Thread: The man who can
    Dec 2005
    In the sponge-monkey tent
    Default The man who can
    Comes up trumps again.
    Asked Mr GSi3.2 for some advice about sorting the 'snot rocket' out. Been having a problem with it cutting out when slowing to a stop and the engine 'racing' to find revs at idle. Armed with Mark's guide and a can of carb cleaner stripped out the Idle Control Valve (ICV) and gave it a thourough clean. The throttle butterfly was choked up and causing it to stick so that got a good seeing to. Also found the crank case breather was nearly blocked so that's been done too.
    Results? WOW, like a different car, smooth as a baby's bum now. Idles perfect and throttle response is crisp. Feels like I've gained a few horses too...must take it down to Regals and see if it's over the 200bhp yet!
    Oh and changed the plugs while I was under the hood
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Sounds like a result mate
    Regular Member Harry's Avatar
    Uxbridge, London
    'The man who can'.....fitting title!
    Good result Neil
    spoons
    Guest
    Sorted.... and still enough time for a beer !!
