Thread: camshaft
    rossendale
    Default camshaft
    hi can any of you guys help me?
    i have a 96 17td i am changing the timing belt, ive locked the top two pullies,but i dont know how to lock the bottom end up, ive bought a hanes manual but it doesnt tell u how to lock it, its realy startind to p*** me off now if you can help please do, its apprichated
    thanks daz thats my head banging of the brick wall,not a ball hahaha
    Regular Member The Doc's Avatar
    'Norf Yorks.
    You don't need to lock the bottom end up? Rotate the crank to it's position, time up and lock the cam pulleys, remove tensioner if you haven't already, fit belt, refit tensioner, tension belt, crank over by hand to check tension. Start engine?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    you dont lock the bottom there is amark on the pully the matches a mark on the oil pump housing at about the 12 oclcok postion looks like a arrow
    rossendale
    Default 17td
    thanks bennie and cdti
    ive took on boad what you have said, ive done it now(thanks) but now as usual a new prob when belt was put back on i manualy cranked the engine . no prob then i started it, it started but has a slight rattle/nocking noise, but ive been out in it today an done about 100miles no prob but the noise is woring as it wasnt their b4, an ideas what it could be??????????
    cdti out of intrest what is the bus you was refering to?????????any picks??
    cheers lads
    rossendale
    Default rear bumper
    hello again
    can anyone help ive just got a tow bar for my 95plate vectra,but i dont know how to take of the back bunper, does anyone no??????????
  1. HELP - where is camshaft sensor.....
    By sri150 in forum Engine & Drivetrain
    Last Post: 30th December 2013, 18:24
  2. Camshaft Woodruff Key
    By 123rado in forum Engine & Drivetrain
    Last Post: 2nd January 2013, 22:54
  3. camshaft scoring
    By keggy77 in forum Engine & Drivetrain
    Last Post: 6th May 2012, 19:06
  4. Camshaft sensor Q?
    By Barlow in forum Engine & Drivetrain
    Last Post: 11th April 2012, 23:03
  5. Camshaft
    By Rebellion8878 in forum Petrol Engine related
    Last Post: 3rd January 2010, 15:51
