View Poll Results: Which engine have you had problems with?
Voters
366. You may not vote on this poll
  • 1.8
    29 7.92%
  • 1.8vvti
    18 4.92%
  • 2.2 non-direct petrol
    22 6.01%
  • 2.2 direct petrol
    36 9.84%
  • 2.0 Dti
    43 11.75%
  • 2.2 Dti
    35 9.56%
  • 1.9 Cdti (120)
    33 9.02%
  • 1.9 Cdti (150)
    105 28.69%
  • 3.0 V6 CDTi (Euro 3 - 177PS)
    11 3.01%
  • 3.0 V6 CDTi (Euro 4 - 184PS)
    9 2.46%
  • 2.0 Turbo
    16 4.37%
  • 3.2 V6
    17 4.64%
  • 2.8 V6 Turbo
    3 0.82%
Multiple Choice Poll.
Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 130
Thread: Engine reliability
    Regular Member Spikeyİ's Avatar
    Dec 2005
    In the sponge-monkey tent
    Default Engine reliability
    Had any reliabillity issues with your engine? This is purely engine/engine management based. If you have had Engine problems, check the engine type and then post what the problem was.
    [Ex]Admin Duncan's Avatar
    You're talking spanner light coming up kinda thing? or including things like belts/pulleys being replaced? - or just anything that has had to be done under the bonnet?
    What are you defining as a problem?, just so I know whether to vote or not.
    Dec 2005
    Yes faults/breakdowns that kind of thing. Anything that broke basically - not general service items that have been done during servicing.
    Regular Member simac's Avatar
    Wirral
    So far at 52K miles my ickle 1.8 has been problem free (touch wood).
    It's the suspension components which are pants on mine
    Quote Originally Posted by Spikeyİ View Post
    OK, I'll add my few bits a bit later then.
    SOUTH SHIELDS
    1.Clutch and flywheel replaced under warranty 42K
    2.Radiator just replaced 60500miles clamp holding radiator had worn through the top cansing it to leak still wandering if I should take this up with dealer even though car is just out of warranty?
    3. Alternator replaced (vx recall) 59k
    1.9 CDTi 150 -
    1. Manifold & turbo replaced (manufacturing fault)
    2. New Fuel injector (No's 2 and 3)
    3. New Common Rail
    4. New ECU
    5. New Common Rail wiring Harness (I had chopped into the old one though)
    Regular Member breezephil's Avatar
    LONDON
    1.8 Petrol.... No Problems
    2.0 DTi - Whilst on a test drive, kept going into limp mode - put me right off it
    Leicester
    er, non
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Could I suggest we add another entry into the engine choice?
    3.0 CDTi V6 177 (Euro 3)
    3.0 CDTi V6 184 (Euro 4)
    In the same way there are subtle differences between the 2.2 and 2.2 Direct, there are also subtle differences between the 3.0 Euro 3 and 3.0 Euro 4
  1. V6 Diesel reliability
    By Steviec100 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2012, 15:00
  2. 2.0T Reliability ?
    By ukmayhem in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2010, 20:48
  3. V6 CDTI reliability
    By jasv6 in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2010, 15:28
  4. 2.0 T reliability
    By Gregg in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2008, 00:00
  5. Vectra Reliability
    By runs4miles in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2008, 09:48
Vectra c 1.8 petrol Vacuum tube
