Thread: Perplexed - totally.
    Regular Member Led's Avatar
    Kings Langley
    confused Perplexed - totally.
    I returned from my holiday (car left in car park for a week - flat ground) key in and car starts 1st turn, drive from Stansted to Kings Langley - no problems.
    I park my car facing the house (easier to remove suitcases) slightly up hill maybe a 10% gradient. I left the car like this for 2 days, didn't need to use it. I then went to start the car and it just would start I rolled it on to the road (flat surface) and cranked it over for a while and it eventually started, left it running for a while (5 mins) and parked it normally facing to the road (downhill)
    This is the 2nd time this has happened in the 18 months I've owned it and it only happens after being left for a few days parked facing up hill.
    Has anyone else experienced this ?
    The car has done 18k and has been recently (last September) serviced, no noticable fule/oil leaks.
    My old Vec B never suffered this problem.
    Regular Member sri22dti's Avatar
    Northern Ireland
    sounds like injector seals or leak of pipes which run between the injectors, common problem with this engine!
    The main 'common' problem with the non starting DTi is the injector leak off pipes....but this seems more like a drain back problem..fuel running away from the pump...I'd drop it back into your workshops at BT....
    still want that oil, now you're back from your travels??
    Kings Langley
    Hi Mark,
    Oil - Yes please.
    The problem car is mine, not the wifes
    The car is still under warranty - would it be covered ?
    Regular Member simac's Avatar
    Wirral
    A very similar problem was repaired under warranty (network q) when I had a B 2.0DTI
    Best of luck !
    Shove it back down to VX then, if you've got warranty and ask them to look athe the leak-offs.. but they may have a problem replicating the fault..
    Regular Member SteveBray's Avatar
    Barnsley, South Yorkshire
    Thumbs down
    I had a DTi 2.2 a few years ago and if left facing up hill it would not start, was fixed under warranty, it was the seals, it happened twice during warranty. Six months after warranty ran out fuel pump failed and cost almost £1500 to have replaced and the car sold to a relation has had other problems as well. Don't want to frighten you but it could the begining of bigger problems in the future, good luck.
  1. Totally gutted
    By conman in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2013, 18:52
  2. Totally stolen
    By Vectralicker in forum General Chat
    Last Post: 26th March 2011, 03:41
  3. Now for something totally different...
    By P3tchy in forum Styling
    Last Post: 26th March 2010, 14:28
  4. totally new
    By stew299 in forum Introduce yourself.
    Last Post: 19th July 2009, 22:11
  5. Totally fed up with my car
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2007, 18:07
