Results 1 to 2 of 2
Thread: Rear Light Cluster
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Default Rear Light Cluster
    Hi Guys
    Are there any photos on line I could use as a guide for removing the rear light cluster.
    Some ****** has let a shopping trolley go into my new mota and smashed the nearside one..........
    Any tips welcome!
    right.. dead easy to do..haven't got any photo's, but i'll try ang guide you along....
    you CAN access the 3 little nuts from the cubby hole in the NS boot liner.., but if you don't know what you're looking at it'll be easier to remove the liner..lift the boot carpet..now prise forward ath the base the rear black hard plastic boot cover ( you'll need to move the luggage restarint points) and pull it up.. it'll just unclip..
    remove the 1 x plastic stud on the NS boot aperture that holds the liner in, and the liner will pull out of the boot seal giving you the access you need..
    then it's one multiplug to undo, and the nuts on the ends of the goldy studs are all that hold the lamp in..
    Clear as mud?..M
  1. Rear light cluster
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2009, 16:38
  2. Rear light cluster
    By KSD in forum Styling
    Last Post: 3rd February 2008, 15:26
  3. Rear Light cluster
    By phildews in forum Styling
    Last Post: 25th July 2007, 03:32
