Thread: Wiring an active sub
    Regular Member raymie.d's Avatar
    Feb 2007
    Glasgow
    Default Wiring an active sub
    Hi guys, new at this so bear with me. I have an blaupunkt active sub (100W) and I have wired it to one of the spare connectors on the connector block next to the fuse box (behind the glove compartment). Is this a good idea or should I move it to the auxilliary socket on the central console, disconnecting the aux socket and using this as my feed? It has a 7.5 inline fuse.
    Also, before I wired this in my radio reception was great, now I can only get about two radio stations, any ideas?
    Feb 2006
    Dorset
    ANY subwoofer amp etc should be wired drirectly to the battery . tapping off of a fuse board in a car can lead to a fire . wire it correctly !!!!
    if the radio had lost all stations check the 12v feed to the ariel base as it has an amp built in sounds like it has gone or lost its power supply .
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    what you need mate is this http://cgi.ebay.co.uk/600w-car-amp-w...QQcmdZViewItemmake sure the fuse is as close to the battery as possible plus it could be the sub causing the radio interferance maybe
    Feb 2007
    Glasgow
    Thanks guys I will disconnect it tonight and look into feeding from the battery.
    Feb 2006
    Dorset
    If you drop the glovebox out (5 torx T20 screws) you will see the gromet you need to go through , its dead easy to do .
    Feb 2007
    Glasgow
    Thanks Dennis I went out to the car and found the grommet. Job done!!
  1. LS Active Saloon
    By kvraider in forum Quick Photo Album
    Last Post: 27th June 2011, 19:44
  2. Anybody seen ........ not been Active for a while
    By WeDesign in forum The 'Off Topic' room
    Last Post: 22nd June 2009, 15:13
  3. Most active
    By T4M in forum General Chat
    Last Post: 4th January 2008, 22:46
  4. Active users !
    By John H in forum General Chat
    Last Post: 27th February 2006, 14:01
  5. Active Owners?
    By Paulmac07 in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2006, 19:30
