDS Interactive Codes
    P1618 SBDS Interactive Codes
    P1619 SBDS Interactive Codes
    P1620 SBDS Interactive Codes
    P1621 Control Module Long Term Memory Performance/ Immobilizer Code Words Do Not Match
    P1622 Immobilizer ID Does Not Match
    P1623 Immobilizer Code Word/ID Number Write Failure
    P1624 Anti Theft System
    P1625 B+ Supply To VCRM Fan Circuit Malfunction
    P1626 Theft Deterrent Fuel Enable Signal Not Received/ B+ Supply To VCRM A/C Circuit Malfunction
    P1627 Module Supply Voltage Out Of Range
    P1628 Module Ignition Supply Input Malfunction
    P1629 Internal Voltage Regulator Malfunction
    P1630 Internal Vref Malfunction
    P1631 Theft Deterrent Start Enable Signal Not Correct/ Main Relay Malfunction (Power Hold)
    P1632 Smart Alternator Faults Sensor/Circuit Malfunction
    P1633 KAM Voltage Too Low
    P1634 Data Output Link Circuit Failure
    P1635 Tire / Axle Ratio Out of Acceptable Range
    P1636 Inductive Signature Chip Communication Error
    P1637 Can Link ECM/ABSCM Circuit / Network Malfunction
    P1638 Can Link ECM/INSTM Circuit / Network Malfunction
    P1639 Vehicle ID Block Corrupted or Not Programmed
    P1640 Powertrain DTCs Available in Another Module
    P1641 Fuel Pump Primary Circuit Failure
    P1642 Fuel Pump Monitor Circuit High Input
    P1643 Fuel Pump Monitor Circuit Low Input
    P1644 Fuel Pump Speed Control Circuit Malfunction
    P1645 Fuel Pump Resistor Switch Circuit Malfunction
    P1650 PSP Switch Out of Self Test Range
    P1651 PSP Switch Input Malfunction
    P1652 IAC Monitor Disabled by PSP Switch Failed On
    P1653 Power Steering Output Circuit Malfunction
    P1654 Recirculation Override Circuit Malfunction
    P1655 Starter Disable Circuit Malfunction
    P1660 Output Circuit Check Signal High
    P1661 Output Circuit Check Signal Low
    P1662 IDM_EN Circuit Failure
    P1663 Fuel Demand Command Signal Circuit Malfunction
    P1667 CI Circuit Malfunction
    P1668 PCM - IDM Communications Error
    P1670 Electronic Feedback Signal Not Detected
    P1680 Metering Oil Pump Malfunction
    P1681 Metering Oil Pump Malfunction
    P1682 Metering Oil Pump Malfunction
    P1683 Metering Oil Pump Temperature Sensor Circuit Malfunction
    P1684 Metering Oil Pump Position Sensor Circuit Malfunction
    P1685 Metering Oil Pump Stepping Motor Circuit Malfunction
    P1686 Metering Oil Pump Stepping Motor Circuit Malfunction
    P1687 Metering Oil Pump Stepping Motor Circuit Malfunction
    P1688 Metering Oil Pump Stepping Motor Circuit Malfunction
    P1689 Oil Pressure Control Solenoid Circuit Malfunction
    P1690 Wastegate Solenoid Circuit Malfunction
    P1691 Turbo Pressure Control Solenoid Circuit Malfunction
    P1692 Turbo Control Solenoid Circuit Malfunction
    P1693 Turbo Charge Control Circuit Malfunction
    P1694 Turbo Charge Relief Circuit Malfunction
    P1700 Transmission Indeterminate Failure (Failed to Neutral)
    P1701 Reverse Engagement Error
    P1702 TRS Circuit Intermittent Malfunction
    P1703 Brake Switch Out Of Self Test Range
    P1704 Digital TRS Failed to Transition States in KOEO / KOER
    P1705 Not in P or N During KOEO / KOER
    P1706 High Vehicle Speed Observed in Park
    P1707 Transfer Case Neutral Indicator Hard Fault Present
    P1708 Clutch Switch Circuit Malfunction
    P1711 TFT Sensor Out Of Self Test Range
    P1712 Trans Torque Reduction Request Signal Malfunction
    P1713 TFT Sensor In Range Failure Low Value
    P1714 SSA Inductive Signature Malfunction
    P1715 SSB Inductive Signature Malfunction
    P1716 SSC Inductive Signature Malfunction
    P1717 SSD Inductive Signature Malfunction
    P1718 TFT Sensor In Range Failure High
    P1720 Vehicle Speed (Meter) Circuit Malfunction
    P1721 Gear 1 Incorrect Ratio
    P1722 Gear 2 Incorrect Ratio
    P1723 Gear 3 incorrect Ratio
    P1724 Gear 4 Incorrect Ratio
    P1725 Insufficient Engine Speed Increase During Self Test
    P1726 Insufficient Engine Speed Decrease During Self Test
    P1727 Coast Clutch Solenoid Inductive Signature Malfunction
    P1728 Transmission Slip Error
    P1729 4x4 Low Switch Error
    P1730 Gear Control Malfunction 2,3,5
    P1731 1-2 Shift Malfunction
    P1732 2-3 Shift Malfunction
    P1733 3-4 Shift Malfunction
    P1734 Gear Control Malfunction
    P1735 First Gear Switch Circuit Malfunction
    P1736 Second Gear Switch Circuit Malfunction
    P1737 Lockup Solenoid System
    P1738 Shift Time Error
    P1739 Slip Solenoid System
    P1740 Torque Converter Clutch Inductive Signature Malfunction
    P1741 Torque Converter Clutch Control Error
    P1742 Torque Converter Clutch Solenoid Failed On
    P1743 Torque Converter Clutch Solenoid Failied On
    P1744 Torque Converter Clutch System Performance
    P1745 Line Pressure Solenoid System
    P1746 Pressure Control Solenoid "A" Open Circuit
    P1747 Pressure Control Solenoid "A" Short Circuit
    P1748 EPC Malfunction
    P1749 Pressure Control Solenoid Failed Low
    P1751 Shift Solenoid A Performance
    P1754 Coast Clutch Solenoid Circuit Malfunction
    P1755 Intermediate Speed Sensor (ISS) Malfunction
    P1756 Shift Solenoid B Performance
    P1760 Pressure Control Solenoid "A" Short Circuit
    P1761 Shift Solenoid C Performance
    P1762 Overdrive Band Failed Off
    P1765 Timing Solenoid Circuit Malfunction
    P1767 Torque Converter Clutch Circuit Malfunction
    P1768 Performance / Normal / Winter Mode Input Malfunction
    P1769 AG4 Transmission Torque Modulation Fault
    P1770 Clutch Solenoid Circuit Malfunction
    P1775 Transmission System MIL Fault
    P1776 Ignition Retard Request Duration Fault
    P1777 Ignition Retard Request Circuit Fault
    P1778 Transmission Reverse I/P Circuit Malfunction
    P1779 TCIL Circuit Malfunction
    P1780 Trans Control Switch (O/D Cancel) Out of Self Test Range
    P1781 4X4 Switch Out of Self Test Range
    P1782 P/ES Circuit Out Of Self Test Range
    P1783 Transmission Overtemperature Condition
    P1784 Transmission Mechanical Failure - First And Reverse
    P1785 Transmission Mechanical Failure - First And Second
    P1786 3-2 Downshift Error
    P1787 2-1 Downshift Error
    P1788 Pressure Control Solenoid "B" Open Circuit
    P1789 Pressure Control Solenoid "B" Short Circuit
    P1790 TP (Mechanical) Circuit Malfunction
    P1791 TP (Electric) Circuit Malfunction
    P1792 Barometer Pressure Circuit Malfunction
    P1793 Intake Air Volume Circuit Malfunction
    P1794 Battery Voltage Circuit Malfunction
    P1795 Idle Switch Circuit Malfunction
    P1796 Kick Down Switch Circuit Malfunction
    P1797 Neutral Switch Circuit Malfunction
    P1798 Coolant Temperature Circuit Malfunction
    P1799 Hold Switch Circuit Malfunction
    P1800 Transmission Clutch Interlock Safety Switch Circuit Failure
    P1801 Transmission Clutch Interlock Safety Switch Open Circuit
    P1802 Transmission Clutch Interlock Safety Switch Short Circuit To Battery
    P1803 Transmission Clutch Interlock Safety Switch Short Circuit To Ground
    P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure
    P1805 Transmission 4-Wheel Drive High Indicator Open Circuit
    P1806 Transmission 4-Wheel Drive High Indicator Short Circuit To Battery
    P1807 Transmission 4-Wheel Drive High Indicator Short Circuit To Ground
    P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure
    P1809 Transmission 4-Wheel Drive Low Indicator Open Circuit
    P1810 TFP Valve Position Switch Circuit/ Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery
    P1811 Transmission 4-Wheel Drive Low Indicator Short Circuit To Ground
    P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure
    P1813 Transmission 4-Wheel Drive Mode Select Open Circuit
    P1814 Transmission 4-Wheel Drive Mode Select Short Circuit To Battery
    P1815 Transmission 4-Wheel Drive Mode Select Short Circuit To Ground
    P1816 Transmission Neutral Safety Switch Circuit Failure
    P1817 Transmission Neutral Safety Switch Open Circuit
    P1818 Transmission Neutral Safety Switch Short Circuit To Battery
    P1819 Transmission Neutral Safety Switch Short Circuit To Ground
    P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure
    P1821 Transmission Transfer Case Clockwise Shift Relay Coil Open Circuit
    P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery
    P1823 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground
    P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure
    P1825 Transmission 4-Wheel Drive Clutch Relay Open Circuit
    P1826 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery
    P1827 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Ground
    P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure
    P1829 Transmission Transfer Case Counter Clockwise Shift Relay Coil Open Circuit
    P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
    P1831 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Ground
    P1832 Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
    P1833 Transmission Transfer Case Differential Lock-Up Solenoid Open Circuit
    P1834 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Battery
    P1835 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Ground
    P1836 Transmission Transfer Case Front Shaft Speed Sensor Circuit Failure
    P1837 Transmission Transfer Case Rear Shaft Speed Sensor Circuit Failure
    P1838 Transmission Transfer Case Shift Motor Circuit Failure
    P1839 Transmission Transfer Case Shift Motor Open Circuit
    P1840 Transmission Transfer Case Shift Motor Short Circuit To Battery
    P1841 Transmission Transfer Case Shift Motor Short Circuit To Ground
    P1842 Transmission Transfer Case Differential Lock-Up Feedback Switch Circuit Failure
    P1843 Transmission Transfer Case Differential Lock-Up Feedback Switch Open Circuit
    P1844 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Battery
    P1845 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Ground
    P1846 Transmission Transfer Case Contact Plate 'A' Circuit Failure
    P1847 Transmission Transfer Case Contact Plate 'A' Open Circuit
    P1848 Transmission Transfer Case Contact Plate 'A' Short Circuit To Battery
    P1849 Transmission Transfer Case Contact Plate 'A' Short Circuit To Ground
    P1850 Transmission Transfer Case Contact Plate 'B' Circuit Failure
    P1851 Transmission Transfer Case Contact Plate 'B' Open Circuit
    P1852 Transmission Transfer Case Contact Plate 'B' Short Circuit To Battery
    P1853 Transmission Transfer Case Contact Plate 'B' Short Circuit To Ground
    P1854 Transmission Transfer Case Contact Plate 'C' Circuit Failure
    P1855 Transmission Transfer Case Contact Plate 'C' Open Circuit
    P1856 Transmission Transfer Case Contact Plate 'C' Short Circuit To Battery
    P1857 Transmission Transfer Case Contact Plate 'C' Short Circuit To Ground
    P1858 Transmission Transfer Case Contact Plate 'D' Circuit Failure
    P1859 Transmission Transfer Case Contact Plate 'D' Open Circuit
    P1860 TCC PWM Solenoid Circuit Electrical/ Transmission Transfer Case Contact Plate 'D' Short Circuit To Battery
    P1861 Transmission Transfer Case Contact Plate 'D' Short Circuit To Ground
    P1862 Transmission Transfer Case Contact Plate Power Circuit Failure
    P1863 Transmission Transfer Case Contact Plate Power Open Circuit
    P1864 Transmission Transfer Case Contact Plate Power Short To Battery
    P1865 Transmission Transfer Case Contact Plate Power Short To Ground
    P1866 Transmission Transfer Case System Concern - Servicing Required
    P1867 Transmission Transfer Case Contact Plate General Circuit Failure
    P1868 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Failure
    P1869 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Short To Battery
    P1870 Transmission Component Slipping/ Transmission Mechanical Transfer Case 4x4 Switch Circuit Failure
    P1871 Transmission Mechanical Transfer Case 4x4 Switch Circuit Short To Battery
    P1872 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Failure
    P1873 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Short To Battery
    P1874 Transmission Automatic Hall Effect Sensor Power Circuit Failure
    P1875 Transmission Automatic Hall Effect Sensor Power Circuit Short To Battery / 4WD Low Switch Circuit Electrical
    P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure
    P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short To Battery
    P1878 Transmission Transfer Case Disengaged Solenoid Circuit Failure
    P1879 Transmission Transfer Case Disengaged Solenoid Open Circuit
    P1880 Transmission Transfer Case Disengaged Solenoid Short to Battery
    P1881 Engine Coolant Level Switch Circuit Failure, GEM
    P1882 Engine Coolant Level Switch Circuit Short to Ground
    P1883 Engine Coolant Level Switch Circuit Failure, GEM
    P1884 Engine Coolant Level Lamp Circuit Short to Ground
    P1885 Transmission Transfer Case Disengaged Solenoid Short to Ground
    P1886 4X4 Initialization Failure
    P1890 Transmission 4WD Mode Select Return Input Circuit Failure
    P1891 Transmission Transfer Case Contact Plate Ground Return Open Circuit
    P1900 OSS Circuit Intermittent Malfunction
    P1901 TSS Circuit Intermittent Malfunction
    P1902 Pressure Control Solenoid "B" Intermittent Short
    P1903 Pressure Control Solenoid "C" Short Circuit
    P1904 Pressure Control Solenoid "C" Open Circuit
    P1905 Pressure Control Solenoid "C" Intermittent Short
    P1906 Kickdown Pull Relay Open or Short Circuit to Ground
    P1907 Kickdown Hold Relay Open or Short Circuit to Ground
    P1908 Transmission Pressure Circuit Solenoid Open or Short to Ground
    P1909 Trans Temp Sensor Circuit Open or Shorted to Pwr or Gnd
    P1910 VFS A Pressure Output Failed Low
    P1911 VFS B Pressure Output Failed Low
    P1912 VFS C Pressure Output Failed Low
    P1913 Pressure Switch A Circuit Malfunction
    P1914 Manually Shifted Automatic (MSA) Sw Circuit Malf
    P1915 Reverse Switch Circuit Malfunction
    P1916 High Clutch Drum Speed Sensor Malfunction
    P1917 High Clutch Drum Speed Sensor Intermittent
    P1918 Transmission Range Display Circuit Malfunction
    C1091 Speed Wheel Sensor All Coherency Failure
    C1095 ABS Hydraulic Pump Motor Circuit Failure
    C1096 ABS Hydraulic Pump Motor Circuit Open
    C1097 ABS Hydraulic Pump Motor Circuit Short To Ground
    C1098 ABS Hydraulic Pump Motor Circuit Short To Battery
    C1100 ABS Pump Switch Circuit Failure
    C1101 ABS Hydraulic Valve Circuit Failure
    C1102 ABS Acceleration Switch Circuit Failure
    C1103 ABS Hydraulic Brake Switch Circuit Failure
    C1104 Traction Control Active Lamp - Circuit Short to Battery
    C1105 Traction Control Disable Lamp - Circuit Short to Battery
    C1106 Traction Control Disable Switch Circuit Short to Battery
    C1107 ABS Function Enabled Input Circuit Failure
    C1109 Speed Control Actuator Assembly Cable Release Failure
    C1110 ABS Power Relay Coil Circuit Failure
    C1111 ABS Power Relay Coil Open Circuit
    C1112 ABS Power Relay Coil Short Circuit To Ground
    C1113 ABS Power Relay Coil Short Circuit To Battery
    C1114 ABS Power Relay Output Short Circuit To Ground
    C1115 ABS Power Relay Output Short Circuit To Battery
    C1116 Starter Motor Circuit Failure
    C1117 RPM Input Circuit Failure
    C1123 Vehicle Speed Sensor Input Short to Battery
    C1124 Input shaft speed signal missing/faulted
    C1125 Brake Fluid Level Sensor Input Circuit Failure
    C1126 Cruise Control Command Switch Assembly Circuit Failure
    C1127 Cruise Control Deactivator Brake Switch Circuit Failure
    C1132 Clutch position ckt short to ground
    C1133 Clutch position ckt short to battery
    C1134 Gear Shift position short to ground
    C1135 Gear Shift position short to battery
    C1136 Gear Select position short to ground
    C1137 ECU is Defective
    C1138 Gear Select position short to Battery
    C1139 Wheel Speed Sensor Center Tone Ring Missing Tooth Fault
    C1140 Hydraulic Base Brake Failure
    C1141 Wheel Speed Sensor LF Tone Ring Tooth Missing Fault
    C1142 Wheel Speed Sensor RF Tone Ring Tooth Missing Fault
    C1143 Wheel Speed Sensor LR Tone Ring Tooth Missing Fault
    C1144 Wheel Speed Sensor RR Tone Ring Tooth Missing Fault
    C1145 Speed Wheel Sensor RF Input Circuit Failure
    C1146 Speed Wheel Sensor RF Circuit Open
    C1148 Speed Wheel Sensor RF Coherency Fault
    C1149 Hydraulic Fluid Pressure/ Flow Circuit Failure
    C1150 Two Speed Rear Axle Input Switch Circuit Short to Vbatt
    C1155 Speed Wheel Sensor LF Input Circuit Failure
    C1156 Speed Wheel Sensor LF Circuit Open
    C1157 Park Brake Actuator Assembly Switch Applied Circuit Failure
    C1158 Speed Wheel Sensor LF Coherency Fault
    C1159 Hydraulic Fluid Pressure/ Flow Circuit Short to Gnd
    C1161 Air Pressure Low Circuit Short to Gnd
    C1162 Park Brake Switch # 2 Released Circuit Failure
    C1163 Park Brake Switch # 2 Applied Circuit Short to Gnd
    C1164 Park Brake Actuator Assembly Switch Circuit Failure
    C1165 Speed Wheel Sensor RR Input Circuit Failure
    C1166 Speed Wheel Sensor RR Input Open Circuit
    C1167 Park Brake Actuator Assembly Switch Released Circuit Short to Gnd
    C1168 Speed Wheel Sensor RR Coherency Fault
    C1169 ABS Fluid Dumping Exceeds Maximum Timing
    C1170 PRNDL Switch Circuit Failure
    C1172 Park Brake Switch # 1 Applied Circuit Failure
    C1173 Park Brake Switch # 1 Released Circuit Short to Gnd
    C1174 Park Brake Switch # 2 Applied Circuit Failure
    C1175 Speed Wheel Sensor LR Input Circuit Failure
    C1176 Speed Wheel Sensor LR Circuit Open
    C1177 Park Brake Actuator Assembly Switch Released Circuit Failure
    C1178 Speed Wheel Sensor LR Coherency Fault
    C1179 Speed Control Actuator Assembly Cable Slack Failure
    C1180 Park Brake Valve Solenoid #1 Sense Input Circuit Failure
    C1181 Park Brake Valve Solenoid #1 Sense Input Circuit Short to Gound
    C1182 Park Lamp Flash Relay Circuit Failure
    C1183 Park Lamp Flash Relay Circuit Short to Battery
    C1184 ABS System Is Not Operational
    C1185 ABS Power Relay Output Circuit Failure
    C1186 ABS Power Relay Output Open Circuit
    C1187 Brake Fluid Level Sensor Input Open Circuit
    C1188 Brake Fluid Level Sensor Input Short Circuit To Battery
    C1189 Brake Fluid Level Sensor Input Short Circuit To Ground
    C1190 Speed Wheel Sensor LF Input Short Circuit To Battery
    C1191 Speed Wheel Sensor LF Input Short Circuit To Ground
    C1192 Speed Wheel Sensor RF Input Short Circuit To Battery
    C1193 Speed Wheel Sensor RF Input Short Circuit To Ground
    C1194 ABS Outlet Valve Coil LF Circuit Failure
    C1195 ABS Outlet Valve Coil LF Circuit Open
    C1196 ABS Outlet Valve Coil LF Circuit Short To Battery
    C1197 ABS Outlet Valve Coil LF Circuit Short To Ground
    C1198 ABS Inlet Valve Coil LF Circuit Failure
    C1199 ABS Inlet Valve Coil LF Circuit Open
    C1200 ABS Inlet Valve Coil LF Circuit Short To Battery
    C1201 ABS Inlet Valve Coil LF Circuit Short To Ground
    C1202 ABS Outlet Valve Coil Rear Circuit Failure
    C1203 ABS Outlet Valve Coil Rear Circuit Open
    C1204 ABS Outlet Valve Coil Rear Circuit Short To Battery
    C1205 ABS Outlet Valve Coil Rear Circuit Short To Ground
    C1206 ABS Inlet Valve Coil Rear Circuit Failure
    C1207 ABS Inlet Valve Coil Rear Circuit Open
    C1208 ABS Inlet Valve Coil Rear Circuit Short To Battery
    C1209 ABS Inlet Valve Coil Rear Circuit Short To Ground
    C1210 ABS Outlet Valve Coil RF Circuit Failure
    C1211 ABS Outlet Valve Coil RF Circuit Open
    C1212 ABS Outlet Valve Coil RF Circuit Short To Battery
    C1213 ABS Outlet Valve Coil RF Circuit Short To Ground
    C1214 ABS Inlet Valve Coil RF Circuit Failure
    C1215 ABS Inlet Valve Coil RF Circuit Open
    C1216 ABS Inlet Valve Coil RF Circuit Short To Battery
    C1217 ABS Inlet Valve Coil RF Circuit Short To Ground
    C1218 Lamp ABS Warning Output Circuit Failure
    C1219 Lamp ABS Warning Output Circuit Open
    C1220 Lamp ABS Warning Output Circuit Short To Battery
    C1221 Lamp ABS Warning Output Circuit Short To Ground
    C1222 Speed Wheel Mismatch
    C1223 Lamp Brake Warning Output Circuit Failure
    C1224 Lamp Brake Warning Output Circuit Open
    C1225 Lamp Brake Warning Output Circuit Short To Battery
    C1226 Lamp Brake Warning Output Circuit Short To Ground
    C1227 Speed Wheel Sensor LR Input Short Circuit To Battery
    C1228 Speed Wheel Sensor LR Input Short Circuit To Ground
    C1229 Speed Wheel Sensor Rear Center Coherency Fault
    C1230 Speed Wheel Sensor Rear Center Input Circuit Failure
    C1231 Speed Wheel Sensor Rear Center Circuit Open
    C1232 Speed Wheel Sensor Rear Center Input Short Circuit To Battery
    C1233 Speed Wheel LF Input Signal Missing
    C1234 Speed Wheel RF Input Signal Missing
    C1235 Speed Wheel RR Input Signal Missing
    C1236 Speed Wheel LR Input Signal Missing
    C1237 Speed Wheel Rear Input Signal Missing
    C1238 ABS Hydraulic Pressure Differential Switch Input Circuit Failure
    C1239 ABS Hydraulic Pressure Differential Switch Input Open Circuit
    C1240 ABS Hydraulic Pressure Differential Switch Input Short Circuit To Battery
    C1241 ABS Hydraulic Pressure Differential Switch Input Short Circuit To Ground
    C1242 ABS Outlet Valve Coil LR Circuit Failure
    C1243 ABS Outlet Valve Coil LR Circuit Open
    C1244 ABS Outlet Valve Coil LR Circuit Short To Battery
    C1245 ABS Outlet Valve Coil LR Circuit Short To Ground
    C1246 ABS Outlet Valve Coil RR Circuit Failure
    C1247 ABS Outlet Valve Coil RR Circuit Open
    C1248 ABS Outlet Valve Coil RR Circuit Short To Battery
    C1249 ABS Outlet Valve Coil RR Circuit Short To Ground
    C1250 ABS Inlet Valve Coil LR Circuit Failure
    C1251 ABS Inlet Valve Coil LR Circuit Open
    C1252 ABS Inlet Valve Coil LR Circuit Short To Battery
    C1253 ABS Inlet Valve Coil LR Circuit Short To Ground
    C1254 ABS Inlet Valve Coil RR Circuit Failure
    C1255 ABS Inlet Valve Coil RR Circuit Open
    C1256 ABS Inlet Valve Coil RR Circuit Short To Battery
    C1257 ABS Inlet Valve Coil RR Circuit Short To Ground
    C1258 Speed Wheel LF Comparison Failure
    C1259 Speed Wheel RF Comparison Failure
    C1260 Speed Wheel RR Comparison Failure
    C1261 Speed Wheel LR Comparison Failure
    C1262 Lamp Warning Relay Circuit Failure
    C1263 Lamp Warning Relay Circuit Open
    C1264 Lamp Warning Relay Circuit Short To Battery
    C1265 Lamp Warning Relay Circuit Short To Ground
    C1266 ABS Valve Power Relay Circuit Failure
    C1267 ABS Functions Temporarily Disabled
    C1268 Motor Relay # 1 Circuit Failure
    C1269 Motor Relay # 1 Circuit Short to Battery
    C1270 Motor # 1 Input Circuit Failure
    C1271 Motor # 1 Input Circuit Short to Gnd
    C1272 Motor # 2 Input Circuit Failure
    C1273 Motor # 2 Input Circuit Short to Vbat
    C1274 Solenoid Relay # 1 Circuit Failure
    C1275 Solenoid Relay # 1 Circuit Short to Vbatt
    C1276 Park Brake Actuator Assembly Switch Applied Circuit Short to Gnd
    C1277 STEERING Wheel Angle 1and 2 Circuit Failure
    C1278 STEERING Wheel Angle 1and 2 Signal Faulted
    C1279 Yaw Rate Sensor circuit Failure
    C1280 Yaw Rate Sensor Signal Fault
    C1281 Lateral Accelerometer circuit Failure
    C1282 Lateral Accelerometer Signal Fault
    C1283 Switch Test Signal Failure
    C1284 Oil Pressure Switch Failure
    C1285 Booster Solenoid circuit Failure
    C1286 Booster Mechanical Failure
    C1287 Booster Pedal Force switch circuit Failure
    C1288 Pressure Transducer Main / Primary Input Circuit Failure
    C1289 Pressure Transducer Redundant / Secondary Input Circuit Failure
    C1400 Traction Control Valve RF Circuit Failure
    C1401 Traction Control Valve RF Circuit Open
    C1402 Traction Control Valve RF Circuit Short To Ground
    C1403 Traction Control Valve RF Circuit Short To Battery
    C1404 Traction Control Valve Rear Circuit Failure
    C1405 Traction Control Valve Rear Circuit Open
    C1406 Traction Control Valve Rear Circuit Short To Ground
    C1407 Traction Control Valve Rear Circuit Short To Battery
    C1410 Traction Control Valve LF Circuit Failure
    C1411 Traction Control Valve LF Circuit Open
    C1412 Traction Control Valve LF Circuit Short To Ground
    C1413 Traction Control Valve LF Circuit Short To Battery
    C1414 Incorrect Module Design Level
    C1415 Incorrect Module Configuration
    C1416 Damper RF Circuit Short To Battery
    C1417 Damper RF Circuit Short to Ground
    C1418 Damper RF Circuit Failure
    C1419 Damper RF Circuit Open
    C1420 Hydraulic Fluid Pressure/ Flow Circuit Short to Vbatt
    C1421 Damper LF Circuit Short To Battery
    C1422 Damper LF Circuit Short to Ground
    C1423 Damper LF Circuit Failure
    C1424 Damper LF Circuit Open
    C1425 Damper RR Circuit Short to Ground
    C1426 Damper RR Circuit Short To Battery
    C1427 Damper RR Circuit Open
    C1428 Damper RR Circuit Failure
    C1429 Input-shaft-speed input circuit failure
    C1430 Damper LR Circuit Open
    C1431 Damper LR Circuit Short To Battery
    C1432 Damper LR Circuit Short to Ground
    C1433 Damper LR Circuit Failure
    C1435 Accelerometer Rear Circuit Failure
    C1436 Accelerometer Rear Circuit Signal Is Not Sensed
    C1437 Accelerometer Rear Circuit Short To Ground
    C1438 Accelerometer Rear Circuit Short To Battery
    C1439 Vehicle Acceleration EEC-IV Circuit Failure
    C1440 Pressure Transducer Main / Primary signal Faulted
    C1441 Steering Phase A Circuit Signal Is Not Sensed
    C1442 Steering Phase B Circuit Signal Is Not Sensed
    C1443 Steering Phase A Circuit Short To Ground
    C1444 Steering Phase B Circuit Short To Ground
    C1445 Speed Vehicle Signal Circuit Failure
    C1446 Brake Switch Circuit Failure
    C1447 Traction Control Module Request Circuit Failure
    C1448 Lamp Adaptive Damping Warning Circuit Failure
    C1449 Traction Control Motor Coherency Fault
    C1450 Traction Control Motor Circuit Failure
    C1451 Traction Control Motor Circuit Open
    C1452 Traction Control Motor Circuit Short to Battery
    C1453 Traction Control Motor Circuit Short to Ground
    C1454 Front Lateral Accelerometer Circuit Failure
    C1455 Accelerometer Front Circuit Failure
    C1456 Accelerometer Front Circuit Is Not Sensed
    C1457 Accelerometer Front Circuit Short To Ground
    C1458 Accelerometer Front Circuit Short To Battery
    C1459 Adaptive Mode Switch Circuit Failure
    C1460 Vehicle Accelerometer Power Circuit Failure
    C1461 Vehicle Accelerometer Power Circuit Short to Battery
    C1462 Left Front Vertical Accelerometer Circuit Failure
    C1463 Right Front Vertical Accelerometer Circuit Failure
    C1464 Pressure Transducer Redundant / Secondary Signal Faulted
    C1465 Damper High Side Front Circuit Short To Battery
    C1466 Damper Circuit Failure
    C1467 Damper High Side Rear Circuit Short To Battery
    C1468 Damper Low Side Front Circuit Failure
    C1469 Damper Low Side Rear Circuit Failure
    C1495 Traction Control Motor Potentiometer Circuit Failure
    C1496 Traction Control Motor Potentiometer Circuit Open
    C1497 Traction Control Motor Potentiometer Circuit Short to Battery
    C1498 Traction Control Motor Potentiometer Circuit Short to Ground
    C1499 Transfer Case Contact Plate "A" Encoder Circuit Failure
    C1500 Transfer Case Contact Plate "B" Encoder Circuit Failure
    C1501 Transfer Case Contact Plate "C" Encoder Circuit Failure
    C1502 Transfer Case Contact Plate "D" Encoder Circuit Failure
    C1503 Dynamic Stability Control Left Front Valve Malfunction
    C1504 Dynamic Stability Control Right Front Valve Malfunction
    C1505 Dynamic Stability Control Left Rear Valve Malfunction
    C1506 Dynamic Stability Control Right Rear Valve Malfunction
    C1507 Traction Control of Brake Exceeds Time-Out
    C1508 Traction Control of Engine Exceeds Time-Out
    C1510 Right Front Wheel Pressure Reduction Performance Problem
    C1511 Left Front Wheel Pressure Reduction Performance Problem
    C1512 Right Rear Wheel Pressure Reduction Performance Problem
    C1513 Left rear Wheel Pressure Reduction Performance Problem
    C1699 Left Rear Sensor Circuit Short to Vbat
    C1700 Left Rear Sensor Circuit Failure
    C1701 Left Rear Sensor Circuit Fault
    C1702 RightRear Sensor Circuit Short to Vbat
    C1703 Right Rear Sensor Circuit Failure
    C1704 Right Rear Sensor Circuit Fault
    C1705 Left Rear Center Sensor Circuit Short to Vbat
    C1706 Left Rear Center Sensor Circuit Failure
    C1707 Left Rear Center Sensor Circuit Fault
    C1708 Right Rear Center Sensor Circuit Short to Vbat
    C1709 Right Rear Center Sensor Circuit Failure
    C1710 Right Rear Center Sensor Circuit Fault
    C1711 Left Front Sensor Circuit Short to Vbat
    C1712 Left Front Sensor Circuit Failure
    C1713 Left Front Sensor Circuit Fault
    C1714 Right Front Sensor Circuit Short to Vbat
    C1715 Right Front Sensor Circuit Failure
    C1716 Right Front Sensor Circuit Fault
    C1717 Left Front Center Sensor Circuit Short to Vbat
    C1718 Left Front Center Sensor Circuit Failure
    C1719 Left Front Center Sensor Circuit Fault
    C1721 Air Suspension Height Sensor Power Circuit Open
    C1722 Air Suspension Height Sensor Power Circuit Short To Battery
    C1723 Air Suspension Height Sensor Power Circuit Short To Ground
    C1724 Air Suspension Height Sensor Power Circuit Failure
    C1725 Air Suspension Front Pneumatic Failure
    C1726 Air Suspension Rear Pneumatic Failure
    C1727 Air Suspension Reservoir Pneumatic Failure
    C1728 Transfer Case unable to transition between 2H and 4H
    C1729 Transfer Case unable to transition between 4H and 4L
    C1730 Reference Voltage Out of Range (+5 v)
    C1731 Air Suspension LF Corner Up Timeout
    C1732 Air Suspension LF Corner Down Timeout
    C1733 Air Suspension RF Corner Up Timeout
    C1734 Air Suspension RF Corner Down Timeout
    C1735 Air Suspension LR Corner Up Timeout
    C1736 Air Suspension LR Corner Down Timeout
    C1737 Air Suspension RR Corner Up Timeout
    C1738 Air Suspension RR Corner Down Timeout
    C1739 Right Front Center Sensor Circuit Short to Vbat
    C1740 Right Front Center Sensor Circuit Failure
    C1741 Right Front Center Sensor Circuit Fault
    C1742 Rear Sounder Circuit Failure
    C1743 Rear Sounder Circuit Short to Vbatt
    C1744 Front Sounder Circuit Failure
    C1745 Front Sounder Circuit Short to Vbatt
    C1748 Switch input Circuit Short to Gnd
    C1749 Trailer Input Circuit Failure
    C1750 Accelerator Position Sensor Out of Range
    C1751 Vehicle Speed Sensor # 1 Output Circuit Short to Vbatt
    C1752 Vehicle Speed Sensor # 1 Output Circuit Short to Gnd
    C1753 Hydraulic Clutch Actuator Valve Signal Fault
    C1754 Hydraulic Clutch Actuator Valve Circuit Failure
    C1755 Power Limit Shutdown Fault
    C1756 Air Suspension Front Height Sensor High (SE) Signal Circuit Failure
    C1757 Air Suspension Front Height Sensor High (SE) Signal Circuit Open
    C1758 Air Suspension Front Height Sensor High (SE) Signal Circuit Short To Battery
    C1759 Air Suspension Front Height Sensor High (SE) Signal Circuit Short To Ground
    C1760 Air Suspension Rear Height Sensor High (SE) Signal Circuit Failure
    C1761 Air Suspension Rear Height Sensor High (SE) Signal Circuit Open
    C1762 Air Suspension Rear Height Sensor High (SE) Signal Circuit Short To Battery
    C1763 Air Suspension Rear Height Sensor High (SE) Signal Circuit Short To Ground
    C1765 Air Suspension Rear Height Sensor Low Signal Circuit Failure
    C1766 Air Suspension Rear Height Sensor Low Signal Circuit Open
    C1767 Air Suspension Rear Height Sensor Low Signal Circuit Short To Battery
    C1768 Air Suspension Rear Height Sensor Low Signal Circuit Short To Ground
    C1770 Air Suspension Vent Solenoid Output Circuit Failure
    C1771 Air Suspension Vent Solenoid Output Circuit Open
    C1772 Air Suspension Vent Solenoid Output Circuit Short To Battery
    C1773 Air Suspension Vent Solenoid Output Circuit Short To Ground
    C1774 Coolant Temp Out of Range
    C1775 DC-DC Converter Failure
    C1776 Heater System Failure
    C1777 Vacuum Pressure Circuit Failure
    C1778 Power Steering Failure
    C1779 Blower Switch Failure
    C1780 Temperature Select Failure
    C1781 Engine Coolant Temperature Signal Missing/Fault
    C1790 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Failure
    C1791 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Open
    C1792 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Battery
    C1793 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Ground
    C1795 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Failure
    C1796 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Open
    C1797 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Battery
    C1798 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Ground
    C1800 Air Suspension Reservoir Solenoid Circuit Failure
    C1805 Mismatched PCM and/or ABS-TC Module
    C1813 Air Suspension LR Vent Request Exceeded Max Timing
    C1814 Air Suspension RR Vent Request Exceeded Max Timing
    C1818 Air Suspension LR Air Compress Request Exceeded Max Timing
    C1819 Air Suspension RR Air Compress Request Exceeded Max Timing
    C1820 Air Suspension RF Air Compress Request Exceeded Max Timing
    C1830 Air Suspension Compressor Relay Circuit Failure
    C1831 Air Suspension Compressor Relay Circuit Open
    C1832 Air Suspension Compressor Relay Circuit Short To Battery
    C1833 Air Suspension Compressor Relay Circuit Short To Ground
    C1834 Gauge Drive Current Fault
    C1835 Current Sense Circuit Failure
    C1836 Battery Temp out of Range
    C1837 Battery Heater Circuit Failure
    C1838 Charging System Fault
    C1839 Leakage Fault
    C1840 Air Suspension Disable Switch Circuit Failure
    C1841 Air Suspension Disable Switch Circuit Open
    C1842 Air Suspension Disable Switch Circuit Short To Battery
    C1843 Air Suspension Disable Switch Circuit Short To Ground
    C1844 Air Suspension Secondary Front Inflator Solenoid Output Circuit Failure
    C1845 Air Suspension Front Inflator Solenoid Output Circuit Failure
    C1846 Air Suspension Front Inflator Solenoid Output Circuit Open
    C1847 Air Suspension Front Inflator Solenoid Output Circuit Short To Battery
    C1848 Air Suspension Front Inflator Solenoid Output Circuit Short To Ground
    C1849 Master Cylinder Pressure Out of Range
    C1850 Air Suspension Warning Lamp Circuit Failure
    C1851 Air Suspension Warning Lamp Circuit Open
    C1852 Air Suspension Warning Lamp Circuit Short To Battery
    C1853 Air Suspension Warning Lamp Circuit Short To Ground
    C1854 Motor Temperature Out of Range
    C1855 Acceleration Position Sensor Conflict
    C1856 Traction Motor Encoder circuit Failure
    C1859 PRNDL Input #2 Circuit Failure
    C1860 PRNDL Input #3 Circuit Failure
    C1861 PRNDL Input #4 Circuit Failure
    C1862 Contactor Circuit Failure
    C1863 External Charging Fault
    C1864 Battery Module Fault
    C1865 Air Suspension Rear Inflator Solenoid Output Circuit Failure
    C1866 Air Suspension Rear Inflator Solenoid Output Circuit Open
    C1867 Air Suspension Rear Inflator Solenoid Output Circuit Short To Battery
    C1868 Air Suspension Rear Inflator Solenoid Output Circuit Short To Ground
    C1869 Air Suspension Gate Solenoid Output Circuit Failure
    C1870 Air Suspension Gate Solenoid Output Circuit Open
    C1871 Air Suspension Gate Solenoid Output Circuit Short To Battery
    C1872 Air Suspension Gate Solenoid Output Circuit Short To Ground
    C1873 Air Suspension RF Air Spring Solenoid Output Circuit Failure
    C1874 Air Suspension RF Air Spring Solenoid Output Circuit Open
    C1875 Air Suspension RF Air Spring Solenoid Output Circuit Short To Battery
    C1876 Air Suspension RF Air Spring Solenoid Output Circuit Short To Ground
    C1877 Air Suspension LF Air Spring Solenoid Output Circuit Failure
    C1878 Air Suspension LF Air Spring Solenoid Output Circuit Open
    C1879 Air Suspension LF Air Spring Solenoid Output Circuit Short To Battery
    C1880 Air Suspension LF Air Spring Solenoid Output Circuit Short To Ground
    C1881 Air Suspension RF Height Sensor Circuit Failure
    C1882 Air Suspension RF Height Sensor Circuit Open
    C1883 Air Suspension RF Height Sensor Circuit Short To Battery
    C1884 Air Suspension RF Height Sensor Circuit Short To Ground
    C1885 Air Suspension RR Height Sensor Circuit Failure
    C1886 Air Suspension RR Height Sensor Circuit Open
    C1887 Air Suspension RR Height Sensor Circuit Short To Battery
    C1888 Air Suspension RR Height Sensor Circuit Short To Ground
    C1889 Air Suspension LF Height Sensor Circuit Failure
    C1890 Air Suspension LF Height Sensor Circuit Open
    C1891 Air Suspension LF Height Sensor Circuit Short To Battery
    C1892 Air Suspension LF Height Sensor Circuit Short To Ground
    C1893 Air Suspension LR Height Sensor Circuit Failure
    C1894 Air Suspension LR Height Sensor Circuit Open
    C1895 Air Suspension LR Height Sensor Circuit Short To Battery
    C1896 Air Suspension LR Height Sensor Circuit Short To Ground
    C1897 Steering VAPS II Circuit Loop Failure
    C1898 Steering VAPS II Circuit Loop Open
    C1899 Steering VAPS II Circuit Loop Short To Battery
    C1900 Steering VAPS II Circuit Loop Short To Ground
    C1901 Ride Control RR Shock Actuator Circuit Failure
    C1902 Ride Control RR Shock Actuator Circuit Open
    C1903 Ride Control RR Shock Actuator Circuit Short To Battery
    C1904 Ride Control RR Shock Actuator Circuit Short To Ground
    C1905 Ride Control LR Shock Actuator Circuit Failure
    C1906 Ride Control LR Shock Actuator Circuit Open
    C1907 Ride Control LR Shock Actuator Circuit Short To Battery
    C1908 Ride Control LR Shock Actuator Circuit Short To Ground
    C1909 Ride Control RF Shock Actuator Circuit Failure
    C1910 Ride Control RF Shock Actuator Circuit Open
    C1911 Ride Control RF Shock Actuator Circuit Short To Battery
    C1912 Ride Control RF Shock Actuator Circuit Short To Ground
    C1913 Ride Control LF Shock Actuator Circuit Failure
    C1914 Ride Control LF Shock Actuator Circuit Open
    C1915 Ride Control LF Shock Actuator Circuit Short To Battery
    C1916 Ride Control LF Shock Actuator Circuit Short To Ground
    C1917 Steering EVO Out-of-Range Fault
    C1918 Air Suspension Ride Height Select Switch Circuit Failure
    C1920 Led #1 Circuit Failure
    C1921 VAPS Solenoid Actuator Output Circuit Failure
    C1922 VAPS Solenoid Actuator Output Circuit Open
    C1923 VAPS Solenoid Actuator Output Circuit Short To Battery
    C1924 VAPS Solenoid Actuator Output Circuit Short To Ground
    C1925 VAPS Solenoid Actuator Return Circuit Failure
    C1926 VAPS Solenoid Actuator Return Circuit Open
    C1927 VAPS Solenoid Actuator Return Circuit Short To Battery
    C1928 VAPS Solenoid Actuator Return Circuit Short To Ground
    C1929 Air Suspension Front Compressor Relay Circuit Failure
    C1930 Air Suspension Front Compressor Relay Circuit Open
    C1931 Air Suspension Front Compressor Relay Circuit Short To Battery
    C1932 Air Suspension Front Compressor Relay Circuit Short To Ground
    C1933 Solenoid Current Out Of Range
    C1934 HPU (Hydraulic Pump Unit) Pressurisation Failure
    C1935 Chime Circuit Failure
    C1936 Hydraulic Pump Relay Circuit Failure
    C1937 Steering Wheel Angle Sensor Offset Failure
    C1938 Invalid Steering Wheel Angle Sensor ID
    C1939 Brake Pressure Switch Input Circuit Failure
    C1940 Brake Pressure Switch Mechanical Failure
    C1942 Unrecognized Powertrain Configuration
    C1943 Airbag Deployment Indication Input Fault
    C1944 Gauge Driver Circuit Fault
    C1945 Park Switch Indicates Park with Vehicle Moving
    C1946 Seat Track Position Switch Circuit Open
    C1947 Seat Track Position Switch Circuit Short to Ground
    C1948 Seat Track Position Switch Circuit Resistance Out of Range
    C1949 Accelerometer Sensor Circuit Open
    C1950 Accelerometer Sensor Circuit Failure
    C1951 Lateral Accelerometer Sensor Circuit Open
    C1952 Yaw Rate Sensor Circuit Open
    C1953 Master Cylinder Pressure Sensor Circuit Open
    C1954 Master Cylinder Pressure Sensor Circuit Failure
    C1955 Steering Angle Sensor Circuit Open
    C1956 Steering Angle Sensor Circuit Failure
    C1957 Dynamic Stability Control Valve RF Circuit Failure
    C1958 Dynamic Stability Control Valve LF Circuit Failure
    C1959 Lateral Accelerometer Sensor Circuit Failure
    C1960 Driver Brake Apply Circuit Fault
    C1961 Park Lamp Relay Coil Circuit Failure
    C1962 Park Lamp Relay Coil Short to Battery
    C1963 Stability Control Inhibit Warning
    B1200 Climate Control Pushbutton Circuit Failure
    B1201 Fuel Sender Circuit Failure
    B1202 Fuel Sender Circuit Open
    B1203 Fuel Sender Circuit Short To Battery
    B1204 Fuel Sender Circuit Short To Ground
    B1205 EIC Switch-1 Assembly Circuit Failure
    B1206 EIC Switch-1 Assembly Circuit Open
    B1207 EIC Switch-1 Assembly Circuit Short To Battery
    B1208 EIC Switch-1 Assembly Circuit Short To Ground
    B1209 EIC Switch-2 Assembly Circuit Failure
    B1210 EIC Switch-2 Assembly Circuit Open
    B1211 EIC Switch-2 Assembly Circuit Short To Battery
    B1212 EIC Switch-2 Assembly Circuit Short To Ground
    B1213 Anti-Theft Number of Programmed Keys Is Below Minimum
    B1214 Running Board Lamp Circuit Failure
    B1215 Running Board Lamp Circuit Short to Battery
    B1216 Emergency & Road Side Assistance Switch Circuit Short to Ground
    B1217 Horn Relay Coil Circuit Failure
    B1218 Horn Relay Coil Circuit Short to Vbatt
    B1219 Fuel Tank Pressure Sensor Circuit Failure
    B1220 Fuel Tank Pressure Sensor Circuit Open
    B1222 Fuel Temperature Sensor #1 Circuit Failure
    B1223 Fuel Temperature Sensor #1 Circuit Open
    B1224 Fuel Temperature Sensor #1 Circuit Short to Battery
    B1225 Fuel Temperature Sensor #1 Circuit Short to Ground
    B1226 Fuel Temperature Sensor #2 Circuit Failure
    B1227 Fuel Temperature Sensor #2 Circuit Open
    B1228 Fuel Temperature Sensor #2 Circuit Short to Battery
    B1229 Fuel Temperature Sensor #2 Circuit Short to Ground
    B1231 Longitudinal Acceleration Threshold Exceeded
    B1232 See Manufacturer
    B1233 Glass Break Sensor Failure
    B1234 Mirror Switch Invalid Code
    B1235 Window Feedback Failure
    B1236 Window Feedback Loss of Signal
    B1237 Window Feedback Out of Range
    B1238 Over Temperature Fault
    B1239 Air Flow Blend Door Driver Circuit Failure
    B1240 Wiper Washer Rear Pump Relay Circuit Failure
    B1241 Wiper Washer Rear Pump Relay Circuit Short to Battery
    B1242 Air Flow Recirculation Door Driver Circuit Failure
    B1243 Express Window Down Switch Circuit Short to Battery
    B1244 Wiper Rear Motor Run Relay Circuit Failure
    B1245 Wiper Rear Motor Run Relay Circuit Short to Battery
    B1246 Dim Panel Potentiometer Switch Circuit Failure
    B1247 Panel Dim Switch Circuit Open
    B1248 Passenger's Seatback Autoglide Rearward Switch Circuit Short to Ground
    B1249 Blend Door Failure
    B1250 Air Temperature Internal Sensor Circuit Failure
    B1251 Air Temperature Internal Sensor Circuit Open
    B1252 Air Temperature Internal Sensor Circuit Short To Battery
    B1253 Air Temperature Internal Sensor Circuit Short To Ground
    B1254 Air Temperature External Sensor Circuit Failure
    B1255 Air Temperature External Sensor Circuit Open
    B1256 Air Temperature External Sensor Circuit Short To Battery
    B1257 Air Temperature External Sensor Circuit Short To Ground
    B1258 Solar Radiation Sensor Circuit Failure
    B1259 Solar Radiation Sensor Circuit Open
    B1260 Solar Radiation Sensor Circuit Short To Battery
    B1261 Solar Radiation Sensor Circuit Short To Ground
    B1262 Servo Motor Defrost Circuit Failure
    B1263 Servo Motor Vent Circuit Failure
    B1264 Servo Motor Foot Circuit Failure
    B1265 Servo Motor Coolair Bypass Circuit Failure
    B1266 Servo Motor Airintake Left Circuit Failure
    B1267 Servo Motor Airintake Right Circuit Failure
    B1268 Servo Motor Potentiometer Defrost Circuit Failure
    B1269 Servo Motor Potentiometer Defrost Circuit Open
    B1270 Servo Motor Potentiometer Defrost Circuit Short To Battery
    B1271 Servo Motor Potentiometer Defrost Circuit Short To Ground
    B1272 Servo Motor Potentiometer Vent Circuit Failure
    B1273 Servo Motor Potentiometer Vent Circuit Open
    B1274 Servo Motor Potentiometer Vent Circuit Short To Battery
    B1275 Servo Motor Potentiometer Vent Circuit Short To Ground
    B1276 Servo Motor Potentiometer Foot Circuit Failure
    B1277 Servo Motor Potentiometer Foot Circuit Open
    B1278 Servo Motor Potentiometer Foot Circuit Short To Battery
    B1279 Servo Motor Potentiometer Foot Circuit Short To Ground
    B1280 Servo Motor Potentiometer Coolair Circuit Failure
    B1281 Servo Motor Potentiometer Coolair Circuit Open
    B1282 Servo Motor Potentiometer Coolair Circuit Short To Battery
    B1283 Servo Motor Potentiometer Coolair Circuit Short To Ground
    B1284 Servo Motor Potentiometer Airintake Left Circuit Failure
    B1285 Servo Motor Potentiometer Airintake Left Circuit Open
    B1286 Servo Motor Potentiometer Airintake Left Circuit Short To Battery
    B1287 Servo Motor Potentiometer Airintake Left Circuit Short To Ground
    B1288 Servo Motor Potentiometer Airintake Right Circuit Failure
    B1289 Servo Motor Potentiometer Airintake Right Circuit Open
    B1290 Servo Motor Potentiometer Airintake Right Circuit Short To Battery
    B1291 Servo Motor Potentiometer Airintake Right Circuit Short To Ground
    B1292 Battery Power Relay Circuit Failure
    B1293 Battery Power Relay Circuit Open
    B1294 Battery Power Relay Circuit Short To Battery
    B1295 Battery Power Relay Circuit Short To Ground
    B1296 Power Supply Sensor Circuit Failure
    B1297 Power Supply Sensor Circuit Open
    B1298 Power Supply Sensor Circuit Short To Battery
    B1299 Power Supply Sensor Circuit Short To Ground
    B1300 Power Door Lock Circuit Failure
    B1301 Power Door Lock Circuit Open
    B1302 Accessory Delay Relay Coil Circuit Failure
    B1303 Accessory Delay Relay Coil Circuit Open
    B1304 Accessory Delay Relay Coil Circuit Short To Battery
    B1305 Accessory Delay Relay Coil Circuit Short To Ground
    B1306 Oil Level Switch Circuit Open
    B1307 Oil Level Switch Circuit Short To Battery
    B1308 Oil Level Switch Circuit Short To Ground
    B1309 Power Door Lock Circuit Short To Ground
    B1310 Power Door Unlock Circuit Failure
    B1311 Power Door Unlock Circuit Open
    B1312 Lamp Headlamp Input Circuit Short To Battery
    B1313 Battery Saver Relay Coil Circuit Failure
    B1314 Battery Saver Relay Coil Circuit Open
    B1315 Battery Saver Relay Coil Circuit Short To Battery
    B1316 Battery Saver Relay Coil Circuit Short To Ground
    B1317 Battery Voltage High
    B1318 Battery Voltage Low
    B1319 Driver Door Ajar Circuit Failure
    B1320 Driver Door Ajar Circuit Open
    B1321 Driver Door Ajar Circuit Short To Battery
    B1322 Driver Door Ajar Circuit Short To Ground
    B1323 Door Ajar Lamp Circuit Failure
    B1324 Door Ajar Lamp Circuit Open
    B1325 Door Ajar Lamp Circuit Short To Battery
    B1326 Door Ajar Lamp Circuit Short To Ground
    B1327 Passenger Door Ajar Circuit Failure
    B1328 Passenger Door Ajar Circuit Open
    B1329 Passenger Door Ajar Circuit Short To Battery
    B1330 Passenger Door Ajar Circuit Short To Ground
    B1331 Decklid Ajar Rear Door Circuit Failure
    B1332 Decklid Ajar Rear Door Circuit Open
    B1333 Decklid Ajar Rear Door Circuit Short To Battery
    B1334 Decklid Ajar Rear Door Circuit Short To Ground
    B1335 Door Ajar RR Circuit Failure
    B1336 Door Ajar RR Circuit Open
    B1337 Door Ajar RR Circuit Short To Battery
    B1338 Door Ajar RR Circuit Short To Ground
    B1339 Chime Input Request Circuit Short To Battery
    B1340 Chime Input Request Circuit Short To Ground
    B1341 Power Door Unlock Circuit Short To Ground
    B1342 ECU Is Defective
    B1343 Heated Backlite Input Circuit Failure
    B1344 Heated Backlite Input Circuit Open
    B1345 Heated Backlite Input Circuit Short To Ground
    B1346 Heated Backlite Input Circuit Short To Battery
    B1347 Heated Backlite Relay Circuit Failure
    B1348 Heated Backlite Relay Circuit Open
    B1349 Heated Backlite Relay Short To Battery
    B1350 Heated Backlite Relay Short To Ground
    B1351 Ignition Key-In Circuit Short To Battery
    B1352 Ignition Key-In Circuit Failure
    B1353 Ignition Key-In Circuit Open
    B1354 Ignition Key-In Circuit Short To Ground
    B1355 Ignition Run Circuit Failure
    B1356 Ignition Run Circuit Open
    B1357 Ignition Run Circuit Short To Battery
    B1358 Ignition Run Circuit Short To Ground
    B1359 Ignition Run/Acc Circuit Failure
    B1360 Ignition Run/Acc Circuit Open
    B1361 Ignition Run/Acc Circuit Short To Battery
    B1362 Ignition Run/Acc Circuit Short To Ground
    B1363 Ignition Start Circuit Failure
    B1364 Ignition Start Circuit Open
    B1365 Ignition Start Circuit Short To Battery
    B1366 Ignition Start Circuit Short To Ground
    B1367 Ignition Tach Circuit Failure
    B1368 Ignition Tach Circuit Open
    B1369 Ignition Tach Circuit Short To Battery
    B1370 Ignition Tach Circuit Short To Ground
    B1371 Illuminated Entry Relay Circuit Failure
    B1372 Illuminated Entry Relay Circuit Open
    B1373 Illuminated Entry Relay Short To Battery
    B1374 Illuminated Entry Relay Short To Ground
    B1375 Oil Change Lamp Circuit Open
    B1376 Oil Change Lamp Circuit Short To Battery
    B1377 Oil Change Lamp Circuit Failure
    B1378 Oil Change Lamp Circuit Short To Ground
    B1379 Oil Change Reset Button Circuit Short To Ground
    B1380 Oil Change Reset Button Circuit Failure
    B1381 Oil Change Reset Button Circuit Open
    B1382 Oil Change Reset Button Circuit Short To Battery
    B1383 Oil Level Lamp Circuit Short To Battery
    B1384 Oil Level Lamp Circuit Failure
    B1385 Oil Level Lamp Circuit Open
    B1386 Oil Level Lamp Circuit Short To Ground
    B1387 Oil Temperature Sensor Circuit Open
    B1388 Oil Temperature Sensor Circuit Short To Battery
    B1389 Oil Temperature Sensor Circuit Failure
    B1390 Oil Temperature Sensor Circuit Short To Ground
    B1391 Oil Level Switch Circuit Failure
    B1392 Power Door Memory Lock Relay Circuit Failure
    B1393 Power Door Memory Lock Relay Circuit Open
    B1394 Power Door Memory Lock Relay Circuit Short To Battery
    B1395 Power Door Memory Lock Relay Circuit Short To Ground
    B1396 Power Door Lock Circuit Short To Battery
    B1397 Power Door Unlock Circuit Short To Battery
    B1398 Driver Power Window One Touch Window Relay Circuit Failure
    B1399 Driver Power Window One Touch Window Relay Circuit Open
    B1400 Driver Power Window One Touch Window Relay Circuit Short To Battery
    B1401 Driver Power Window One Touch Window Relay Circuit Short To Ground
    B1402 Driver Power Window Down Switch Circuit Failure
    B1403 Driver Power Window Up Switch Circuit Failure
    B1404 Driver Power Window Down Circuit Open
    B1405 Driver Power Window Down Circuit Short To Battery
    B1406 Driver Power Window Down Circuit Short To Ground
    B1407 Driver Power Window Up Circuit Open
    B1408 Driver Power Window Up Circuit Short To Battery
    B1409 Driver Power Window Up Circuit Short To Ground
    B1410 Driver Power Window Motor Circuit Failure
    B1411 Driver Power Window Motor Circuit Open
    B1412 Driver Power Window Motor Circuit Short To Battery
    B1413 Driver Power Window Motor Circuit Short To Ground
    B1414 Power Window LR Motor Circuit Failure
    B1415 Power Window LR Motor Circuit Open
    B1416 Power Window LR Motor Circuit Short To Battery
    B1417 Power Window LR Motor Circuit Short To Ground
    B1418 Passenger Power Window Motor Circuit Failure
    B1419 Passenger Power Window Motor Circuit Open
    B1420 Passenger Power Window Motor Circuit Short To Battery
    B1421 Passenger Power Window Motor Circuit Short To Ground
    B1422 Power Window RR Motor Circuit Failure
    B1423 Power Window RR Motor Circuit Open
    B1424 Power Window RR Motor Circuit Short To Battery
    B1425 Power Window RR Motor Circuit Short To Ground
    B1426 Lamp Seat Belt Circuit Short To Battery
    B1427 Lamp Seat Belt Circuit Open
    B1428 Lamp Seat Belt Circuit Failure
    B1429 Lamp Seat Belt Circuit Short To Ground
    B1430 Seat Belt Switch Circuit Short To Ground
    B1431 Wiper Brake/Run Relay Circuit Failure
    B1432 Wiper Brake/Run Relay Circuit Short To Battery
    B1433 Wiper Brake/Run Relay Circuit Short To Ground
    B1434 Wiper Hi/Low Speed Relay Coil Circuit Failure
    B1435 Wiper Hi/Low Speed Relay Coil Circuit Open
    B1436 Wiper Hi/Low Speed Relay Coil Circuit Short To Battery
    B1437 Wiper Hi/Low Speed Relay Coil Circuit Short To Ground
    B1438 Wiper Mode Select Switch Circuit Failure
    B1439 Wiper Mode Select Switch Circuit Open
    B1440 Wiper Mode Select Switch Circuit Short To Battery
    B1441 Wiper Mode Select Switch Circuit Short To Ground
    B1442 Door Handle Switch Circuit Failure
    B1443 Door Handle Switch Circuit Open
    B1444 Door Handle Switch Circuit Short To Battery
    B1445 Door Handle Switch Circuit Short To Ground
    B1446 Wiper Park Sense Circuit Failure
    B1447 Wiper Park Sense Circuit Open
    B1448 Wiper Park Sense Circuit Short To Battery
    B1449 Wiper Park Sense Circuit Short To Ground
    B1450 Wiper Wash/Delay Switch Circuit Failure
    B1451 Wiper Wash/Delay Switch Circuit Open
    B1452 Wiper Wash/Delay Switch Circuit Short To Battery
    B1453 Wiper Wash/Delay Switch Circuit Short To Ground
    B1454 Wiper Washer Fluid Lamp Circuit Failure
    B1455 Wiper Washer Fluid Lamp Circuit Open
    B1456 Wiper Washer Fluid Lamp Circuit Short To Battery
    B1457 Wiper Washer Fluid Lamp Circuit Short To Ground
    B1458 Wiper Washer Pump Motor Relay Circuit Failure
    B1459 Wiper Washer Pump Motor Relay Coil Circuit Open
    B1460 Wiper Washer Pump Motor Relay Coil Circuit Short To Battery
    B1461 Wiper Washer Pump Motor Relay Coil Circuit Short To Ground
    B1462 Seat Belt Switch Circuit Failure
    B1463 Seat Belt Switch Circuit Open
    B1464 Seat Belt Switch Circuit Short To Battery
    B1465 Wiper Brake/Run Relay Circuit Open
    B1466 Wiper Hi/Low Speed Not Switching
    B1467 Wiper Hi/Low Speed Circuit Motor Short To Battery
    B1468 Chime Input Request Circuit Failure
    B1469 Chime Input Request Circuit Open
    B1470 Lamp Headlamp Input Circuit Failure
    B1471 Lamp Headlamp Input Circuit Open
    B1472 Lamp Headlamp Input Circuit Short To Ground
    B1473 Wiper Low Speed Circuit Motor Failure
    B1474 Battery Saver Power Relay Circuit Short To Battery
    B1475 Accessory Delay Relay Contact Short To Battery
    B1476 Wiper High Speed Circuit Motor Failure
    B1477 Wiper Hi/Low Circuit Motor Short To Ground
    B1478 Power Window One Touch Up/Down Activated Simultaneously
    B1479 Wiper Washer Fluid Level Sensor Circuit Failure
    B1480 Wiper Washer Fluid Level Sensor Circuit Open
    B1481 Wiper Washer Fluid Level Sensor Circuit Short To Battery
    B1482 Wiper Washer Fluid Level Sensor Circuit Short To Ground
    B1483 Brake Pedal Input Circuit Failure
    B1484 Brake Pedal Input Open Circuit
    B1485 Brake Pedal Input Circuit Battery Short
    B1486 Brake Pedal Input Circuit Ground Short
    B1487 Door Handle Right Front Circuit Failure
    B1488 Door Handle Right Front Circuit Open
    B1489 Door Handle Right Front Short To Battery
    B1490 Door Handle Right Front Short To Ground
    B1491 Ignition Cylinder Sensor Circuit Failure
    B1492 Ignition Cylinder Sensor Open Circuit
    B1493 Ignition Cylinder Sensor Battery Short
    B1494 Ignition Cylinder Sensor Ground Short
    B1495 Decklid Punch-Out Sensor Circuit Failure
    B1496 Decklid Punch-Out Sensor Open Circuit
    B1497 Decklid Punch-Out Sensor Battery Short
    B1498 Decklid Punch-Out Sensor Ground Short
    B1499 Lamp Turn Signal Left Circuit Failure
    B1500 Lamp Turn Signal Left Circuit Open
    B1501 Lamp Turn Signal Left Circuit Short To Battery
    B1502 Lamp Turn Signal Left Circuit Short To Ground
    B1503 Lamp Turn Signal Right Circuit Failure
    B1504 Lamp Turn Signal Right Circuit Open
    B1505 Lamp Turn Signal Right Circuit Short To Battery
    B1506 Lamp Turn Signal Right Circuit Short To Ground
    B1507 Flash To Pass Switch Circuit Failure
    B1508 Flash To Pass Switch Circuit Open
    B1509 Flash To Pass Switch Circuit Short To Battery
    B1510 Flash To Pass Switch Circuit Short To Ground
    B1511 Driver Door Handle Circuit Failure
    B1512 Driver Door Handle Circuit Open
    B1513 Driver Door Handle Circuit Short To Battery
    B1514 Driver Door Handle Circuit Short To Ground
    B1515 Seat Driver Occupied Switch Circuit Failure
    B1516 Seat Driver Occupied Switch Circuit Open
    B1517 Seat Driver Occupied Switch Circuit Short To Battery
    B1518 Seat Driver Occupied Switch Circuit Short To Ground
    B1519 Hood Switch Circuit Failure
    B1520 Hood Switch Circuit Open
    B1521 Hood Switch Circuit Short To Battery
    B1522 Hood Switch Circuit Short To Ground
    B1523 Keyless Entry Circuit Failure
    B1524 Keyless Entry Circuit Open
    B1525 Keyless Entry Circuit Short To Battery
    B1526 Keyless Entry Circuit Short To Ground
    B1527 Memory Set Switch Circuit Failure
    B1528 Memory Set Switch Circuit Open
    B1529 Memory Set Switch Circuit Short To Battery
    B1530 Memory Set Switch Circuit Short To Ground
    B1531 Memory 1 Switch Circuit Failure
    B1532 Memory 1 Switch Circuit Open
    B1533 Memory 1 Switch Circuit Short To Battery
    B1534 Memory 1 Switch Circuit Short To Ground
    B1535 Memory 2 Switch Circuit Failure
    B1536 Memory 2 Switch Circuit Open
    B1537 Memory 2 Switch Circuit Short To Battery
    B1538 Memory 2 Switch Circuit Short To Ground
    B1539 Mirror Driver Switch Assembly Circuit Failure
    B1540 Mirror Driver Switch Assembly Circuit Open
    B1541 Mirror Driver Switch Assembly Circuit Short To Battery
    B1542 Mirror Driver Switch Assembly Circuit Short To Ground
    B1543 Seat Direction Switch Assembly Circuit Failure
    B1544 Seat Direction Switch Assembly Circuit Open
    B1545 Seat Direction Switch Assembly Circuit Short To Battery
    B1546 Seat Direction Switch Assembly Circuit Short To Ground
    B1547 Power Window Master Circuit Failure
    B1548 Power Window Master Circuit Open
    B1549 Power Window Master Circuit Short To Battery
    B1550 Power Window Master Circuit Short To Ground
    B1551 Decklid Release Circuit Failure
    B1552 Decklid Release Circuit Open
    B1553 Decklid Release Circuit Short To Battery
    B1554 Decklid Release Circuit Short To Ground
    B1555 Ignition Run/Start Circuit Failure
    B1556 Ignition Run/Start Circuit Open
    B1557 Ignition Run/Start Circuit Short To Battery
    B1558 Ignition Run/Start Circuit Short To Ground
    B1559 Door Lock Cylinder Circuit Failure
    B1560 Door Lock Cylinder Circuit Open
    B1561 Door Lock Cylinder Circuit Short To Battery
    B1562 Door Lock Cylinder Circuit Short To Ground
    B1563 Door Ajar Circuit Failure
    B1564 Door Ajar Circuit Open
    B1565 Door Ajar Circuit Short To Battery
    B1566 Door Ajar Circuit Short To Ground
    B1567 Lamp Headlamp High-Beam Circuit Failure
    B1568 Lamp Headlamp High-Beam Circuit Open
    B1569 Lamp Headlamp High-Beam Circuit Short To Battery
    B1570 Lamp Headlamp High-Beam Circuit Short To Ground
    B1571 Door Ajar LR Circuit Failure
    B1572 Door Ajar LR Circuit Open
    B1573 Door Ajar LR Circuit Short To Battery
    B1574 Door Ajar LR Circuit Short To Ground
    B1575 Lamp Park Input Circuit Failure
    B1576 Lamp Park Input Circuit Open
    B1577 Lamp Park Input Circuit Short To Battery
    B1578 Lamp Park Input Circuit Short To Ground
    B1579 Dim Panel Increase Input Circuit Failure
    B1580 Dim Panel Increase Input Circuit Open
    B1581 Dim Panel Increase Input Circuit Short To Battery
    B1582 Dim Panel Increase Input Circuit Short To Ground
    B1583 Dim Panel Decrease Input Circuit Failure
    B1584 Dim Panel Decrease Input Circuit Open
    B1585 Dim Panel Decrease Input Circuit Short To Battery
    B1586 Dim Panel Decrease Input Circuit Short To Ground
    B1587 Autolamp Delay Increase Circuit Failure
    B1588 Autolamp Delay Increase Circuit Open
    B1589 Autolamp Delay Increase Circuit Short To Battery
    B1590 Autolamp Delay Increase Circuit Short To Ground
    B1591 Autolamp Delay Decrease Circuit Failure
    B1592 Autolamp Delay Decrease Circuit Open
    B1593 Autolamp Delay Decrease Circuit Short To Battery
    B1594 Autolamp Delay Decrease Circuit Short To Ground
    B1595 Ignition Switch Illegal Input Code
    B1596 Service Continuous Codes
    B1597 Driver's Seat Seatback Autoglide Forward Switch Circuit Short to Ground
    B1598 Driver's Seat Seatback Autoglide Rearward Switch Circuit Short to Ground
    B1599 Passenger's Seatback Autoglide Forward Switch Circuit Short to Ground
    B1600 PATS Ignition Key Transponder Signal Is Not Received
    B1601 PATS Received Incorrect Key-Code From Ignition Key Transponder
    B1602 PATS Received Invalid Format Of Key-Code From Ignition Key Transponder
    B1603 Lamp Anti-Theft Indicator Circuit Failure
    B1604 Lamp Anti-Theft Indicator Circuit Open
    B1605 Lamp Anti-Theft Indicator Circuit Short To Battery
    B1606 Lamp Anti-Theft Indicator Circuit Short To Ground
    B1607 Illuminated Entry Input Circuit Failure
    B1608 Illuminated Entry Input Open Circuit
    B1609 Illuminated Entry Input Short Circuit To Battery
    B1610 Illuminated Entry Input Short Circuit To Ground
    B1611 Wiper Rear Mode Select Switch Circuit Failure
    B1612 Wiper Rear Mode Select Switch Circuit Open
    B1613 Wiper Rear Mode Select Switch Circuit Short To Battery
    B1614 Wiper Rear Mode Select Switch Circuit Short To Ground
    B1615 Wiper Rear Disable Switch Circuit Failure
    B1616 Wiper Rear Disable Switch Circuit Open
    B1617 Wiper Rear Disable Switch Circuit Short To Battery
    B1618 Wiper Rear Disable Switch Circuit Short To Ground
    B1619 Wiper Rear Low Limit Input Circuit Failure
    B1620 Wiper Rear Low Limit Input Circuit Open
    B1621 Wiper Rear Low Limit Input Circuit Short To Battery
    B1622 Wiper Rear Low Limit Input Circuit Short To Ground
    B1623 Lamp Keypad Output Circuit Failure
    B1624 Lamp Keypad Output Open Circuit
    B1625 Lamp Keypad Output Short Circuit To Battery
    B1626 Lamp Keypad Output Short Circuit To Ground
    B1627 PRNDL Reverse Input Circuit Failure
    B1628 PRNDL Reverse Input Open Circuit
    B1629 PRNDL Reverse Input Short To Battery
    B1630 PRNDL Reverse Input Short Circuit To Ground
    B1631 Mirror Driver Left Circuit Failure
    B1632 Mirror Driver Left Circuit Open
    B1633 Mirror Driver Left Circuit Short To Battery
    B1634 Mirror Driver Left Circuit Short To Ground
    B1635 Mirror Driver Right Circuit Failure
    B1636 Mirror Driver Right Circuit Open
    B1637 Mirror Driver Right Circuit Short To Battery
    B1638 Mirror Driver Right Short To Ground
    B1639 Mirror Passenger Left Circuit Failure
    B1640 Mirror Passenger Left Circuit Open
    B1641 Mirror Passenger Left Circuit Short To Battery
    B1642 Mirror Passenger Left Circuit Short To Ground
    B1643 Mirror Passenger Right Circuit Failure
    B1644 Mirror Passenger Right Circuit Open
    B1645 Mirror Passenger Right Circuit Short To Battery
    B1646 Mirror Passenger Right Circuit Short To Ground
    B1647 Seat Driver Recline Forward Circuit Failure
    B1648 Seat Driver Recline Forward Circuit Open
    B1649 Seat Driver Recline Forward Circuit Short To Battery
    B1650 Seat Driver Recline Forward Circuit Short To Ground
    B1651 Seat Driver Recline Backward Circuit Failure
    B1652 Seat Driver Recline Backward Circuit Open
    B1653 Seat Driver Recline Backward Circuit Short To Battery
    B1654 Seat Driver Recline Backward Circuit Short To Ground
    B1655 Seat Driver Rear Up Circuit Failure
    B1656 Seat Driver Rear Up Circuit Open
    B1657 Seat Driver Rear Up Circuit Short To Battery
    B1658 Seat Driver Rear Up Circuit Short To Ground
    B1659 Seat Driver Front Up Circuit Failure
    B1660 Seat Driver Front Up Circuit Open
    B1661 Seat Driver Front Up Circuit Short To Battery
    B1662 Seat Driver Front Up Circuit Short To Ground
    B1663 Seat Driver Front Up/Down Motor Stalled
    B1664 Seat Driver Rear Up/Down Motor Stalled
    B1665 Seat Driver Forward/Backward Motor Stalled
    B1666 Seat Driver Recline Motor Stalled
    B1667 Mirror Driver Up/Down Motor Stalled
    B1668 Mirror Driver Right/Left Motor Stalled
    B1669 Mirror Passenger Up/Down Motor Stalled
    B1670 Mirror Passenger Right/Left Motor Stalled
    B1671 Battery Module Voltage Out Of Range
    B1672 Seat Driver Occupied Input Circuit Failure
    B1673 Seat Driver Occupied Input Circuit Open
    B1674 Seat Driver Occupied Input Circuit Short To Battery
    B1675 Seat Driver Occupied Input Circuit Short To Ground
    B1676 Battery Pack Voltage Out Of Range
    B1677 Alarm Panic Input Circuit Failure
    B1678 Alarm Panic Input Circuit Open
    B1679 Alarm Panic Input Circuit Short To Battery
    B1680 Alarm Panic Input Circuit Short To Ground
    B1681 PATS Transceiver Module Signal Is Not Received
    B1682 PATS Is Disabled (Check Link Between PATS And Transponder)
    B1683 Mirror Driver/Passenger Switch Circuit Failure
    B1684 Mirror Driver/Passenger Switch Circuit Open
    B1685 Lamp Dome Input Circuit Failure
    B1686 Lamp Dome Input Circuit Open
    B1687 Lamp Dome Input Circuit Short To Battery
    B1688 Lamp Dome Input Circuit Short To Ground
    B1689 Autolamp Delay Circuit Failure
    B1690 Autolamp Delay Circuit Open
    B1691 Autolamp Delay Circuit Short To Battery
    B1692 Autolamp Delay Circuit Short To Ground
    B1693 Autolamp On Circuit Failure
    B1694 Autolamp On Circuit Open
    B1695 Autolamp On Circuit Short To Battery
    B1696 Autolamp On Circuit Short To Ground
    B1697 Mirror Driver/Passenger Switch Circuit Short To Battery
    B1698 Mirror Driver/Passenger Switch Circuit Short To Ground
    B1699 Passenger's Seat Occupied Switch Circuit Short to Ground
    B1700 Passenger's Seatbelt Tension Reducer Circuit Short to Ground
    B1701 Seat Driver Recline Forward Switch Circuit Failure
    B1702 Seat Driver Recline Forward Switch Circuit Open
    B1703 Seat Driver Recline Forward Switch Circuit Short To Battery
    B1704 Seat Driver Recline Forward Switch Circuit Short To Ground
    B1705 Seat Driver Recline Rearward Switch Circuit Failure
    B1706 Seat Driver Recline Rearward Switch Circuit Open
    B1707 Seat Driver Recline Rearward Switch Circuit Short To Battery
    B1708 Seat Driver Recline Rearward Switch Circuit Short To Ground
    B1709 Seat Driver Front Up Switch Circuit Failure
    B1710 Seat Driver Front Up Switch Circuit Open
    B1711 Seat Driver Front Up Switch Circuit Short To Battery
    B1712 Seat Driver Front Up Switch Circuit Short To Ground
    B1713 Seat Driver Front Down Switch Circuit Failure
    B1714 Seat Driver Front Down Switch Circuit Open
    B1715 Seat Driver Front Down Switch Circuit Short To Battery
    B1716 Seat Driver Front Down Switch Circuit Short To Ground
    B1717 Seat Driver Forward Switch Circuit Failure
    B1718 Seat Driver Forward Switch Circuit Open
    B1719 Seat Driver Forward Switch Circuit Short To Battery
    B1720 Seat Driver Forward Switch Circuit Short To Ground
    B1721 Seat Driver Rearward Switch Circuit Failure
    B1722 Seat Driver Rearward Switch Circuit Open
    B1723 Seat Driver Rearward Switch Circuit Short To Battery
    B1724 Seat Driver Rearward Switch Circuit Short To Ground
    B1725 Seat Driver Rear Up Switch Circuit Failure
    B1726 Seat Driver Rear Up Switch Circuit Open
    B1727 Seat Driver Rear Up Switch Circuit Short To Battery
    B1728 Seat Driver Rear Up Switch Circuit Short To Ground
    B1729 Seat Driver Rear Down Switch Circuit Failure
    B1730 Seat Driver Rear Down Switch Circuit Open
    B1731 Seat Driver Rear Down Switch Circuit Short To Battery
    B1732 Seat Driver Rear Down Switch Circuit Short To Ground
    B1733 Mirror Driver Vertical Switch Circuit Failure
    B1734 Mirror Driver Vertical Switch Circuit Open
    B1735 Mirror Driver Vertical Switch Circuit Short To Battery
    B1736 Mirror Driver Vertical Switch Circuit Short To Ground
    B1737 Mirror Driver Horizontal Switch Circuit Failure
    B1738 Mirror Driver Horizontal Switch Circuit Open
    B1739 Mirror Driver Horizontal Switch Circuit Short To Battery
    B1740 Mirror Driver Horizontal Switch Circuit Short To Ground
    B1741 Mirror Passenger Vertical Switch Circuit Failure
    B1742 Mirror Passenger Vertical Switch Circuit Open
    B1743 Mirror Passenger Vertical Switch Circuit Short To Battery
    B1744 Mirror Passenger Vertical Switch Circuit Short To Ground
    B1745 Mirror Passenger Horizontal Switch Circuit Failure
    B1746 Mirror Passenger Horizontal Switch Circuit Open
    B1747 Mirror Passenger Horizontal Switch Circuit Short To Battery
    B1748 Mirror Passenger Horizontal Switch Circuit Short To Ground
    B1749 Park/Neutral Switch Circuit Failure
    B1750 Park/Neutral Switch Circuit Open
    B1751 Park/Neutral Switch Circuit Short To Battery
    B1752 Park/Neutral Switch Circuit Short To Ground
    B1753 Hazard Flash Output Circuit Failure
    B1754 Hazard Flash Output Circuit Open
    B1755 Hazard Flash Output Circuit Short Battery
    B1756 Hazard Flash Output Circuit Short To Ground
    B1757 Seat Driver Rear Down Circuit Failure
    B1758 Seat Driver Rear Down Circuit Open
    B1759 Seat Driver Rear Down Circuit Short To Battery
    B1760 Seat Driver Rear Down Circuit Short To Ground
    B1761 Seat Driver Front Down Circuit Failure
    B1762 Seat Driver Front Down Circuit Open
    B1763 Seat Driver Front Down Circuit Short To Battery
    B1764 Seat Driver Front Down Circuit Short To Ground
    B1765 Seat Driver Forward Circuit Failure
    B1766 Seat Driver Forward Circuit Open
    B1767 Seat Driver Forward Circuit Short To Battery
    B1768 Seat Driver Forward Circuit Short To Ground
    B1769 Seat Driver Backward Circuit Failure
    B1770 Seat Driver Backward Circuit Open
    B1771 Seat Driver Backward Circuit Short To Battery
    B1772 Seat Driver Backward Circuit Short To Ground
    B1773 Mirror Driver Up Circuit Failure
    B1774 Mirror Driver Up Circuit Open
    B1775 Mirror Driver Up Circuit Short To Battery
    B1776 Mirror Driver Up Circuit Short To Ground
    B1777 Driver's Seatbelt Tension Reducer Circuit Short to Ground
    B1778 Mirror Driver Down Circuit Failure
    B1779 Mirror Driver Down Circuit Open
    B1780 Mirror Driver Down Circuit Short To Battery
    B1781 Mirror Driver Down Short To Ground
    B1782 Mirror Passenger Up Circuit Failure
    B1783 Mirror Passenger Up Circuit Open
    B1784 Mirror Passenger Up Circuit Short To Battery
    B1785 Mirror Passenger Up Circuit Short To Ground
    B1786 Mirror Passenger Down Circuit Failure
    B1787 Mirror Passenger Down Circuit Open
    B1788 Mirror Passenger Down Circuit Short To Battery
    B1789 Mirror Passenger Down Circuit Short To Ground
    B1790 Autolamp Sensor Input Circuit Failure
    B1791 Autolamp Sensor Input Circuit Open
    B1792 Autolamp Sensor Input Circuit Short To Battery
    B1793 Autolamp Sensor Input Circuit Short To Ground
    B1794 Lamp Headlamp Low-Beam Circuit Failure
    B1795 Lamp Headlamp Low-Beam Circuit Open
    B1796 Lamp Headlamp Low-Beam Circuit Short To Battery
    B1797 Lamp Headlamp Low-Beam Circuit Short To Ground
    B1798 Lamp Turn Signal Front Output Circuit Failure
    B1799 Lamp Turn Signal Front Output Circuit Open
    B1800 Lamp Turn Signal Front Output Circuit Short To Battery
    B1801 Lamp Turn Signal Front Output Circuit Short To Ground
    B1802 Lamp Turn Signal Rear Output Circuit Failure
    B1803 Lamp Turn Signal Rear Output Circuit Open
    B1804 Lamp Turn Signal Rear Output Circuit Short To Battery
    B1805 Lamp Turn Signal Rear Output Circuit Short To Ground
    B1806 Lamp Tail Output Circuit Failure
    B1807 Lamp Tail Output Circuit Open
    B1808 Lamp Tail Output Circuit Short To Battery
    B1809 Lamp Tail Output Circuit Short To Ground
    B1810 Lamp Backup Switch Input Circuit Failure
    B1811 Lamp Backup Switch Input Circuit Open
    B1812 Lamp Backup Switch Input Circuit Short To Battery
    B1813 Lamp Backup Switch Input Circuit Short To Ground
    B1814 Wiper Rear Motor Down Relay Coil Circuit Failure
    B1815 Wiper Rear Motor Down Relay Coil Circuit Open
    B1816 Wiper Rear Motor Down Relay Coil Circuit Short To Battery
    B1817 Wiper Rear Motor Down Relay Coil Circuit Short To Ground
    B1818 Wiper Rear Motor Up Relay Coil Circuit Failure
    B1819 Wiper Rear Motor Up Relay Coil Circuit Open
    B1820 Wiper Rear Motor Up Relay Coil Circuit Short To Battery
    B1821 Wiper Rear Motor Up Relay Coil Circuit Short To Ground
    B1822 Wiper Rear Park Sense Input Circuit Failure
    B1823 Wiper Rear Park Sense Input Circuit Open
    B1824 Wiper Rear Park Sense Input Circuit Short To Battery
    B1825 Wiper Rear Park Sense Input Circuit Short To Ground
    B1826 Wiper Rear High Limit Input Circuit Failure
    B1827 Wiper Rear High Limit Input Circuit Open
    B1828 Wiper Rear High Limit Input Circuit Short To Battery
    B1829 Wiper Rear High Limit Input Circuit Short To Ground
    B1830 Door Unlock Disarm Switch Circuit Failure
    B1831 Door Unlock Disarm Switch Circuit Open
    B1832 Door Unlock Disarm Switch Circuit Short To Battery
    B1833 Door Unlock Disarm Switch Circuit Short To Ground
    B1834 Door Unlock Disarm Output Circuit Failure
    B1835 Door Unlock Disarm Output Circuit Open
    B1836 Door Unlock Disarm Output Circuit Short To Battery
    B1837 Door Unlock Disarm Output Circuit Short To Ground
    B1838 Battery Saver Power Relay Circuit Failure
    B1839 Wiper Rear Motor Circuit Failure
    B1840 Wiper Front Power Circuit Failure
    B1841 Wiper Front Power Circuit Open
    B1842 Wiper Front Power Circuit Short To Battery
    B1843 Wiper Front Power Circuit Short To Ground
    B1844 Phone Handset Circuit Failure
    B1845 Ignition Tamper Circuit Failure
    B1846 Ignition Tamper Circuit Open
    B1847 Ignition Tamper Circuit Short To Battery
    B1848 Ignition Tamper Circuit Short To Ground
    B1849 Climate Control Temperature Differential Circuit Failure
    B1850 Climate Control Temperature Differential Circuit Open
    B1851 Climate Control Temperature Differential Circuit Short To Battery
    B1852 Climate Control Temperature Differential Circuit Short To Ground
    B1853 Climate Control Air Temperature Internal Sensor Motor Circuit Failure
    B1854 Climate Control Air Temperature Internal Sensor Motor Circuit Open
    B1855 Climate Control Air Temperature Internal Sensor Motor Circuit Short To Battery
    B1856 Climate Control Air Temperature Internal Sensor Motor Circuit Short To Ground
    B1857 Climate Control On/Off Switch Circuit Failure
    B1858 Climate Control A/C Pressure Switch Circuit Failure
    B1859 Climate Control A/C Pressure Switch Circuit Open
    B1860 Climate Control A/C Pressure Switch Circuit Short To Battery
    B1861 Climate Control A/C Pressure Switch Circuit Short To Ground
    B1862 Climate Control A/C Lock Sensor Failure
    B1863 Ground ECU Circuit Open
    B1864 Battery Power Supply ECU Circuit Failure
    B1865 Battery Power Supply ECU Circuit Open
    B1866 Battery Power Supply ECU Circuit Short To Battery
    B1867 Battery Power Supply ECU Circuit Short To Ground
    B1868 Lamp Air Bag Warning Indicator Circuit Failure
    B1869 Lamp Air Bag Warning Indicator Circuit Open
    B1870 Lamp Air Bag Warning Indicator Circuit Short To Battery
    B1871 Passenger Air Bag Disable Module Fault
    B1872 Turn Signal / Hazard Power Feed Circuit Short To Battery
    B1873 Turn Signal / Hazard Power Feed Circuit Short To Ground
    B1874 Cellular Phone Handset Not Present
    B1875 Turn Signal / Hazard Switch Signal Circuit Failure
    B1876 Seatbelt Driver Pretensioner Circuit Failure
    B1877 Seatbelt Driver Pretensioner Circuit Open
    B1878 Seatbelt Driver Pretensioner Circuit Short to Battery
    B1879 Seatbelt Driver Pretensioner Circuit Short to Ground
    B1880 Seatbelt Passenger Pretensioner Circuit Failure
    B1881 Seatbelt Passenger Pretensioner Circuit Open
    B1882 Seatbelt Passenger Pretensioner Circuit Short to Battery
    B1883 Seatbelt Passenger Pretensioner Circuit Short to Ground
    B1884 PAD Warning Lamp Inoperative
    B1885 Seatbelt Driver Pretensioner Circuit Resistance Low on Squib
    B1886 Seatbelt Passenger Pretensioner Circuit Resistance Low on Squib
    B1887 Air Bag Driver Circuit Resistance Low or Shorted Together
    B1888 Air Bag Passenger Circuit Resistance Low or Shorted Together
    B1889 Passenger Airbag Disable Module Sensor Obstructed
    B1890 PAD Warning Lamp Circuit Short to Battery
    B1891 Air Bag Tone Warning Indicator Circuit Short to Battery
    B1892 Air Bag Tone Warning Indicator Circuit Failure
    B1893 GPS Antenna Open Circuit
    B1894 Wiper Rear Motor Speed Sense Circuit Failure
    B1895 Driver's / Passenger's Door Ajar Output Circuit Failure
    B1896 Driver's / Passenger's Door Ajar Output Circuit Short to Battery
    B1897 Horn Switch Circuit Failure
    B1898 Chime Input #2 Circuit Short to Ground
    B1899 Microphone Input Signal Circuit Open
    B1900 Driver Side Airbag Fault
    B1901 Air Bag Crash Sensor #1 Feed/Return Circuit Short To Ground
    B1902 Air Bag Crash Sensor #1 Ground Circuit Failure
    B1903 Air Bag Crash Sensor #1 Ground Circuit Short To Battery
    B1904 Air Bag Crash Sensor #2 Feed/Return Circuit Failure
    B1905 Air Bag Crash Sensor #2 Feed/Return Circuit Short To Battery
    B1906 Air Bag Crash Sensor #2 Feed/Return Circuit Short To Ground
    B1907 Air Bag Crash Sensor #2 Ground Circuit Failure
    B1908 Air Bag Crash Sensor #2 Ground Circuit Short To Battery
    B1909 Air Bag Crash Sensor #2 Ground Circuit Short To Ground
    B1910 Air Bag Diagnostic Monitor Ground Circuit Failure
    B1911 Air Bag Diagnostic Monitor Ground Circuit Short To Battery
    B1912 Air Bag Diagnostic Monitor Ground Circuit Short To Ground
    B1913 Air Bag Driver/Passenger Circuit Short To Ground
    B1914 Air Bag Crash Sensors #1 / #2 Circuit Short To Ground
    B1915 Air Bag Driver Circuit Failure
    B1916 Air Bag Driver Circuit Short To Battery
    B1917 Air Bag Memory Clear Circuit Failure
    B1918 Air Bag Memory Clear Circuit Open
    B1919 Air Bag Memory Clear Circuit Short To Battery
    B1920 Air Bag Passenger Circuit Failure
    B1921 Air Bag Diagnostic Monitor Ground Circuit Open
    B1922 Air Bag Safing Sensor Output Circuit Short To Battery
    B1923 Air Bag Memory Clear Circuit Short To Ground
    B1924 Air Bag Internal Diagnostic Monitor Fault or System Disarm Fault
    B1925 Air Bag Passenger Circuit Short To Battery
    B1926 Air Bag Passenger Pressure Switch Circuit Failure
    B1927 Passenger Side Airbag Fault
    B1928 Air Bag Safing Sensor Output Circuit Failure
    B1929 Air Bag Safing Sensor Output Circuit Open
    B1930 Air Bag Safing Sensor Output Circuit Short To Ground
    B1931 Air Bag Crash Sensor #1 Feed/Return Circuit Failure
    B1932 Air Bag Driver Circuit Open
    B1933 Air Bag Passenger Circuit Open
    B1934 Air Bag Driver Inflator Circuit Resistance Low on Squib
    B1935 Air Bag Passenger Inflator Circuit Resistance Low on Squib
    B1936 Air Bag Driver Circuit Short To Ground
    B1937 Air Bag Passenger Pressure Switch Circuit Open
    B1938 Air Bag Passenger Circuit Short To Ground
    B1939 Air Bag Passenger Pressure Switch Circuit Short To Ground
    B1941 Air Bag Crash Sensor #1 Feed/Return Circuit Open
    B1942 Air Bag Crash Sensor #2 Feed/Return Circuit Open
    B1943 Air Bag Crash Sensor #1 Ground Circuit Short To Ground
    B1944 Air Bag Crash Sensor #1 Ground Circuit Open
    B1945 Air Bag Crash Sensor #2 Ground Circuit Open
    B1946 Climate Control A/C Post Evaporator Sensor Circuit Failure
    B1947 Climate Control A/C Post Evaporator Sensor Circuit Short To Ground
    B1948 Climate Control Water Temperature Sensor Circuit Failure
    B1949 Climate Control Water Temperature Sensor Circuit Short To Ground
    B1950 Seat Rear Up/Down Potentiometer Feedback Circuit Failure
    B1951 Seat Rear Up/Down Potentiometer Feedback Circuit Open
    B1952 Seat Rear Up/Down Potentiometer Feedback Circuit Short To Battery
    B1953 Seat Rear Up/Down Potentiometer Feedback Circuit Short To Ground
    B1954 Seat Front Up/Down Potentiometer Feedback Circuit Failure
    B1955 Seat Front Up/Down Potentiometer Feedback Circuit Open
    B1956 Seat Front Up/Down Potentiometer Feedback Circuit Short To Battery
    B1957 Seat Front Up/Down Potentiometer Feedback Circuit Short To Ground
    B1958 Seat Recline Forward/Backward Potentiometer Feedback Circuit Failure
    B1959 Seat Recline Forward/Backward Potentiometer Feedback Circuit Open
    B1960 Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Battery
    B1961 Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Ground
    B1962 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Failure
    B1963 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Open
    B1964 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Battery
    B1965 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Ground
    B1966 A/C Post Heater Sensor Circuit Failure
    B1967 A/C Post Heater Sensor Circuit Short To Ground
    B1968 A/C Water Pump Detection Circuit Failure
    B1969 A/C Clutch Magnetic Control Circuit Failure
    B1970 Passenger Seatback Forward Switch Circuit Short to Ground
    B1971 Passenger Seatback Rearward Switch Circuit Short to Ground
    B1972 Passenger Rear Seat Up Switch Circuit Short to Battery
    B1973 Passenger Rear Seat Down Switch Circuit Short to Battery
    B1974 Passenger's Seat Recline Forward Switch Circuit Short to Battery
    B1975 Passenger's Seat Recline Back Switch Circuit Short to Battery
    B1976 Passenger's Seat Forward Switch Circuit Short to Battery
    B1977 Passenger's Front Seat Up Switch Circuit Short to Battery
    B1978 Passenger's Front Seat Down Switch Circuit Short to Battery
    B1979 Passenger Seat Rearward Switch Circuit Short to Battery
    B1980 Bulb - Outage Condition Detected
    B1981 Memory Off Switch Circuit Short to Battery
    B1982 Driver's Door Unlock Relay Circuit Failure
    B1983 Driver's Door Unlock Relay Circuit Short to Battery
    B1984 Seat Switch Lumbar Inflate Circuit Failure
    B1985 Seat Switch Lumbar Deflate Circuit Failure
    B1986 Driver's Seat Seatback Autoglide Rearward Switch Circuit Failure
    B1987 Pedal Forward / Rearward Motor Stalled
    B1988 Pedal Position Forward Switch Circuit Short to Battery
    B1989 Pedal Position Rearward Switch Circuit Short to Battery
    B1990 Pedal Forward / Rearward Potentiometer Feedback Circuit Failure
    B1991 Pedal Forward / Rearward Potentiometer Feedback Circuit Short to Battery
    B1992 Driver Side, Side mount Airbag Circuit Short to Vbatt
    B1993 Driver Sid, Side mount Airbag Circuit Short to Ground
    B1994 Driver Sid, Side mount Airbag Circuit Open
    B1995 Driver Sid, Side mount Airbag Low resistance on Squib
    B1996 Passenger Sid, Side mount Airbag Circuit Short to Vbatt
    B1997 Passenger Sid, Side mount Airbag Circuit Short to Ground
    B1998 Passenger Sid, Side mount Airbag Circuit Open
    B1999 Passenger Sid, Side mount Airbag Low resistance on Squib
    B2100 Door Driver Key Cylinder Switch Failure
    B2101 Head Rest Switch Circuit Failure
    B2102 Antenna Circuit Short to Ground
    B2103 Antenna Not Connected
    B2104 Door Passenger Key Cylinder Switch Failure
    B2105 Throttle Position Input Out of Range Low
    B2106 Throttle Position Input Out of Range High
    B2107 Front Wiper Motor Relay Circuit Short to Vbatt
    B2108 Trunk Key Cylinder Switch Failure
    B2109 Heated Wind Shield Relay Short to Vbatt (changed from Failure 2/6/97)
    B2110 Front Wiper Motor Relay Circuit Open (changed from Failure 2/6/97)
    B2111 All Door Lock Input Short to Ground
    B2112 Door Driver Set Switch Stuck Failure
    B2113 Heated Windshield Input Short to Ground
    B2114 Front Washer Input Short to Ground
    B2115 Rear Washer Input Short to Ground
    B2116 Door Driver Reset Switch Stuck Failure
    B2117 Driver Side, Side mount Airbag Low capacitance on Squib
    B2118 Passenger Sid, Side mount Airbag Low capacitance on Squib
    B2119 Compressor Failure
    B2120 Door Passenger Set Switch Stuck Failure
    B2122 Driver Side Satellite Communication Circuit Short to Ground
    B2123 Passenger Side Satellite Communication Circuit Short to Ground
    B2124 Door Passenger Reset Switch Stuck Failure
    B2128 Central Lock Motor Failure
    B2129 Central Lock Feedback Failure
    B2130 Double Lock Timeout Failure
    B2131 Double Lock Feedback Failure
    B2132 Dimmer switch Circuit Short to Gnd
    B2133 Brake Motor Warning lamp Circuit Failure
    B2134 Brake Motor Warning lamp Circuit Short to Vbatt
    B2135 Park Brake Applied Warning Lamp Circuit Failure
    B2136 Park Brake Applied Warning Lamp Circuit Short To Battery
    B2139 Data Mismatch (receive data does not match what was expected)
    B2141 NVM Configuration Failure
    B2142 NVM TIC Failure
    B2143 NVM Memory Failure
    B2144 NVM Alarm Data Failure
    B2145 NVM RF HR Failure
    B2146 Seat Recline Motor Position Out of Range
    B2148 PWM Input Circuit Failure
    B2149 Seat Front Vertical Motor Position Out of Range
    B2150 Power Supply #1 Circuit Short to Ground
    B2151 Power Supply #2 Circuit Short to Ground
    B2152 Seat Rear Vertical Motor Position Out of Range
    B2153 Rear Echo Sensor Circuit Failure
    B2154 Front Echo Sensor Circuit Failure
    B2155 Seat Horizontal Motor Position Out of Range
    B2156 Rear Doppler Sensor Circuit Failure
    B2157 Front Doppler Sensor Circuit Failure
    B2158 Seat Recline Motor Memory Position Out of Range
    B2159 Memory #1 output Short to Ground
    B2160 Memory #1 output Short to VBatt
    B2161 Seat Front Vertical Motor Memory Position Out of Range
    B2162 Data Mismatch #2 (receive data does not match what was expected)
    B2163 Clutch Position Fault
    B2164 Seat Rear Vertical Motor Memory Position Out of Range
    B2165 Gear shift position Fault
    B2166 Gear select position Fault
    B2167 Seat Horizontal Motor Memory Position Out of Range
    B2168 Unable to confirm Unlock Condition
    B2169 Unable to confirm lock Condition
    B2170 Steering Column Lock Switch Circuit Failure
    B2172 Inertia Switch input Circuit Open
    B2174 Window Driver Rear Remote Up Switch Short to Battery
    B2175 A/C Request Signal Circuit Short to Ground
    B2176 Overdrive switch circuit short to Vbatt
    B2177 Interior Scanning Sensor Circuit Failure
    B2178 Window Driver Rear Remote Down Switch Short to Battery
    B2179 Front Wiper Select Switch "A" Short to Ground
    B2180 Front Wiper Select Switch "B" Short to Ground
    B2181 Front Wiper Select Switch "C" Short to Ground
    B2182 Window Passenger Front Remote Up Switch Short to Battery
    B2183 Front Wiper Select Switch "H" Short to Ground
    B2184 Front Wiper Select Switch "W" Short to Ground
    B2185 Rear Wiper Select Switch "D" Short to Ground
    B2186 Window Passenger Front Remote Down Switch Short to Battery
    B2187 Rear Wiper Select Switch "B" Short to Ground
    B2188 Rear Wiper Select Switch "E" Short to Ground
    B2190 Window Passenger Rear Remote Up Switch Short to Battery
    B2194 Window Passenger Rear Remote Down Switch Short to Battery
    B2195 Driver Window Up / Down Power Circuit Short to Ground
    B2196 Passenger Window Up / Down Power Circuit Short to Ground
    B2197 TV Module Error
    B2198 TrafficMaster Module Error
    B2199 VICS Module Error
    B2200 No Communication to TV Module (No Fitting of TV)
    B2201 No Communication With Traffic MasterModule
    B2202 No Communication to VICS Module (No Fitting of VICS)
    B2203 CD-ROM Error
    B2204 GPS Antenna Connection Open or Short
    B2205 GPS Receiver Error
    B2206 Gyroscope Error
    B2207 ECU ROM Checksum Error
    B2208 Communication Link to Display and Switch Module Error
    B2209 Interior Lamp Override Switch Open Circuit
    B2210 Interior Lamp Override Switch Short to Ground
    B2211 Low Coolant Lamp Output Circuit Short to Battery
    B2214 Window Passenger Front Up Switch Short to Battery
    B2215 Window Passenger Front Down Switch Short to Battery
    B2219 Window Driver Front Current Feedback Exceeded
    B2220 Window Driver Rear Current Feedback Exceeded
    B2221 Window Passenger Front Current Feedback Exceeded
    B2222 Window Passenger Rear Current Feedback Exceeded
    B2223 Mirror Driver Drive Circuit Failure
    B2224 Mirror Passenger Drive Circuit Failure
    B2225 Front Crash Sensor Mount Fault
    B2226 Front Crash Sensor Internal Fault
    B2227 Front Crash Sensor Driver Communications Fault
    B2228 Air Bag Driver Circuit Short to Ground - Loop #2
    B2229 Air Bag Passenger Circuit Short to Ground - Loop #2
    B2230 Air Bag Driver Circuit Short to Battery - Loop #2
    B2231 Air Bag Passenger Circuit Short to Battery - Loop #2
    B2232 Air Bag Driver Circuit Open - Loop #2
    B2233 Air Bag passenger Circuit Open - Loop #2
    B2234 Air Bag Driver Inflator Circuit Resistance Low on Squib - Loop #2
    B2235 Air Bag Passenger Inflator Circuit
    B2236 Weak or Defected Electric Vehicle Battery Module Fault
    B2237 Vehicle Signal indicating Park While VSS Present
    B2238 Power Cable For Power Sliding Door Broken
    B2239 Rear Cargo Door Set Switch Stuck (Short to Ground)
    B2240 Rear Cargo Door Reset Switch Stuck (Short to Ground)
    B2241 Rear Cargo Door Lock Circuit Short to Ground
    B2242 Rear Cargo Door Unlock Circuit Open
    B2243 Driver Rear Door Ajar Circuit Open
    B2244 Driver Sliding Door Ajar Circuit Short to GND
    B2245 Passenger Rear Door Ajar Circuit Open
    B2246 Passenger Sliding Door Ajar Circuit Short to GND
    B2247 EV Battery Pack Temperature Fault
    B2248 Heated Windshield Relay Coil Circuit Failure
    B2249 Head Lamp Relay Coil Short to Battery
    B2250 All Doors Unlock Relay Circuit Failure
    B2251 Parklamp Output Relay Driver Circuit Failure
    B2252 Parklamp Output Relay Dirver Short to Battery
    B2300 Seat Driver Memory Position Error
    B2301 Seat Passenger Memory Position Error
    B2302 Seat Headrest Feedback Potentiometer Circuit Failure
    B2303 Seat Headrest Feedback Potentiometer Circuit Open
    B2304 Seat Headrest Feedback Potentiometer Circuit Short to Battery
    B2305 Seat Headrest Feedback Potentiometer Circuit Short to Ground
    B2306 Seat Headrest Motor Stalled
    B2310 Mirror Driver Memory Position Error
    B2311 Mirror Passenger Memory Position Error
    B2312 Mirror Passenger Horizontal Feedback Potentiometer Circuit Failure
    B2313 Mirror Passenger Horizontal Feedback Potentiometer Circuit Open
    B2314 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Battery
    B2315 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Ground
    B2316 Mirror Passenger Vertical Feedback Potentiometer Circuit Failure
    B2317 Mirror Passenger Vertical Feedback Potentiometer Circuit Open
    B2318 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Battery
    B2319 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Ground
    B2320 Mirror Driver Horizontal Feedback Potentiometer Circuit Failure
    B2321 Mirror Driver Horizontal Feedback Potentiometer Circuit Open
    B2322 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Battery
    B2323 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Ground
    B2324 Mirror Driver Vertical Feedback Potentiometer Circuit Failure
    B2325 Mirror Driver Vertical Feedback Potentiometer Circuit Open
    B2326 Mirror Driver Vertical Feedback Potentiometer Circuit Short to Battery
    B2327 Mirror Driver Vertical Feedback Potentiometer Circuit Short to Ground
    B2328 Column Reach Feedback Potentiometer Circuit Failure
    B2329 Column Reach Feedback Potentiometer Circuit Open
    B2330 Column Reach Feedback Potentiometer Circuit Short to Battery
    B2331 Column Reach Feedback Potentiometer Circuit Short to Ground
    B2332 Column Tilt Feedback Potentiometer Circuit Failure
    B2333 Column Tilt Feedback Potentiometer Circuit Open
    B2334 Column Tilt Feedback Potentiometer Circuit Short to Battery
    B2335 Column Tilt Feedback Potentiometer Circuit Short to Ground
    B2336 Mirror Switch Assembly Circuit Failure
    B2337 Mirror Switch Assembly Circuit Open
    B2338 Mirror Switch Assembly Circuit Short to Battery
    B2339 Mirror Switch Assembly Circuit Short to Ground
    B2340 Column Reach Motor Stalled
    B2341 Column Tilt Motor Stalled
    B2342 Seat Switch Reference Voltage Positive Common Open Circuit
    B2343 Seat Switch Reference Voltage Positive Common Supply Low Voltage
    B2344 Seat Switch Reference Voltage Positive Common Supply Voltage Fault
    B2345 Seat Switch Reference Voltage Negative Common Open Circuit
    B2346 Mirror Switch Reference Voltage Positive Common Open Circuit
    B2347 Mirror Switch Reference Voltage Positive Common Supply Low Voltage
    B2348 Mirror Switch Reference Voltage Positive Common Supply Voltage Fault
    B2349 Mirror Switch Reference Voltage Negative Common Open Circuit
    B2350 Steering Column Switch Circuit Short to Battery
    B2351 Steering Column Switch Circuit Failure
    B2352 Driver Memory Power Switch Indicator Circuit Short to Battery
    B2353 Driver Mirror Power Driver Circuit Short Ground
    B2354 Driver Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open
    B2355 Passenger Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open
    B2357 Driver Window Down Current Sense Low Circuit Failure
    B2362 Remote Open/Close signal Circuit Short to Ground
    B2363 Optical Sensor System Failure
    B2364 Fuel Filler Door Circuit Open
    B2365 B-pillar Power Sliding Door Open/Close Switch Input Ckt Short to Gnd
    B2366 IP Power Sliding Door Open/Close switch Ckt Short to Gnd
    B2367 Power Sliding Door Override Switch Input Ckt Short to Gnd
    B2368 Steering Column Switch Circuit Out of Range
    B2369 Chime OUTPUT Request Ckt Short to Ground
    B2373 LED #1 Circuit Short to Battery
    B2374 Power Sliding Detent (Latch) Circuit Failure
    B2380 Heater Coolant Temp sensor circuit Short to GND
    B2381 Heater Coolant Temp sensor circuit Open
    B2384 Audio Reverse Aid Mute Input Ckt Failure
    B2385 Audio Navigation Mute Input Ckt Failure
    B2401 Audio Tape Deck Mechanism Fault
    B2402 Audio CD/DJ Thermal Shutdown Fault
    B2403 Audio CD/DJ Internal Fault
    B2404 Audio Steering Wheel Switch Circuit Fault
    B2405 Audio Single-Disc CD Player Thermal Shutdown Fault
    B2406 Audio Single-Disc CD Player Internal Fault
    B2416 Climate Control Recirculation Actuator Out of Limits
    B2425 Remote Keyless Entry Out of Synchronization
    B2426 Passenger Solar Radiation Sensor Circuit Open
    B2427 Passenger Solar Radiation Sensor Circuit Short to Ground
    B2428 A/C Post Heater Sensor #2 Circuit Failure
    B2429 A/C Post Heater Sensor #2 Circuit Short to Ground
    B2431 Transponder Programming Failed
    B2432 Drivers Seat Belt Buckle Switch Circuit Open
    B2433 Drivers Seat Belt Buckle Switch Circuit Short to Battery
    B2434 Drivers Seat Belt Buckle Switch Circuit Short to Ground
    B2435 Drivers Seat Belt Buckle Switch Resistance out of Range
    B2436 Passengers Seat Belt Buckle Switch Circuit Open
    B2437 Passengers Seat Belt Buckle Switch Circuit Short to Battery
    B2438 Passengers Seat Belt Buckle Switch Circuit Short to Ground
    B2439 Passengers Seat Belt Buckle Switch Resistance out of Range
    B2440 Passenger Sid, Side crash sensor mount fault
    B2441 Driver Sid, Side crash sensor mount fault
    B2442 Intrusion Sensor Fault
    B2443 Powertrain Performance Mode Switch Circuit failure
    B2444 Driver Side Crash Sensor Internal Fault
    B2445 Passenger Side Crash Sensor Internal Fault
    B2446 RESCU/VEMS Input Circuit Open
    B2447 RESCU/VEMS Input Circuit Short to Battery
    B2448 RESCU/VEMS Input Circuit Short to Ground
    B2449 Aux Heater Glow Plug Circuit Short to Ground
    B2450 Aux Heater Glow Plug Circuit Open
    B2451 Aux Heater Fuel Pump Circuit Short to Ground
    B2452 Aux Heater Fuel Pump Circuit Open
    B2453 Aux Heater Blower Fan Circuit Short to Ground
    B2454 Aux Heater Blower Fan Circuit Open
    B2455 Aux Heater Blower Faulted
    B2456 Aux Heater Coolant Sensor Circuit Short to Ground
    B2457 Aux Heater Coolant Sensor Circuit Open
    B2458 Aux Heater Overheat Sensor Circuit Short to Ground
    B2459 Aux Heater Overheat Sensor Circuit Open
    B2460 Aux Heater Flame Sensor Circuit Short to Ground
    B2461 Aux Heater Flame Sensor Circuit Open
    B2462 Aux Heater Flame Out Fault
    B2463 Aux Heater Overheat Fault
    B2464 Aux Heater Start Time Exceeded
    B2465 Aux Heater Start Counter Overrun/System Locked (same as below ?)
    B2466 Aux Heater Overheat Counter Overrun/System Locked
    B2467 Aux Heater Cool Down Time Exceeded (may be con to a453-5 )
    B2468 Aux Heater Coolant Pump Circuit Short to Ground
    B2469 Aux Heater Coolant Pump Circuit Open
    B2470 Interior Fan Control Circuit Short to Ground
    B2471 Interior Fan Control Circuit Open
    B2472 Fog Lamp Switch Failure
    B2473 Passenger Door Disarm Switch ckt Short to Ground
    B2474 Passenger Door Lock Switch Circuit Shorted to Ground
    B2475 Passenger Door Unlock Switch Circuit Shorted to Ground
    B2476 RADIO PRESENT SWITCH Ckt Failure
    B2477 Module Configuration Failure
    B2478 ANTI THEFT INPUT SIGNAL SHORT TO GROUND
    B2479 BRAKE PARK SWITCH CIRCUIT SHORT TO GROUND
    B2480 LF CORNER LAMP OUTPUT Ckt Short to Battery
    B2481 Convertible Top Up/Down switch Fault
    B2482 RF CORNER LAMP OUTPUT Ckt Short to Battery
    B2483 Enable Signal Open Circuit
    B2484 Disable Signal Short to Ground
    B2485 LF SIDE REPEATER LAMP OUTPUT Ckt Short to Battery
    B2487 RF SIDE REPEATER LAMP OUTPUT Ckt Short to Battery
    B2489 UNDERHOOD LAMP OUTPUT CIRCUIT Failure
    B2490 UNDERHOOD LAMP OUTPUT CIRCUIT Short to Battery
    B2491 RF PARK LAMP OUTPUT CIRCUIT Short to Battery
    B2492 Already Programmed (Test Mode DTC Only !!!)
    B2493 LF PARK LAMP OUTPUT CIRCUIT Short to Battery
    B2494 ANTI THEFT HORN OUTPUT CIRCUIT Short to Batt
    B2495 ANTI THEFT HORN OUTPUT CIRCUIT Failure
    B2496 ANTI THEFT HORN OUTPUT CIRCUIT Short to Gnd
    B2499 COURTESY LAMP OUTPUT Failure
    B2500 COURTESY LAMP OUTPUT Ckt Short to Battery
    B2501 LF LAMP LOW BEAM CIRCUIT Failure
    B2502 LF LAMP LOW BEAM CIRCUIT Short to Battery
    B2503 RF LAMP LOW BEAM CIRCUIT Failure
    B2504 RF LAMP LOW BEAM CIRCUIT Short to Battery
    B2505 LF LAMP HIGH BEAM CIRCUIT Failure
    B2506 LF LAMP HIGH BEAM CIRCUIT Short to Battery
    B2507 RF LAMP HIGH BEAM CIRCUIT Failure
    B2508 RF LAMP HIGH BEAM CIRCUIT Short to Battery
    B2509 Rear Fog Lamp Switch Circuit Failure
    B2510 Main Blower Motor Relay Circuit Short to Battery
    B2511 Horn Output Relay Circuit Short to Battery
    B2512 Front Fog Lamp Relay Ckt Short to Battery
    B2513 Blower (Fan) Circuit Failure
    B2514 Blower (Fan) Circuit Short to Vbatt
    B2515 Heater Blower Relay Circuit Failure
    B2516 Blower Control Circuit Failure
    B2517 Emergency Power Off System Faulted
    B2518 Compressor Overtemp Fault
    B2519 High Mount Stop Lamp Circuit Failure
    B2520 High Mount Stop Lamp Circuit Short to Battery
    B2523 License Lamp Circuit Failure
    B2524 License Lamp Circuit Short to Battery
    B2525 Left Rear Backup Lamp Circuit Failure
    B2526 Left Rear Backup Lamp Circuit Short to Battery
    B2527 Left Rear Stop lamp Circuit Failure
    B2528 Left Rear Stop lamp Circuit Short to Battery
    B2529 Left Rear Turn Lamp Circuit Failure
    B2530 Left Rear Turn Lamp Circuit Short to Battery
    B2531 Right Rear Backup Lamp Circuit Failure
    B2532 Right Rear Backup Lamp Circuit Short to Battery
    B2533 Right Rear Stop lamp Circuit Failure
    B2534 Right Rear Stop lamp Circuit Short to Battery
    B2535 Right Rear Turn Lamp Circuit Failure
    B2536 Right Rear Turn Lamp Circuit Short to Battery
    B2539 Aux A/C Mode Position Reference Circuit Short to Ground
    B2540 Aux A/C Mode Position Reference Circuit Short to Battery
    B2543 Aux A/C Control Switch Reference Circuit Short to Ground
    B2544 Aux A/C Control Switch Reference Circuit Short to Battery
    B2545 System Power Relay Circuit Short to Battery
    B2546 System Power Relay Circuit Failure
    B2550 LAMP DOME OUTPUT Circuit Short to Ground
    B2553 Disable Signal Output Circuit Short to Battery
    B2554 LAMP DOME OUTPUT Circuit Failure
    B2555 LAMP DOME OUTPUT Circuit Short to Battery
    B2556 Enable Signal Circuit Short to Battery
    B2557 Left Power Sliding Door Open/Close Output Circuit Short to Battery
    B2558 Right Power Sliding Door Open/Close Output Circuit Short to Battery
    B2559 Aux A/C Blower Motor Relay Circuit Short to Battery
    B2560 Aux A/C Blower Motor Relay Circuit Short to Ground
    B2561 Aux A/C Blower Speed 1 Circuit Failure
    B2562 Aux A/C Blower Speed 1 Circuit Short to Ground
    B2563 Aux A/C Blower Speed 2 Circuit Failure
    B2564 Aux A/C Blower Speed 2 Circuit Short to Ground
    B2565 Right Tail Lamp Circuit Failure
    B2566 Right Tail Lamp Circuit Short to Ground
    B2567 Reverse Mirror Output Circuit Failure
    B2568 Reverse Mirror Output Circuit Short to Ground
    B2569 Liftgate Disarm Switch Circuit Short to Ground
    B2570 Right Lamp Outage Signal Circuit Short to Ground
    B2571 Left Lamp Outage Signal Circuit Short to Ground
    B2580 Aux Blower Sense Switch Circuit Failure
    B2581 Passenger Seat Occupant Detection Circuit Short To Ground
    B2582 Passenger Seat Occupant Detection Circuit Open
    B2583 Child Seat Detection Circuit Short to Ground
    B2584 Child Seat Detection Circuit Open
    B2585 Anti Theft Input Signal Circuit Short To Battery
    B2586 Headlamp Mode Select Circuit Failure
    B2587 Passenger Seat Occupant Detection Circuit Short To Battery
    B2588 Child Seat Detection Circuit Short To Battery
    B2589 Unexpected Door Reversal During Close
    B2590 Vehicle Park/Speed Signal Circuit Failure
    B2591 Detent Signal Missing During Unlatch
    B2592 PSD Not Fully Closed (Module Commanded Successfully)
    B2593 Power Sliding Door Opened During Module Close Command
    B2594 No Movement Detected After an Unlatch During Power Open
    B2595 Anti Theft Input Signal Circuit Failure
    B2596 Headlamp Aim Output Relay Circuit Short To Battery
    B2597 Headlamp Aim Output Relay Circuit Failure
    B2598 Headlamp Relay Circuit Failure
    B2599 Tailgate Release Open Circuit
    B2600 Double Locking Door Motor Frozen
    B2601 No Latch Signal Sensed on Closing and Door Reversed
    B2602 Missing Latch Signal During Power Sliding Door Unlatch
    B2603 PSD Not Fully Closed During Self-Test
    B2604 Power Sliding Door On/Off Switch Open Circuit
    B2605 Disable Signal Open Circuit
    B2606 A/C Temperature Sensor Out of Range
    U1000 SCP (J1850) Invalid or Missing Data for Primary Id
    U1001 SCP (J1850) Invalid or Missing Data for Primary Id
    U1002 SCP (J1850) Invalid or Missing Data for Primary Id
    U1003 SCP (J1850) Invalid or Missing Data for Primary Id
    U1004 SCP (J1850) Invalid or Missing Data for EEC Programming
    U1005 SCP (J1850) Invalid or Missing Data for EEC Programming
    U1006 SCP (J1850) Invalid or Missing Data for Primary Id
    U1007 SCP (J1850) Invalid or Missing Data for Primary Id
    U1008 SCP (J1850) Invalid or Missing Data for Engine Torque
    U1009 SCP (J1850) Invalid or Missing Data for Engine Torque
    U1010 SCP (J1850) Invalid or Missing Data for Engine Air Intake
    U1011 SCP (J1850) Invalid or Missing Data for Engine Air Intake
    U1012 SCP (J1850) Invalid or Missing Data for Primary Id
    U1013 SCP (J1850) Invalid or Missing Data for Primary Id
    U1014 SCP (J1850) Invalid or Missing Data for Primary Id
    U1015 SCP (J1850) Invalid or Missing Data for Primary Id
    U1016 SCP (J1850) Invalid or Missing Data for Primary Id
    U1017 SCP (J1850) Invalid or Missing Data for Primary Id
    U1018 SCP (J1850) Invalid or Missing Data for Throttle
    U1019 SCP (J1850) Invalid or Missing Data for Throttle
    U1020 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch
    U1021 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch
    U1022 SCP (J1850) Invalid or Missing Data for Primary Id
    U1023 SCP (J1850) Invalid or Missing Data for Primary Id
    U1024 SCP (J1850) Invalid or Missing Data for Primary Id
    U1025 SCP (J1850) Invalid or Missing Data for Primary Id
    U1026 SCP (J1850) Invalid or Missing Data for Engine RPM
    U1027 SCP (J1850) Invalid or Missing Data for Engine RPM
    U1028 SCP (J1850) Invalid or Missing Data for Primary Id
    U1029 SCP (J1850) Invalid or Missing Data for Primary Id
    U1030 SCP (J1850) Invalid or Missing Data for Experimental #1
    U1031 SCP (J1850) Invalid or Missing Data for Experimental #1
    U1032 SCP (J1850) Invalid or Missing Data for Primary Id
    U1033 SCP (J1850) Invalid or Missing Data for Primary Id
    U1034 SCP (J1850) Invalid or Missing Data for Primary Id
    U1035 SCP (J1850) Invalid or Missing Data for Primary Id
    U1036 SCP (J1850) Invalid or Missing Data for Wheels
    U1037 SCP (J1850) Invalid or Missing Data for Wheels
    U1038 SCP (J1850) Invalid or Missing Data for Primary Id
    U1039 SCP (J1850) Invalid or Missing Data for Primary Id / Vehicle Speed
    U1040 SCP (J1850) Invalid or Missing Data for Vehicle Speed
    U1041 SCP (J1850) Invalid or Missing Data for Vehicle Speed
    U1042 SCP (J1850) Invalid or Missing Data for Traction Control
    U1043 SCP (J1850) Invalid or Missing Data for Traction Control
    U1044 SCP (J1850) Invalid or Missing Data for Traction Motor
    U1045 SCP (J1850) Invalid or Missing Data for Traction Motor
    U1046 SCP (J1850) Invalid or Missing Data for Primary Id
    U1047 SCP (J1850) Invalid or Missing Data for Primary Id
    U1048 SCP (J1850) Invalid or Missing Data for Primary Id
    U1049 SCP (J1850) Invalid or Missing Data for Primary Id
    U1050 SCP (J1850) Invalid or Missing Data for Brakes
    U1051 SCP (J1850) Invalid or Missing Data for Brakes
    U1052 SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel
    U1053 SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel
    U1054 SCP (J1850) Invalid or Missing Data for Primary Id
    U1055 SCP (J1850) Invalid or Missing Data for Primary Id
    U1056 SCP (J1850) Invalid or Missing Data for Vehicle Configuration
    U1057 SCP (J1850) Invalid or Missing Data for Vehicle Configuration
    U1058 SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL
    U1059 SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL
    U1060 SCP (J1850) Invalid or Missing Data for Primary Id
    U1061 SCP (J1850) Invalid or Missing Data for Primary Id
    U1062 SCP (J1850) Invalid or Missing Data for Primary Id
    U1063 SCP (J1850) Invalid or Missing Data for Primary Id
    U1064 SCP (J1850) Invalid or Missing Data for Primary Id
    U1065 SCP (J1850) Invalid or Missing Data for Primary Id
    U1066 SCP (J1850) Invalid or Missing Data for Primary Id
    U1067 SCP (J1850) Invalid or Missing Data for Primary Id
    U1068 SCP (J1850) Invalid or Missing Data for Primary Id
    U1069 SCP (J1850) Invalid or Missing Data for Primary Id
    U1070 SCP (J1850) Invalid or Missing Data for Engine Sensors
    U1071 SCP (J1850) Invalid or Missing Data for Engine Sensors
    U1072 SCP (J1850) Invalid or Missing Data for Engine Coolant
    U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant
    U1074 SCP (J1850) Invalid or Missing Data for Engine Oil
    U1075 SCP (J1850) Invalid or Missing Data for Engine Oil Temp
    U1076 SCP (J1850) Invalid or Missing Data for Primary Id
    U1077 SCP (J1850) Invalid or Missing Data for Primary Id
    U1078 SCP (J1850) Invalid or Missing Data for Primary Id
    U1079 SCP (J1850) Invalid or Missing Data for Primary Id
    U1080 SCP (J1850) Invalid or Missing Data for Primary Id
    U1081 SCP (J1850) Invalid or Missing Data for Primary Id
    U1082 SCP (J1850) Invalid or Missing Data for Engine Systems Other
    U1083 SCP (J1850) Invalid or Missing Data for Engine Systems Other
    U1084 SCP (J1850) Invalid or Missing Data for Powertrain Status Request
    U1085 SCP (J1850) Invalid or Missing Data for Powertrain Status Request
    U1086 SCP (J1850) Invalid or Missing Data for Primary Id
    U1087 SCP (J1850) Invalid or Missing Data for Primary Id
    U1088 SCP (J1850) Invalid or Missing Data for Suspension
    U1089 SCP (J1850) Invalid or Missing Data for Suspension
    U1090 SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics
    U1091 SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics
    U1092 SCP (J1850) Invalid or Missing Data for Primary Id
    U1093 SCP (J1850) Invalid or Missing Data for Primary Id
    U1094 SCP (J1850) Invalid or Missing Data for Experimental #2
    U1095 SCP (J1850) Invalid or Missing Data for Experimental #2
    U1096 SCP (J1850) Invalid or Missing Data for Primary Id
    U1097 SCP (J1850) Invalid or Missing Data for Primary Id
    U1098 SCP (J1850) Invalid or Missing Data for Vehicle Speed Control
    U1099 SCP (J1850) Invalid or Missing Data for Vehicle Speed Control
    U1100 SCP (J1850) Invalid or Missing Data for Primary Id
    U1101 SCP (J1850) Invalid or Missing Data for Primary Id
    U1102 SCP (J1850) Invalid or Missing Data for Primary Id
    U1103 SCP (J1850) Invalid or Missing Data for Primary Id
    U1104 SCP (J1850) Invalid or Missing Data for Chassis Status Request
    U1105 SCP (J1850) Invalid or Missing Data for Chassis Status Request
    U1106 SCP (J1850) Invalid or Missing Data for Legislated Diagnostics
    U1107 SCP (J1850) Invalid or Missing Data for Legislated Diagnostics
    U1108 SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)
    U1109 SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)
    U1110 SCP (J1850) Invalid or Missing Data for Primary Id
    U1111 SCP (J1850) Invalid or Missing Data for Primary Id
    U1112 SCP (J1850) Invalid or Missing Data for Primary Id
    U1113 SCP (J1850) Invalid or Missing Data for Primary Id
    U1114 SCP (J1850) Invalid or Missing Data for Charging System
    U1115 SCP (J1850) Invalid or Missing Data for Charging System
    U1116 SCP (J1850) Invalid or Missing Data for Electrical Energy Management
    U1117 SCP (J1850) Invalid or Missing Data for Electrical Energy Management
    U1118 SCP (J1850) Invalid or Missing Data for Primary Id
    U1119 SCP (J1850) Invalid or Missing Data for Primary Id
    U1120 SCP (J1850) Invalid or Missing Data for Primary Id
    U1121 SCP (J1850) Invalid or Missing Data for Primary Id
    U1122 SCP (J1850) Invalid or Missing Data for Odometer
    U1123 SCP (J1850) Invalid or Missing Data for Odometer
    U1124 SCP (J1850) Invalid or Missing Data for Primary Id
    U1125 SCP (J1850) Invalid or Missing Data for Primary Id
    U1126 SCP (J1850) Invalid or Missing Data for Primary Id
    U1127 SCP (J1850) Invalid or Missing Data for Primary Id
    U1128 SCP (J1850) Invalid or Missing Data for Primary Id
    U1129 SCP (J1850) Invalid or Missing Data for Primary Id
    U1130 SCP (J1850) Invalid or Missing Data for Fuel System
    U1131 SCP (J1850) Invalid or Missing Data for Fuel System
    U1132 SCP (J1850) Invalid or Missing Data for Vehicle Motion
    U1133 SCP (J1850) Invalid or Missing Data for Vehicle Motion
    U1134 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
    U1135 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
    U1136 SCP (J1850) Invalid or Missing Data for Telltales
    U1137 SCP (J1850) Invalid or Missing Data for Telltales
    U1138 SCP (J1850) Invalid or Missing Data for Primary Id
    U1139 SCP (J1850) Invalid or Missing Data for Primary Id
    U1140 SCP (J1850) Invalid or Missing Data for Gateway
    U1141 SCP (J1850) Invalid or Missing Data for Gateway
    U1142 SCP (J1850) Invalid or Missing Data for Primary Id
    U1143 SCP (J1850) Invalid or Missing Data for Primary Id
    U1144 SCP (J1850) Invalid or Missing Data for Primary Id
    U1145 SCP (J1850) Invalid or Missing Data for Primary Id
    U1146 SCP (J1850) Invalid or Missing Data for Vehicle Security
    U1147 SCP (J1850) Invalid or Missing Data for Vehicle Security
    U1148 SCP (J1850) Invalid or Missing Data for Audio Control
    U1149 SCP (J1850) Invalid or Missing Data for Audio Control
    U1150 SCP (J1850) Invalid or Missing Data for Audible Warnings
    U1151 SCP (J1850) Invalid or Missing Data for Audible Warnings
    U1152 SCP (J1850) Invalid or Missing Data for Experimental #3
    U1153 SCP (J1850) Invalid or Missing Data for Experimental #3
    U1154 SCP (J1850) Invalid or Missing Data for Compact Disc
    U1155 SCP (J1850) Invalid or Missing Data for Compact Disc
    U1156 SCP (J1850) Invalid or Missing Data for Digital Signal Processing
    U1157 SCP (J1850) Invalid or Missing Data for Digital Signal Processing
    U1158 SCP (J1850) Invalid or Missing Data for Antenna
    U1159 SCP (J1850) Invalid or Missing Data for Antenna
    U1160 SCP (J1850) Invalid or Missing Data for Primary Id
    U1161 SCP (J1850) Invalid or Missing Data for Primary Id
    U1162 SCP (J1850) Invalid or Missing Data for Digital Audio Tape
    U1163 SCP (J1850) Invalid or Missing Data for Digital Audio Tape
    U1164 SCP (J1850) Invalid or Missing Data for Tuner / Receiver
    U1165 SCP (J1850) Invalid or Missing Data for Tuner / Receiver
    U1166 SCP (J1850) Invalid or Missing Data for Cassette Tape
    U1167 SCP (J1850) Invalid or Missing Data for Cassette Tape
    U1168 SCP (J1850) Invalid or Missing Data for Primary Id
    U1169 SCP (J1850) Invalid or Missing Data for Primary Id
    U1170 SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System
    U1171 SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System
    U1172 SCP (J1850) Invalid or Missing Data for Remote Button Control
    U1173 SCP (J1850) Invalid or Missing Data for Remote Button Control
    U1174 SCP (J1850) Invalid or Missing Data for Primary Id
    U1175 SCP (J1850) Invalid or Missing Data for Primary Id
    U1176 SCP (J1850) Invalid or Missing Data for Primary Id
    U1177 SCP (J1850) Invalid or Missing Data for Primary Id
    U1178 SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)
    U1179 SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)
    U1180 SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features
    U1181 SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features
    U1182 SCP (J1850) Invalid or Missing Data for Primary Id
    U1183 SCP (J1850) Invalid or Missing Data for Primary Id
    U1184 SCP (J1850) Invalid or Missing Data for Window Wiper / Washer
    U1185 SCP (J1850) Invalid or Missing Data for Window Wiper / Washer
    U1186 SCP (J1850) Invalid or Missing Data for Primary Id
    U1187 SCP (J1850) Invalid or Missing Data for Primary Id
    U1188 SCP (J1850) Invalid or Missing Data for Primary Id
    U1189 SCP (J1850) Invalid or Missing Data for Primary Id
    U1190 SCP (J1850) Invalid or Missing Data for Primary Id
    U1191 SCP (J1850) Invalid or Missing Data for Primary Id
    U1192 SCP (J1850) Invalid or Missing Data for Primary Id
    U1193 SCP (J1850) Invalid or Missing Data for Primary Id
    U1194 SCP (J1850) Invalid or Missing Data for Mirrors
    U1195 SCP (J1850) Invalid or Missing Data for Mirrors
    U1196 SCP (J1850) Invalid or Missing Data for Door Locks
    U1197 SCP (J1850) Invalid or Missing Data for Door Locks
    U1198 SCP (J1850) Invalid or Missing Data for External Access (Doors)
    U1199 SCP (J1850) Invalid or Missing Data for External Access (Doors)
    U1200 SCP (J1850) Invalid or Missing Data for Seat Motion / Control
    U1201 SCP (J1850) Invalid or Missing Data for Seat Motion / Control
    U1202 SCP (J1850) Invalid or Missing Data for Windows
    U1203 SCP (J1850) Invalid or Missing Data for Windows
    U1204 SCP (J1850) Invalid or Missing Data for Steering Column
    U1205 SCP (J1850) Invalid or Missing Data for Steering Column
    U1206 SCP (J1850) Invalid or Missing Data for Primary Id
    U1207 SCP (J1850) Invalid or Missing Data for Primary Id
    U1208 SCP (J1850) Invalid or Missing Data for Seat Switches
    U1209 SCP (J1850) Invalid or Missing Data for Seat Switches
    U1210 SCP (J1850) Invalid or Missing Data for Restraints
    U1211 SCP (J1850) Invalid or Missing Data for Restraints
    U1212 SCP (J1850) Invalid or Missing Data for Primary Id
    U1213 SCP (J1850) Invalid or Missing Data for Primary Id
    U1214 SCP (J1850) Invalid or Missing Data for Primary Id
    U1215 SCP (J1850) Invalid or Missing Data for Primary Id
    U1216 SCP (J1850) Invalid or Missing Data for External Lamp Outage
    U1217 SCP (J1850) Invalid or Missing Data for External Lamp Outage
    U1218 SCP (J1850) Invalid or Missing Data for External Lamps
    U1219 SCP (J1850) Invalid or Missing Data for External Lamps
    U1220 SCP (J1850) Invalid or Missing Data for Interior Lamp Outage
    U1221 SCP (J1850) Invalid or Missing Data for Interior Lamp Outage
    U1222 SCP (J1850) Invalid or Missing Data for Interior Lamps
    U1223 SCP (J1850) Invalid or Missing Data for Interior Lamps
    U1224 SCP (J1850) Invalid or Missing Data for Primary Id
    U1225 SCP (J1850) Invalid or Missing Data for Primary Id
    U1226 SCP (J1850) Invalid or Missing Data for Body Status Request
    U1227 SCP (J1850) Invalid or Missing Data for Body Status Request
    U1228 SCP (J1850) Invalid or Missing Data for Tires
    U1229 SCP (J1850) Invalid or Missing Data for Tires
    U1230 SCP (J1850) Invalid or Missing Data for Electric Defrost
    U1231 SCP (J1850) Invalid or Missing Data for Electric Defrost
    U1232 SCP (J1850) Invalid or Missing Data for Navigation
    U1233 SCP (J1850) Invalid or Missing Data for Navigation
    U1234 SCP (J1850) Invalid or Missing Data for Displays
    U1235 SCP (J1850) Invalid or Missing Data for Displays
    U1236 SCP (J1850) Invalid or Missing Data for Memory Storage
    U1237 SCP (J1850) Invalid or Missing Data for Memory Storage
    U1238 SCP (J1850) Invalid or Missing Data for Experimental #4
    U1239 SCP (J1850) Invalid or Missing Data for Experimental #4
    U1240 SCP (J1850) Invalid or Missing Data for Primary Id
    U1241 SCP (J1850) Invalid or Missing Data for Primary Id
    U1242 SCP (J1850) Invalid or Missing Data for Exterior Environment
    U1243 SCP (J1850) Invalid or Missing Data for Exterior Environment
    U1244 SCP (J1850) Invalid or Missing Data for Interior Environment
    U1245 SCP (J1850) Invalid or Missing Data for Interior Environment
    U1246 SCP (J1850) Invalid or Missing Data for Primary Id
    U1247 SCP (J1850) Invalid or Missing Data for Primary Id
    U1248 SCP (J1850) Invalid or Missing Data for Time / Date
    U1249 SCP (J1850) Invalid or Missing Data for Time / Date
    U1250 SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)
    U1251 SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)
    U1252 SCP (J1850) Invalid or Missing Data for Class A Functions
    U1253 SCP (J1850) Invalid or Missing Data for Class A Functions
    U1254 SCP (J1850) Invalid or Missing Data for Network Control
    U1255 SCP (J1850) Invalid or Missing Data for Network Control
    U1260 SCP (J1850) Single Ended (+) Circuit Failure
    U1261 SCP (J1850) Single Ended (-) Circuit Failure
    U1262 SCP (J1850) Communication Bus Fault
    U1308 SCP (J1850) Invalid or Missing Data for Function Read Engine Torque
    U1341 SCP (J1850) Invalid or Missing Data for Function Read Vehicle Speed
    U1430 SCP (J1850) Invalid or Missing Data for Function Read Fuel System
    U1451 SCP (J1850) Invalid or Missing Data for Function Read Audible Warnings / Anti-Theft Module, Vehicle Immobilized
    U1612 SCP (J1850) Lack of Acknowledgment for Primary Id
    U1736 SCP (J1850) Lack of Acknowledgment for Telltales
    U1750 SCP (J1850) Lack of Acknowledgment for Audible Warnings
    U1794 SCP (J1850) Lack of Acknowledgment for Mirrors
    U1797 SCP (J1850) Lack of Acknowledgment for Door Locks
    U1798 SCP (J1850) Lack of Acknowledgment for External Access (Doors)
    U1806 SCP (J1850) Lack of Acknowledgment for Primary Id
    U1900 CAN Communication Bus Fault
    U1950 UPB Communication Bus Fault
    U2000 Audio Rear Control Unit is Not Responding
    U2001 Audio Tape Deck Unit is Not Responding
    U2002 Audio Bezel is Not Responding
    U2003 Audio Compact Disk / Disk Jockey Unit is Not Responding
    U2004 Audio Steering Wheel Control Unit is Not Responding
    U2005 Audio Rear Integrated Control Panel Unit is Not Responding
    U2006 Audio Remote Climate Control Unit is Not Responding
    U2007 Audio Navigation Unit is Not Responding
    U2008 Audio Phone is Not Responding
    U2009 Audio Front Control Module (ACM) is Not Responding
    U2010 Module is Not Responding (Non SCP)
    U2011 Module Transmitted Invalid Data (Non SCP)
    U2012 Communication Bus Error (Non SCP)
    U2013 Compass Module is not Responding
    U2014 Audio Subwoofer Unit is Not Responding
    U2015 Signal Link Fault (Non SCP)
    U2016 Signal Link Short to Ground (Non SCP) / From NGV Module
    U2017 Driver Side Crash Sensor Communication Fault (Non SCP)
    U2018 Passenger Side Crash Sensor Communication Fault (Non SCP)
    U2019 Audio Voice Module Not Responding
    U2020 Audio Center Amp is not responding
    U2021 Invalid /fault data received (Non SCP)
    U2150 SCP (J1850) Invalid Data from REM
    U2152 SCP (J1850) Invalid Data from GEM
    U2160 SCP (J1850) Invalid Data from IC
    U2195 SCP (J1850) Invalid Data from SCLM
    U2500 (CAN) Lack of Acknowledgement From Engine Management
    Would you be able to shed some light on what this fault code actually means please? My car is a vaxuhall vectra 1.9cdti auto estate 2006 and is suffering from loss of power/limp mode. Ive change the map sensor and egr but to no avail.
    Any help would be greatly appreciated!
  4. #34
    Oct 2013
    Derby
    295 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by scrumpy71 View Post
    What did google bring up?
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  5. #35
    Full Member petrolcan's Avatar
    Dec 2015
    Watford
    20 Post(s)
    Trim : Elegance
    Engine : 1.9 CDTI (120)
    You had to quote that entire post just to ask that?
    2006 Signum 1.9 CDTi (120)
    EGR mapped out & DPF removed. Mildly breathed upon.
  6. #36
    Apr 2016
    Ipswich
    45 Post(s)
    Vehicle : Vectra C
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    @scrumpy71 you need to readout the ecu so some form of diagnostics is needed, just swapping parts is not the right way of going about this, limp mode an be caused by a simple sticky VNT mechanism on the turbo, a leak in the vacuum system, faulty electronic solenoids, dirty or malfunctioning map or maf sensor, a stuck or blocked egr, dirty or blocked injectors, dirty fuel filter, dirty or malfunctioning injectors, broken or malfunctioning intank lift pump and the list goes on...
    so get the ecu scanned for the fault code, than take action from there.
  7. #37
    May 2020
    worthing
    Vehicle : vauxhall vectra
    Trim : cdti
    Engine : 1.9cdti
    Year : 06
    Ok, so I took my car to vauxhall who done a diagnostic and they said it was a swirl malfunction code - broken swirl flaps. Requires new flaps/inlet manifold & egr valve.
    Cost of just over 1500!
    So I may get a 2nd hand inlet manifold or even a new one and was thinking about doing myself. How difficult a job is it and do you need to remove the cambelt?
    Any advice greatly appreciated.
  8. #38
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    There are guys who will supply and fit a blanked manifold for 150-200. You can clean your egr and boost sensor yourself for not much effort. First off check to see if the swirl bar had disconnected from the flaps.
  9. #39
    May 2020
    worthing
    Trim : cdti
    Engine : 1.9cdti
    Year : 06
    Quote Originally Posted by rushy View Post
    That sounds good! Any recommendations? I have done the egr and boost sensor already and like you said not much effort at all.
  10. #40
    Vehicle : 9-3 Wagon
    Mileage : 137000
    Sorry bud, I may have been on here since 2005 but I haven't been on the site for a long time now so out of the loop. A separate titled thread may point you in the right direction. If you get no joy on the forum try the Facebook pages there's quite a few that do it on there.
    I just read your swirl bar post on another thread. Interestingly enough when I looked for your code in regards to Opel (so GM not ford etc) it came up with an autobox fault. I think you mentioned it happens when you slow down?
    If you you look down at your swirl bar, and you can move 1,2&4 freely and 3 moves position when you start the car then you can re attach the bar with new brass bushes. The old bar will always pop off as the bushes have worn out. There found on eBay and you fit them to your existing bar. Mine fell off, caused really poor and smokey starting and blocked my dpf as soon as I reattached the bar and passively cleared the dpf it's been fine for 2 years.
    I'm in a similar position as you with the manifold. Getting a blanked manifold fitted seams to be the cheapest option but personal I would prefere a working manifold with flaps still fitted. New manifolds with uprated swirls are about 150.
    But for the time being my flaps are holding and working with new bushes, my egr is blanked, she's running well even doing short journeys and running a dtuk box.
Page 4 of 4 FirstFirst ... 234
  1. Fault code
    By welshboy in forum Engine & Drivetrain
    Last Post: 27th September 2011, 17:44
  2. Fault code help please
    By mdibb2009 in forum Engine & Drivetrain
    Last Post: 3rd July 2011, 21:37
  3. fault code help
    By delboy2028 in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 21:16
  4. Fault Code App
    By Keefyb007 in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2010, 21:35
  5. fault code
    By kenny1zero in forum Engine & Drivetrain
    Last Post: 16th August 2008, 20:20
vauxhall vectra c error code 00105
switch circuit bank 1 a vectra
code p1509 opel vectra c
generic heat sensor 2 vectra 2004 2.2 direct
vectra viga p1131
https:www.vectra-c.comforumshowthread.php19442-Fault-code-site
vectra c b3878-04 code
vectra intake heater control solenoid valve
code 0465 on vectra c
p1567 vectra c
p1512 astra 2.2
01 vectra 2.2 error codes
insignia cmp actuator
vectra c fault codes
poo82 code in micra diesel what is fault
p0014 vectra c forum
Vectra p0190 code fuel pressure high voltage
Vectra C Error
vectra c p1191 error code
vectra heater intake solenoid fault
vectra c p1193
vauxhall vectra C 1600 fault
Vectra c p1430
błąd 1116 opel vectra
vectra c error AAI circuit mailfunction
