Thread: Will these fit my car
    Regular Member thestaffy's Avatar
    belfast
    Default Will these fit my car
    As above as i think this is such a bargin
    http://cgi.ebay.co.uk/18-Kahn-style-...QQcmdZViewItem
    Regular Member Harry's Avatar
    Uxbridge, London
    nice wheel, is it similar to the ones that Caterman had on his Vec?
    have you asked him what offset and PCD they are as i didn't see it mentioned in the ad
    [Ex]Admin Duncan's Avatar
    I think they will. With the PCD being 108 you'll need wobbly bolts, but you'll need to find out what offset they are.
    Harry, I think what they refer to as Stud Diameter is the PCD.
    at 108 they will need 'wobbly' bolts to fit on, and the 40ET is okay, but 38 is better...
    no size of hub bore listed thou, so it may need boring. or having a collar fitted..
    3 replies in 60 seconds...god, we're on form today..
    morton
    thought they had to be 110 and between 35 -49 offset !?
    Here, there and every where!
    They are 108mm PCD and might fit with wobbly bolts. It depends on the centre hub size too m8.
    Yes Harry, the TSW Warriors i had on my old vec were very similar to the Kahns.
    morton
    sure are ! but some of us can type quicker !!! lol
    Quote Originally Posted by veccy22 View Post
    110 is what is needed to fit without wobbly bolts. Up to 108 and 112 and you can fit wobbly bolts.
    Mark, the ad hasn't given an offset. I mis-read the aspect ratio as being the offset ,, so edited my post - which you may have based your reply on?
    yep.. i did.. teach me to fully read it....
