Thread: How on earth do you change the spark plugs on the 3.2 ???
    Regular Member muffking's Avatar
    Default How on earth do you change the spark plugs on the 3.2 ???
    Does anyone know how you get to the spark plugs on the 3.2 V6?
    It looks a complete nightmare and that I have to remove the complete plenum... Surely not ??? How would Vx do it as service job if it was made so difficult?
    Melbourne, Australia
    Quote Originally Posted by muffking View Post
    Correct. Lucky they they last 60000 km.
    SOMERSET
    Yes it's a huge pain in the ****, iam sure someone has done a how to step by step a little while ago. If you get any problems email Mark, GSi3.2 he is happy to help(dont tell him i said so)
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Yep believe gsi3.2 helped big Phil change his, a 2 person job?
    it certainly is a big job..yes all the plenubm has to come off, and most of the hidden rear small bore water pipes..
    remove the black ecotec panel on the top of the plenubm and you'll see 5 deep recess's.. these hold torx screws which must be undone..the 6th is hidden under the intake butterfly assy, so you'll have to remove that as well..
    airbox out, intake hose off.. then if all the screws are out the plenubm will just lift up enough ( person 1) while person 2 undoes the coilpacks to remove them and change the plugs..
    watch out for some bi-mettalic corrosion on the manifold screws as they are steel into alloy and the plating is poor...i had a right game..Bring back the old C25XE.. that was a walk in the park compared to now..
  1. How often do you change the spark plugs???
    By philgst in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 12:36
  2. 4th Service, No change of spark plugs?!
    By RobDMX in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2008, 19:59
  3. How To Change Spark Plugs On 3.2 V6
    By tommyk999 in forum General Chat
    Last Post: 15th February 2008, 14:39
  4. Spark Plugs - when to change?
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2007, 18:14
spark plugs vectra zc 3.2
