Thread: Towbar Q
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    Default Towbar Q
    Hi guys i bought a towbar, am i right that i need to buy a wiring kit that plugs into my car rather than cutting wires? where would the plug be in my vectra and would it need to be tech 2'd?
    Regular Member daneboy35's Avatar
    darvel,ayrshire
    you can get a loom kit from v/x that plugs into the rear electrical box on the passenger side of your boot,or you need to fit a by-pass relay with a normal loom
    Regular Member marichrd's Avatar
    Jun 2006
    Cheshire
    the loom kit is also available form Witter too. If you buya kit it needs tech 2 enabling
    okay, from my experiences ( and Green growlers) if you buy the £35 VX kit that just plugs straight into the rear fuse box centre and use the VX relay that plugs into the board, you won't need to tech2 a thing..dead easy to fit as well, unless you have got an estate..in which case VX are now going to issue a seperate kit for them as the current kit is 4" too short..
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It is very possible to wire up a towbar without the kit, and without Tec 2 to enable it.
    Not as simple as cutting straight into wires, but not difficult to do.
    The rear tail / stop lights use the same bulb and a lower voltage for tail and full 12 V for stop brightness. Hope that makes sense. The indicator wire can be simply cut into though.
    When I did mine, I used the number plate bulb feed (full 12 V) to operate a relay for the tail lights, and the middle brake light (again 12V and also through a relay) to power the stop lights on the towbar hook up.
    Thats about all you need.
    Left and right indicator, tail and stop. I didn't bother messing with the fog light at all.
    No faults at all. This way even gets round the bulb sensor falsely triggering.
    Not as easy as plug, "enable" and play. But much cheaper. My towbar was bought second hand and already had the twin electrical sockets and wiring, so I couldn't see the point with paying again for a kit and then being robbed by VX to enable it.
  1. towbar
    Last Post: 17th March 2011, 10:49
  2. Which Towbar?
    By humphshumphs in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2010, 21:39
  3. towbar will it fit?
    By xyy81t in forum The 'Off Topic' room
    Last Post: 25th March 2009, 18:50
  4. Towbar help please
    By Robclowes in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2008, 16:56
  5. towbar help
    Last Post: 12th April 2008, 23:11
