Likes Likes:  1
Results 1 to 10 of 18
Thread: Issues With Precat Decat on 1.9CDTI
    Apr 2011
    Bath
    Default Issues With Precat Decat on 1.9CDTI
    Hello Guys
    Im new on the forum, but have had my vec 1.9CDTi 150 SRi a while now.
    I was thinking of drilling out and removing the internals of my precat.
    I have one worry though. Will I get issues such as an ecu warning light due to the lambda sensors???
    Also is decatting the precat better than decatting the main cat?
    help would be very much appreciated.
    Regular Member nath-lav's Avatar
    Mar 2011
    newcastle upon tyne
    Decatting main cat will give you best results. .and if you only take out internals of precat but reconect lambda sensor etc there wiol be no probs..
    Apr 2011
    Bath
    ok thanks nath-lav.
    so im fine to rip out the internals of the precat and then fix the sensor back in place and all will be ok?
    I would rip the internals out of both precat and main cat but i think i would get issues with not enough back preasure.
    also i think one of the two sensors detects if thye cat is actually working or not.
    am i correct in saying this?
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    244 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    I've mixed opinions on de-catting depending on the type of turbo.
    For hybrid turbo's, removing or gutting all catalysts is essential. On my signum, I initally just gutted the DPF when fitting the hybrid, but it was exceedingly laggy with no power below 2200rpm despite proper mapping. As soon as I gutted the pre-cat, the boost threshold reduced by nearly 300rpm to 1900rpm with much more rapid spoolup.
    With standard turbo and standard mapping, gutting the cats can reduce lag and improve efficiency slightly but the turbo will tend to spool up more quickly and the boost pressure may spike a little just above the boost threshold.
    With standard turbo and remap that gives extra fuelling or even a tuning box, things can go horribly wrong. The boost pressure will tend to spike severely - in some cases I've seen it go above the limit of the TMAP sensor. In most cases this can be controlled by careful recalibration of the VNT maps, but in some cases the boost pressure will tend to oscillate, requiring further modification to the parameters of the PCR governor (closed loop boost pressure control algorithm). Its basically a 'PID controller' using the pressure reading from the TMAP sensor as the measured variable, and the pulse ratio of the boost solenoid as the manipulated variable. Look up PID control on wikipedia
    The reason that these spikes or instability occur is because in the absence of back-pressure in the exhasut system, the avalanche effect is much more rapid - i.e. the turbo rotating assembly accellerates more rapidly and so the measured variable (actual boost pressure) tends to overshoot the target valve (desired boost pressure) before the rather sluggish vacuum based VNT control mechanism can open the vanes enough to compensate. The PCR governor then tends to overcompensate due to the long delay in response from the VNT control system and so the boost pressure drops below the target value and the cycle repeats, causing an oscillation in the boost pressure which gradually reduces in amplitude until a stable pressure is reached.
    The reason that this issue is less likely to occur with a hybrid turbo is because the larger compressor wheel has a higher mass than the standard one, and so the rotating assembly accellerates more slowly than the standard one and the PCR governor and VNT mechanism response time is adequately fast to maintain a stable boost pressure,
    woodbridge, suffolk
    244 Post(s)
    Trim : Design+
    Mileage : 101000
    Also I should add that having now seen both, the pre-cat is much more restrictive than the main cat. The main cat is a simple square-honeycomb construction and so does not disturb gas flow excessively,
    However the precat is of very different construction. Imagine coke-can tpye metal corrugated on both axis like corrugated cardboard, wrapped in a spiral from the centre to the edges of the canister. This I believe offers much greater resistance to gas flow than the simple honeycomb of the main cat.
    And regarding the lambda sensor - as long as you leave them installed in the canister after gutting, or use a de-cat pipe that has a fitting for the sensor, there should be no issue. However if you want to completely remove the lambda sensor for any reason, it can be disabled in the ECU mapping so you can disconnect it without any fault codes appearing.
    Apr 2011
    Bath
    thank you littleteapot.
    great information. I knew that the precat was the most restrictive.
    I was thinking of gutting the pre cat, leaving all lambda sensors in place and leaving the main cat in place. then removng the centre silencer but leaving the standard backbox and tailpipe.
    After i was also going to get a remap.
    How do you think the car will perfrom after and also will I get any side effects?
    woodbridge, suffolk
    244 Post(s)
    Trim : Design+
    Mileage : 101000
    It will perform well, but you need a competent remapper who will log boost pressure and other relevant variables, and make the necessary adjustments to ensure the boost pressure is stable and doesn't spike excessively, nor run-away at full throttle and high revs.
    If the boost pressure is allowed to spike, this will cause rapid wear of the thrust bearing. If boost pressure runs away (caused by the fuelling and hence exhaust gas flow being too high for even a fully-open vnt mechanism) this results in near instant destruction of the entire turbo.
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Just for information, I note none of this on the DTi. The only problem I had about bad VNT rod tuning was excess smoke, laggy spoolup followed by pressure spiking then strong pulling up all over the range, ultimately resulting in limp mode on sustained acceleration... The garage did a nice optimization job, as my fuel consumption has now fallen down by an additional 15%.
    But it never oscillated. Maybe it's because the turbo is larger, with maybe a heavier compressor wheel... The DTi also doesn't have a pre-cat, only a short, square-honeycomb, catalyser, and no DPF either, so the turbo is designed to work with minimal backpressure already. However, the catalyser still added a bit of obstruction, as after having guttied it out, the turbo spool delay has been dramatically reduced (after VNT rod fine tuning), now pulling from 1200 rpm and blowing full power from 1500 rpm.
    One the other hand, when the rod was shortened too much, I could achieve tremendous acceleration (but is was harder to have it reaching the necessary 1500 rpm) and high end power, so maybe something can be done in the aera between the current maximum boost given by the fully closed VNT and the value the ECU considers as being too much... The tolerance isn't excessively tight, maybe 0.1 bar or so, which leaves some margin in the 2 to 2.1 bar range, avoiding the error to trigger... Maybe a hybrid could address that.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    On a CDTI, Removing the pre cat yeilds better results since the pre cat is effectively butted up against the Turbo. Removing it allows the gases to get out quicker. The main cat is a bit far away and it too will relieve a pressure drop in the exhaust but I have to say you don't notice it at much especially if you leave the pre-cat in.
    Giving the DTI it's due, one cat and it sits a bit a away from the turbo so removing the cat from a DTI will give instant results. The CDTI's being of Euro 4 regulations means two cats with one on the 'doorstep' of the turbo.
    woodbridge, suffolk
    244 Post(s)
    Trim : Design+
    Mileage : 101000
    I've only seen the oscillation occur on Z19DTH engines. The PCR governor on some software versions has very short time constants and high gain (much faster than the vacuum mechanism that it operates) and so tends to becomes unstable during transient conditions. This will often be oberved as a surge of power, followed by a flat spot, then full power again, when full throttle is applied suddenly.
    Its a fine balance between responding quickly enough to prevent excessive overshoot, and slow enough to avoid becoming unstable (oscillating). My observation is that the other TD engines (2.0/2.2 DTI, 1.7 CDTI and 1.9 CDTI 120) have much slower PCR governor settings than the Z19DTH 150, which explains why this instability doesn't normally occurr on those engines.
  1. 1.9cdti issues
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2012, 14:43
  2. For Sale: Scorpion PreCat DeCat Down Pipe for 1.9CDTi 150
    By jimbojetset in forum Parts for sale
    Last Post: 4th December 2011, 22:20
  3. starting issues 1.9CDTi 8v
    By Kevinw29 in forum Engine & Drivetrain
    Last Post: 14th October 2011, 08:10
  4. starting issues 1.9CDTi 8v
    By Kevinw29 in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2011, 18:10
  5. Decat and precat
    By johnnyboy1985 in forum Diesel Engine related
    Last Post: 11th February 2011, 16:45
vectra c 1.9 cdti percat
diesel mapping gutting pre cat
z19dt decat limp mode
vectra cdti 150 decat
z19dth percat
advanced pid control vectra c 1.9cdti
vectra c precat
2005 vauxhall astra 1.9cdti decat
1.9 gutted precat
