Thread: Rear Window handle removal.
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Default Rear Window handle removal.
    I'd forgotten to raise this....
    When I was at 888 Nigel said to me "Ya back windows open"..To which I said "no it aint" then I opened the door and found the window was open half a turn.
    Apparently its common and caused by a combination of the weight of the door handle and vibration. The solution is to remove the handle and refit it 180 degrees round from the original (if that makes sense).
    Had a look expecting to find a screw on the handle but there is none. Any one know how the get the handle off?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Hope this helps mate, not done it myself.
    Regular Member simac's Avatar
    Wirral
    I'll watch this with interest m8 as one of my back windows often goes down a fraction, just enough to increase horrible wind noise !
    Feb 2006
    Wirral
    Cheers Rushy!...and Ultimately Mark of course
    Quote Originally Posted by simac View Post
    And let some moisture into the window seal!
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    don't need any special tools just use a duster/rag pulled out stright and pull it up behind the clip moving it side to side and it forces it off works a treat
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by [LEFT
    Brocks[/LEFT];240077]and Ultimately Mark of course
    Of course, who else. The man with all the answers.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by Beavis View Post
    Know just what you mean there, same as my old pug.
    Regular Member david173's Avatar
    Dec 2005
    Dumbarton, Scotland
    I used to get wind noise from my rear window and found it was open a bit, turns out my drivers seatbelt was gettin caught on the handle, and when i went to grab it to put it on, it was pulling the window winder forward slightly!
  1. rear door window removal
    By Al 22 dti in forum Bodywork & Interior
    Last Post: 30th April 2011, 20:54
  2. removal of handle covers
    By hairy31 in forum Styling
    Last Post: 6th October 2010, 20:28
  3. Removal/re-fit rear window vectra c?
    By Dean in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2010, 15:50
  4. B pillar & rear window trim removal
    By sithompson in forum Bodywork & Interior
    Last Post: 12th June 2009, 21:45
  5. Rear lil window removal?
    By 2ltrT in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2006, 18:05
remove window handle from vectra c
remove window winder vectra c
Id like to delete rear window handles
how to remove window handle vectra c
