Results 1 to 10 of 13
Thread: Rough running with KaN air filter
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Default Rough running with KaN air filter
    Vectra c newby !
    A big hello to everyone, I'm new to this site and new to owning a Vectra, my last car was a Mondeo ( CAN I SAY THAT ! ) which had its good points and with out a doubt had its bad ones. My Vectra however has certainly proven most of the criticts to be biast against one manufacturer to another ! i am pleased with the 1.9 cdti 150 its smother and quieter than my previous diesel and the handling feels very good. i have just fitted a K&N pannel air filter but after a day i've taken it back out and re fitted the old one ! the engine ran very roughly and the power delivery felt jerky and inconsistent ( should i have given it a bit longer for the ecu to adjust ? ) my other concern, if it is one, is when trying to get through the gears with a bit of welly it feels like there is a bit of back lash in the drive train ! this could be normal or me not being that good at the cog swopping ! ! any comments or help would be really appreciated.
    Cheers Kcs
    Regular Member Harry's Avatar
    Uxbridge, London
    do a search on this site and you might find that people have 'reset' the ECU after swapping the filter with some fairly impressive results.
    by disconnecting the battery you might find the car performs better with the K&N.
    give and it a go, it won;t cost you anything and definitely worth a try, especially as you've it now
    Feb 2007
    Tamworth
    Thanks Harry will try that, i have just read some info on ( how to fit a K&N ) which i think i did ok but one thing i didn't do was remove the plastic cover in the bottom of filter box ! could this also be better for air intake ?
    cheers Kcs
    Uxbridge, London
    it's not absolutely necessary when fitting a K&N air filter, but people have noticed some benefits when do so.
    you gotta be a bit forceful with it when pulling it out, but don't worry it won't break.
    try disconnecting the battery after fitting it again and see whether it makes a difference or not
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    ive got k@n filter and modded airbox and the car runs perfect ive never disconnecteed the battery though
    Feb 2007
    Tamworth
    Thanks , will i need to put radio code back in or anything else if i unplug battery ?
    Uxbridge, London
    good question....and to be honest i don't know! best just to have it to hand though.
    Feb 2007
    Tamworth
    Thanks again, will have a fiddle tomorrow, will keep you up to speed,
    cheers Kcs
    Feb 2007
    Tamworth
    Hi again to all above who gave me some tips on my air filter, well i've plopped the K&N back in an also removed the plastic cover in the bottom of the box, i havn't as yet removed the battery leads but decided to give it a blast to check how it ran first, well all i can say is "THAT'S MORE LIKE IT !" the revs are clean and instant and its pulling wright through the range. not sure if i have the correct radio code so i will have to wait untill weekend to unplug the battery leads ! Anyway i had better go before the Mrs falls out with me again ! catch ya soon Kcs.
    Uxbridge, London
    glad to hear it's sorted!
  1. Help needed please - 1.9cdti running rough
    By danny_n in forum Engine & Drivetrain
    Last Post: 22nd July 2012, 19:31
  2. 2.2 vectra running a bit rough
    By tweenage in forum Engine & Drivetrain
    Last Post: 20th January 2012, 16:20
  3. sri 150 running rough on start up help?
    By danni_kitch in forum Diesel Engine related
    Last Post: 26th September 2011, 13:30
  4. 2.2 Sri Direct - running rough
    By johnmac in forum Engine & Drivetrain
    Last Post: 24th December 2007, 19:12
  5. 3.2 V6 Gsi Rough Running From Cold
    By TOON VECTRA V6 in forum Engine & Drivetrain
    Last Post: 13th December 2006, 22:20
