Results 1 to 10 of 13
Thread: Fault code P0638
    Feb 2007
    Glasgow
    confused Fault code P0638
    Hi everyone,
    I'm new to the forums and really hope someone can help. i have a 3 1/2 year old signum elegance 2.2 tdi and the car/spanner yellow light keeps coming on with a resulting loss of power. the car is out of warranty now (typical !) and our local friendly mechanic has run a fault test on it at no charge (what a nice man). The fault code that comes up is P0638 which he says will be something to do with the throttle etc. but as it is only an intermittant fault it will be difficult , and probably expensive, to trace exactly what the problem is. It is getting much more frequent tho and is getting to the point that it's a gamble if you'll make it to/from your destinatio.
    has anyone else had similar problems? or know more specifically what might be causing this.
    Very gratefull for any advice.
    thanks
    Eileen
    P0638 relates to the throttle actuator..Cars like these don't have a cable from the pedal to the engine anymore, there's an electonic device which does the job for us..the fault is saying it's control value is out of line..
    This will need careful examination by a vehicle elctronics expert to see if it's getting the correct signals..BUT as a start the mechanic could remove the throttle butterfly assembly to see if it's all caked up inside and if that is restricting it's movements...
    Feb 2007
    Wales
    I have the same intermittent problem with my vectra estate - three trips to the main dealer and still no solution!
    Feb 2007
    Glasgow
    Thanks Mark,
    Car is going in to the mechanic tomorrow and will mention the throttle actuator to him. I've told him about the advice received about the butterfly assembly and he's asked me to print it out and he will check it. I'll keep you posted about what happens
    Feb 2007
    Glasgow
    Quote Originally Posted by Welsh Paul View Post
    What did they say the problem was and how did they try to fix it? I'll let you know if I have any luck.
    Eileen
    Feb 2007
    Wales
    They are unable to find any fault with the vehicle...?
    EAST KILBRIDE
    Default similar problem
    hi Eileen,
    I have a similar problem too. I had the car serviced at Arnold Clark last week, the "spanner" light was coming on now and again, they cleaned out the throttle housing and advised me that I need a new throttle control valve. I have never heard of this part, and previously the problem I was having was the EGR valve which seems a very common fault with these cars. Mine is a 4 year old 2.2dti Elegance Signum.
    If I find out more I will let you know, and vice-versa!!
    Quote Originally Posted by eileeng2 View Post
    Hi everyone,
    thanks
    Eileen
    Feb 2007
    Wales
    Smile Fault repair
    Mine turned out to be a boost pipe that had split, the stealers replaced the part for about 80 - which did not seem to bad to me?
    To be fair the dealer was very good this time, kept me informed etc etc - the first time I have had a positive experience with a VX dealer.
    They said it is a very very common problem!!!
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    What sometimes happens on fly by wire systems is that the potentiometer (thottle sensor) track wears, probably more likely where the vehicle has been driven at constant speeds for long periods of time. This can cause erratic signals as the feed from the potentiometer drops out as the accelerator passes the broken bit of track. This often causes little or no problem during driving but can cause a fault code to be stored because the ECU has picked up an incorrect signal when it didn't expect it. The only real way to test this is with an oscilloscope as it will probably drop out and come back in too quickly to be picked up on a multimeter.
    VIP-Member superstuper's Avatar
    Trieste, Italy
    Vehicle : Opel Vectra C
    Trim : Estate F35, Elegance
    Engine : Y22DTR
    Faulty throttle body. I need to replace them on my 2004 2.2 DTI.
  1. Fault code P0638 2.2 DTi o4 plate
    By Ian666 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th February 2012, 18:16
  2. Fault Code P0638
    By Micknal in forum Engine & Drivetrain
    Last Post: 10th November 2011, 15:22
  3. Fault code P0638
    Last Post: 9th November 2011, 17:43
  4. Fault code P0638
    Last Post: 9th November 2011, 17:41
p0638 opel vectra c
p0638 opel vectra c 19th
p0638
po638 vecta fix
p0638 opel signumb2.2
p0638 opel
p0638 vectra c 2.2
p0638 opel vectra c number
p0638-04 opel
dti p0638
vectra c error p0638-04
P0638 - 04 y22dtr
Opel P0638
p0638 vauxhall y22dtr
p0638 опел not start
vectra c p638
Opel P0638(07)
vauxhall vectra 2000dti code p0638
