Thread: Idling At 1200rpm Whilst Coasting
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Default Idling At 1200rpm Whilst Coasting
    Do they all do it, noticed it today whilst I coasted down a road for about half a mile. The rev counter sat a little over 1k until I came to a stop at the junctin when it settled down to where you'd expect it to be.
    Have noticed it behave like this from time to time in the past. Is this normal?
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    They all do it - speed sensor tells ecu car is still moving
    Herts\Beds Border
    Guessed that was the case if it wasn't a fault.
    Cheers.
    Nov 2005
    Somewhere in time
    it's like an anti-stall system,my old Vec b would hold 1000revs for about 2 secs after coming to a holt and then settled back down to 850
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Mine will only do that in fourth gear and it will actually accelerate if I try to brake...
    Dec 2005
    St Helens
    It also keeps the revs there for the vacuum on the servo - helps you stop
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Doesn't do it in any other gear, and didn't ever do it before the remap. Also never does it in neutral.
  1. Revs itself whilst idling.
    By stakeknife in forum Y & Z30DT Specific
    Last Post: 30th January 2015, 13:20
  2. realy bad knocking while coasting
    By tonner in forum Suspension, Wheels & Brakes
    Last Post: 15th November 2012, 22:45
  3. coasting or steady speed problem
    By lgtuk in forum Engine & Drivetrain
    Last Post: 16th July 2010, 19:38
  4. Idle Speed Now 1200RPM 3.2 V6 - Done The Usual
    By Hedgehog70 in forum Engine & Drivetrain
    Last Post: 24th June 2009, 22:44
  5. Coasting rpm problem - help needed please
    By Vid in forum Engine & Drivetrain
    Last Post: 29th May 2008, 08:27
vauxhall vectra idling at 1200 rpm
